whiplash break in!
#1807654
04/20/15 12:22 PM
04/20/15 12:22 PM
Posts: 15,487 Florida
scratchnfotraction
got the 440 upper end freshend up the last 2 weekends. swapped on a set of rebuilt 452 heads with the Hughes springs,hedman hedders, 3" pipes/3" muffs. test drove and runs great no issues. ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) this weekend I swapped in the hughes whiplash cam, lifters, t-chain,t-cover, M/T valave covers, cleaned up the wire harness down the VC area. fired it up first spin, run for 30 mins to break cam in,shut down to cool down some, drove 10 miles with no issues. let it cool down and changed oil out for the Amsoil high zinc 100% full synthetic 10w40 oil with amsoil large filter. drove 35 miles at different speeds none over 65 mph. shut down over night, fired right up this morning for a 40 mile ride to work no issues. the q-jet is gong to the shelf and the holley 650 dbl pumper is going on for fine tunning after work today. man I am stoked..it is a nasty sounding beast now but drives rather tame on the street like advertised. HUGHES ENGINES ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif)
Re: whiplash break in!
[Re: scratchnfotraction]
#1807676
04/20/15 12:56 PM
04/20/15 12:56 PM
Posts: 20,707 in a cattle trailer down by th...
Guitar Jones
Sounds good. I would go for a larger carb though. Maybe an 850 or at least a 750.
[Re: 77ProStreet]
#1808462
04/21/15 10:38 AM
04/21/15 10:38 AM
scratchnfotraction
well this facebook lurker need to catch me in the act for a pic/vid. I don't have parts to tune the q-jet and low vac is not helping it at all. drivable but got watch the idle in gear when stoped. it is slow to return to idle, then the vac will pull the needles down and drop rpm fast. so.. need to get the holley on, I have it already set up with the the PV in the correct ball park and returned the carb to specs to start tunning it in from there. the cam is the 440 flat tappet whiplash cam. used the Hughes matching spring, pro-gear DR t-chain/gears,milodon t-cover/timming tab. all superformance gaskets, which are very nice. I think I will save up for the RTR firecore dist/wires next. BUT most likely NEED tires next.
[Re: tmef]
#1808649
04/21/15 03:04 PM
04/21/15 03:04 PM
scratchnfotraction
Scratch, what are you pulling for vacuum at idle? GOOD ? , GOT ME? I am on lunch and swapping the q-jet off for the holley. then after work I will put a vac gauge on and recheck timming/rpm. its in the 800-900 rpm range and fluctuating on idle due to power piston spring...what I thin any ways. I let you know tonight.
[Re: wedgeheaded]
#1808802
04/21/15 06:31 PM
04/21/15 06:31 PM
scratchnfotraction
I bought a Whiplash for the 360 from the Doba and it's in the motor but not in the car. I'm thinking about putting it into the 80 PU till I get the Doba done. Looking forward to a listen. Love that cam. I think you will like it. I know I would be real happy with that car and a 360 whiplash.
#1808848
04/21/15 07:47 PM
04/21/15 07:47 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Looks really nice Scratch. Wish I had my BB in something. Some day tho', some day. May I ask, "What is the part # for that wiplash cam?" I have an old motorhome 360 I'm wanting to put in my 76 and a good cam wouldn't hurt.
I have mechanical Aptitude. I can screw up anything.
