Re: 67 Valiant budget built to race 2015
[Re: Tomswheels]
#1817118
05/02/15 02:53 PM
05/02/15 02:53 PM
Posts: 240 Plano, Texas
68cuda440
Plano, Texas
Two '67 Valiants is the top 5? Why do they have your's listed as a '69? You had more than a full second on him on a minute long course.
Michael
1968 Barracuda Notchback Coupe
440 EFI 6-pack, T56 Magnum 6-spd
[Re: 68cuda440]
#1817233
05/02/15 05:27 PM
05/02/15 05:27 PM
Posts: 380 Escondido CA USA
Tomswheels
Escondido CA USA
Ya both Valiants were my 67, they had my year wrong. George is my Bodyman/Painter so as he tries to fix all his Chevys, he co-drives my Valiant
[Re: Tomswheels]
#1817241
05/02/15 05:37 PM
05/02/15 05:37 PM
Tomswheels
Escondido CA USA
Thanks Samy, Emil, and Wade! It's been a lot of fun so far this year wheelin this Valiant around, but I'm planning some mid-season upgrades in May to see if I can get it fast enough for Optima. The Barracuda was cool, young guy who's Father apparently owns a new Fuel Injection company called "FI Tech". It had some suspension upgrades and sticky front tires, but drag radials in back. You can definitely see the dividing lines in times (6 seconds between 8th and 9th) between the guys who do this a lot with sorted cars and those just starting to get cars into it...
[Re: Tomswheels]
#1818423
05/04/15 12:10 PM
05/04/15 12:10 PM
Posts: 1,443 NW Chicago suburban area
Mopar Mitch
Its always fun beating the other brands!!!
Mo Power to ya!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Tomswheels]
#1818685
05/04/15 05:42 PM
05/04/15 05:42 PM
Tomswheels
Escondido CA USA
So I've decided to try and address some of the shortcomings in May and get the Valiants performance absolutely optimized to the extent financially practical. 1. Better front Brakes! I was able to find a no-longer produced set of AR engineering caliper brackets so I upgraded to the 11.75 inch 1978 Córdoba rotors, and Wilwood 4 piston dynalite calipers. Total cost right at $500. The braking seemed improved already, but I have not had it at a track that demands a lot of braking yet. 2. Better Gearing! I bought a used A833 that I believe has "normal" 2.66 first gear gearing. This will get installed later in the month... 3. Higher spring rates... The car just looks like it leans ALOT in some corners, particularly when the sticky tires are gripping well, so I am thinking of jumping to 1.12 or 1.18 bars in front, and trying to figure out how to up the Hotchkis rear leaf rates in the rear... Any ideas? I finally had it correctly corner weighed, with a full tank, battery in the trunk, but no driver...
[Re: Tomswheels]
#1818720
05/04/15 06:22 PM
05/04/15 06:22 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I plan to add lower leafs out of an old set of Mopar circle track springs and at least one,maybe 2, half leafs to my Hotchkis packs. Also have a Hellwig adjustable tubular E body rear swaybar to take it from there. Time will tell.
Mopar to the bone!!!
[Re: Tomswheels]
#1818748
05/04/15 06:51 PM
05/04/15 06:51 PM
68cuda440
Plano, Texas
Is it important to increase spring rate or total roll rate? If the answer is total roll rate you can add rear bar could you not?
Michael
[Re: 68cuda440]
#1818808
05/04/15 07:45 PM
05/04/15 07:45 PM
Tomswheels
Escondido CA USA
Is it important to increase spring rate or total roll rate? If the answer is total roll rate you can add rear bar could you not? I'm at full stiff on the Hotchkis rear bar now...
[Re: Tomswheels]
#1818864
05/04/15 08:55 PM
05/04/15 08:55 PM
72Swinger
Nebraska
They would but for the money , if you have time, I would just add a leaf. Also since our current leafs have 0 arch those things are not very effective.
[Re: Tomswheels]
#1818876
05/04/15 09:02 PM
05/04/15 09:02 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
My understanding is most of the leaf's spring rate is in the portion behind the axle. The Hellwig product you posted helps with axle wrap more so than increasing spring rate.
Which front sway bar? Hotchkis 67-72 a body bar? With rubber bushings? How tight are the end links?
You should consider swapping to a ball joint style sway bar end link. Really helped with the lean on mine. Doesn't change your roll rates, just brings the sway bar in sooner.
I agree with upping your spring rates as well. Which you are doing. May just need to buy new leaf springs though.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Tomswheels]
#1818901
05/04/15 09:27 PM
05/04/15 09:27 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
3. Higher spring rates... The car just looks like it leans ALOT in some corners, particularly when the sticky tires are gripping well, so I am thinking of jumping to 1.12 or 1.18 bars in front, and trying to figure out how to up the Hotchkis rear leaf rates in the rear... Any ideas? What kind of chassis stiffening has been done to the car? Looks like it has a cage, which obviously helps a bunch. But call me crazy, it almost looks like chassis compliance is adding into some of that roll when the pic is blown up, like the bottom of the door is kicking out.
