Re: Seat and seat belt nhra rules
[Re: mechanic190]
#1804575
04/15/15 11:58 PM
04/15/15 11:58 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Somebody can correct me if I'm wrong, but if they are aftermarket belts, they need to be up to date. Doesn't matter if the ET requires them or not.
[Re: mechanic190]
#1804669
04/16/15 01:25 AM
04/16/15 01:25 AM
Posts: 360 Ohio
shorthorse
Ohio
Can I put a plate under the floor board or how do I go about the crossmember part in section 6? How can I go about bracing the back also with out a cage. The stock seat belt holes go through a crossmember but not the racing seat You can purchase different "universal" seat mounting brackets at Jeg's or Summit that will probably align with the crossmembers. They are not that expensive. The back brace is another issue. I guess NHRA assumes that if you have a racing seat you have a rollbar. That would explain the shoulder and back brace requirements. I had a plastic seat that didn't have a back brace and I got caught at the track. I do understand the rule because those plastic seats flex a lot.
[Re: WILD BILL]
#1804675
04/16/15 01:32 AM
04/16/15 01:32 AM
Posts: 360 Ohio
shorthorse
Ohio
Somebody can correct me if I'm wrong, but if they are aftermarket belts, they need to be up to date. Doesn't matter if the ET requires them or not. You are wrong. If the car is not required by the rules to have them they do not need to be with in the 2 yr date.
It's in the general rules section in the back of the book. Can't recall the page # though. Bill, I found the rule on page 43 and you are right. It says the classes that don't require 16.1 or 16.5 restraint systems "the two year re-certification does not apply". But you'd better take your rule book with you to tech.
[Re: shorthorse]
#1804825
04/16/15 10:49 AM
04/16/15 10:49 AM
Posts: 20,698 in a cattle trailer down by th...
Guitar Jones
It's in the general rules section in the back of the book. Can't recall the page # though. Bill, I found the rule on page 43 and you are right. It says the classes that don't require 16.1 or 16.5 restraint systems "the two year re-certification does not apply". But you'd better take your rule book with you to tech. Knowing NHRA what that means is you don't have to replace the stock belts every two years. However if the belts are the 16.1 type you won't be able to use out of date ones. It's like if your car doesn't pass a chassis cert you can't race it even in a slower class that doesn't require it.
[Re: mechanic190]
#1804885
04/16/15 12:44 PM
04/16/15 12:44 PM
Guitar Jones
It's really going to be up the tech inspector at the track. It's virtually impossible to argue with them though. I just nod and say yes sir, I'll have that fixed next time out.
[Re: mechanic190]
#1804891
04/16/15 12:53 PM
04/16/15 12:53 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
if it does not run 11.49 you do not have to change belts every two years. just put an old set in a car yesterday. the seat bracing is going to be iffy depending on the tech guy. I am a bronze certified tech guy thru the NHRA. if you wanted to you could just use the lap belt out of the harness.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: Guitar Jones]
#1804903
04/16/15 01:12 PM
04/16/15 01:12 PM
Posts: 503 Idaho
1320Dart
Idaho
It's in the general rules section in the back of the book. Can't recall the page # though. Bill, I found the rule on page 43 and you are right. It says the classes that don't require 16.1 or 16.5 restraint systems "the two year re-certification does not apply". But you'd better take your rule book with you to tech. Knowing NHRA what that means is you don't have to replace the stock belts every two years. However if the belts are the 16.1 type you won't be able to use out of date ones. It's like if your car doesn't pass a chassis cert you can't race it even in a slower class that doesn't require it. You are correct. I have seen it happen out at our local NHRA track. If you are in a class that your stock seat belts are ok. DON'T PUT IN AFTERMARKET BELTS!!.IF IT HAS AN OUT OF DATE SFI STICKER ON IT YOU CANNOT RUN THEM. But it is ok to use 20 year old stock ones ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
[Re: Guitar Jones]
#1805588
04/17/15 01:49 PM
04/17/15 01:49 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
It's really going to be up the tech inspector at the track. It's virtually impossible to argue with them though. I just nod and say yes sir, I'll have that fixed next time out. Been to E-town with expired belts. The inspector said if they are in the car (mandatory or not) then the have to adhere to the date rules. Period.
"I think its got a hemi"
[Re: mechanic190]
#1805782
04/17/15 06:57 PM
04/17/15 06:57 PM
kissmyaspen
Newark,Ohio
call your division director.. but if the car run SLOWER than 11.49 the belt DO NOT HAVE TO BE UPDATED EVERY TWO YEAR. THis just changes in the last 3-4 years.
[Re: mechanic190]
#1805794
04/17/15 07:12 PM
04/17/15 07:12 PM
kissmyaspen
Newark,Ohio
10:5 DRIVER RESTRAINT SYSTEMS A quick-release, 3-inch-minimum-width driver restraint system, with a 2-inch crotch strap, meeting SFI Spec 16.1 or a 2-inchminimum- width driver restraint system, with a 2-inch crotch strap meeting SFI Spec 16.5 is mandatory in all cars in competition required by the rules to have a roll bar or a roll cage. (Permitted in all other classes.) Driver restraint system must be clearly labeled as meeting SFI Spec 16.1 or SFI Spec 16.5 and be dated by manufacturer. SFI 16.1 or 16.5 3-inchwide shoulder harness straps folded over and sewn to be 2 inches wide by the original manufacturer in order to fit into head and neck restraint lips/channels are acceptable; SFI 16.1 2- inch-wide shoulder harness straps are not permitted. See Class Requirements for additional requirements for Top Fuel and Funny Car. SFI Spec 16.1 or 16.5 Y-type belts prohibited. (In cases where the class does not require an SFI 16.1 or 16.5 driver restraint system, the two-year recertification does not apply.)
From the Rule Book
