Re: The Quest Has Begun......605 Hemi Build, Parts Arrived!
[Re: JohnRR]
#2077401
05/20/16 11:24 PM
05/20/16 11:24 PM
Posts: 12,384 Taxes & Virus's R-US, NY
Dragula
[quote=rowin4]
I guess you found out you can't build pressure from a suction port. I would plumb in the accumulator off another port. Do you have a remote oil filter? I was told, it was a pressure supply port, but we could not get pressure from it, so the assumption its a suction port could be inferred, I guess. I have no other current way to get an AN10 line to attach to the block right now, so the accumulator is on the shelf for now. Does the Indy block have oil pressure ports on the rear like a stock block, that would be the place to plumb ... unless the ports are supplying oil to the heads ? Yes it does, but they are small....Nothing I would use for an AN10 line.
[Re: Dragula]
#2098984
06/27/16 12:59 AM
06/27/16 12:59 AM
Dragula
So just an update.......At the first track outing, the car did remarkably well. Went a best of 6.32 at 108mph and the only thing I worked on was the rear suspension. So thru the mufflers, on DOT approved 31x15 Hoosier QTP's and mono leafs with Rancho rear shocks, it went 6.32 at 108....Had a bunch of 6.40's and the tuning on the rear shocks finally netted some improvements in the launch for a bunch of runs in the 6.3's with a best 60ft of 1.38.... Still had the cowl hood on it....Vid of 6.36 run against my buddy's race car...I won! https://www.youtube.com/watch?v=NVTE82X6ZQ8
[Re: Dragula]
#2101079
06/30/16 12:46 PM
06/30/16 12:46 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Lookin good man and the scoop change will change the tune as you noticed but should come around........
[Re: gsmopar]
#2102280
07/02/16 12:31 AM
07/02/16 12:31 AM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: unknown]
#2137839
08/21/16 01:07 PM
08/21/16 01:07 PM
Dragula
Looking good, much easier to fix then cast iron. Agree'd, but not what I had in mind for my Hemi this year that is for sure.
[Re: Dragula]
#2137868
08/21/16 01:40 PM
08/21/16 01:40 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
It has to make you feel good that it is repairable. I'm guessing you'll forget all about it when you fire that puppy up again.
[image][/image]
[Re: Dragula]
#2137895
08/21/16 02:09 PM
08/21/16 02:09 PM
Posts: 1,505 TN
SCATPACK 1
TN
Question? Do you ned to put the main caps in and torque them down before you weld the block pieces back in so it limits the distortion from the welding? Asking as I am looking at a used block that needs similar repairs. Good luck with it. Jerry
Old Geezer Racing
[Re: SCATPACK 1]
#2137907
08/21/16 02:22 PM
08/21/16 02:22 PM
Dragula
Question? Do you ned to put the main caps in and torque them down before you weld the block pieces back in so it limits the distortion from the welding? Asking as I am looking at a used block that needs similar repairs. Good luck with it. Jerry No, but we will be checking for it when its done. We have to heat it to around 200* so we can weld it. We have an oven in the shop that we normally cook CI blocks in to get all the junk off of before shot blasting them. So we are going to put it on super low temp and bring it up to welding temperature......Should be done next weekend if all goes well.
[Re: Dragula]
#2137913
08/21/16 02:30 PM
08/21/16 02:30 PM
Thumperdart
State of confusion
Good to see you`ll be back in action again.............
[Re: Thumperdart]
#2137922
08/21/16 02:40 PM
08/21/16 02:40 PM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm so glad that your block ended up being repairable. That had to be a sick feeling in your gut.
Re: The Quest Has Begun......605 Hemi Build, Updated!
[Re: slantzilla]
#2139622
08/23/16 11:23 PM
08/23/16 11:23 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Glad to see it going back together. I agree, and good luck with the rebuild. Mark
