Re: How much can you deck a 440
[Re: BPBP440]
#1801836
04/12/15 06:37 PM
04/12/15 06:37 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
If it's a street cruiser, why worry about a chamfer at the top of the bore??
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Twostick]
#1801960
04/12/15 09:36 PM
04/12/15 09:36 PM
Posts: 264 Farmington Hills, MI
BPBP440
IMHO as long as the top ring is below the chamfer, it's a non issue.
IIRC it took .007 to square and zero my 493.
Kevin Thanks
[Re: Stanton]
#1801976
04/12/15 09:47 PM
04/12/15 09:47 PM
BPBP440
Decking has no affect on pushrod angle. The decks are always cut square to each other and 90* to the bore.
Okay, good to know. I did not know if the push rod to rocker arm contact point was absolutely perpendicular to the lifter bore. In some engines they are not, due to optimal valve location/angle and resulting valve train geometries. Too much decking can compromise the geometry to an unacceptable point.
[Re: BPBP440]
#1802112
04/13/15 12:13 AM
04/13/15 12:13 AM
Posts: 8,887 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Okay, good to know. I did not know if the push rod to rocker arm contact point was absolutely perpendicular to the lifter bore. In some engines they are not, due to optimal valve location/angle and resulting valve train geometries. Too much decking can compromise the geometry to an unacceptable point. Well, its probably not perfectly perpendicular to the lifter bore in a big block but regardless, any amount of decking would not have any significant affect. You would have more of an impact by changing the rocker ratio !!
[Re: BPBP440]
#1802704
04/13/15 09:42 PM
04/13/15 09:42 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
.006 to square up my 73 440 block
[Re: BPBP440]
#1802857
04/13/15 11:32 PM
04/13/15 11:32 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Perhaps. Still curious about the answers to the question for my own knowledge base, but some more background. Pretty much any flat top piston to bump me into the 9:1 area will have a top of piston above the bottom of the chamfer. Does anyone see this as an issue? Seems like a nice little pre-detonation "chamber". Thanks. As far as how far you can go before you have to cut the intake or the intake side of the manifold, ive gone as far as .040. Even with that you might have to drill out your intake bolt holes a little, and do some port match up adjustments.
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
[Re: BPBP440]
#1802960
04/14/15 12:46 AM
04/14/15 12:46 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The late 70's RV block I am working with has a .106 deep chamfer at the top of the bore.
Three part question: How much can you deck a 440 block?
How much before you need to cut the intake manifold?
How much before it negatively affects pushrod angle (street cruiser engine)?
Thanks! For every .010 you cut off the head surface you take .0095 off the intake surface.. how well do your ports line up now
[Re: MR_P_BODY]
#1802974
04/14/15 01:12 AM
04/14/15 01:12 AM
Sport440
Canton, Ohio
Thanks! For every .010 you cut off the head surface you take .0095 off the intake surface.. how well do your ports line up now Mike for the BB, the correct known ratio is for every .010 you remove .0123 from the intakes surface, or the heads intake surface. But, that doesn't have to be followed as gospel. As you continue to shave the head or the deck say .010, the intake/ports will keep scooting up in relationship to the heads. That can be a good thing, if you raise the port roof on your heads during porting. A .040 deak/head shave is the max that ive gotten away with without having to touch the intake side.
[Re: quickd100]
#1803935
04/15/15 02:32 AM
04/15/15 02:32 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
The block I decked .146 was a 413 truck block that was bored to 4.25 and fitted with 11.5-1 max-wedge pistons. With a set of 516 heads on it the compression worked out to 8.44-1. To get to the blueprint spec of -.015 deck height I had to deck it .146, I also milled the intake .180. Final compression worked out to 11.88-1. The motor is all bolted up to the dyno but haven't had time to fire it up yet.Dave Curious to see how that ends up sealing/working. How much did it all run (for the EXTRA machining, read: not the decking, but the extra 1/8" ov decking, extra milling etc.)? Enough to warrant not going with custom pistons (in someone else's case lets say).
