Page 6 of 7 1 2 3 4 5 6 7
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: amxautox] #1812086
04/26/15 12:32 AM
04/26/15 12:32 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Originally Posted By amxautox
Passing 3 cars at once, in between the center lane car and right lane car, and then cutting to his left a bit sharply ending up in front of the center car. That one? I was thinking that he was lucky that he didn't spin out at that point.
They drive like that around here on their morning commute... why would the track be any different. I am a little wary about going to track events with people on the track with me who have cars that are easily replaced.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: autoxcuda] #1812090
04/26/15 12:35 AM
04/26/15 12:35 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
That's what makes running with Vipers more comfortable, 90% of those guys are on the track with their pride and joy and they use more common sense. Mustang guys are NOT that way lol!
Mopar to the bone!!!
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: Tomswheels] #1814195
04/28/15 09:09 PM
04/28/15 09:09 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Thanks a lot to all that showed up.
My friends and I had a great time all weekend.
I didn't drive the track this year, little wiped out in the head.
But still great to get out to see you all having fun.
Can't wait to get back out.
We are thinking next trip west we have some of you over to the house for some cold beer and real brick oven pizza. (Toluca Lake)
Is there a track day at the Fall Fling.
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: autoxcuda] #1920977
09/27/15 11:56 PM
09/27/15 11:56 PM
Victoria B. C Canada
gold66cuda Offline
gold66cuda  Offline
Originally Posted By autoxcuda
This was a weird one.
Might be been from old age or just a fluke. But someone pointed out chroming can make the steel brittle. Running at speed put a lot more vibrations and stress on about everything.
Evan had the can on his power steering come off right above where it's soldered/fusion welded/?? on. The weld didn't fail if you look closely, it was the metal right above the weld.
Thought I would update everyone on what I did to ensure this wont happen again. I bought a type 2 pump from Tuff Stuff, a tank from Canton Racing and a pulley and flow regulator from Turn One. I made up some aluminum brackets got things to line up and had some hoses made up, added a tube type cooler, cut down the tank and installed the adjustable flow control valve. So far with the setting on the flow control valve on low it feels pretty good. I haven't beat on it too hard yet but the fluid temp is well below the old set up. As an added bonus this set up, brackets, pump cooler and hoses weigh 6 pounds less then the old Saginaw pump and hoses with out a cooler. Wanted to post pictures but cant figure that out!! Dam
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: gold66cuda] #1921003
09/28/15 12:59 AM
09/28/15 12:59 AM
So Cal
autoxcuda Offline OP
So Cal
Did that tuff stuff pump come with a cast iron or aluminum pump housing?
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: autoxcuda] #1921012
09/28/15 01:25 AM
09/28/15 01:25 AM
gold66cuda Offline
gold66cuda  Offline
I used the aluminum one. Steve I will send you some pictures of it as I cant get them to post.
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: gold66cuda] #1921027
09/28/15 03:16 AM
09/28/15 03:16 AM
So Cal
So Cal
I'll post them for you. Those files are over 2MB in size. You need resize them in Microsoft Picture Manager or similar.
But this is how to post pictures once they are less than 2MB.
Not too hard. You have to hit the button on the quick reply screen that says "Switch to Full Reply Screen"
Then do this:
Once you chose you file, you MUST hit the "Add File" button to actually upload the attachment to your post
Read here for some other hints on the new forum:
https://board.moparts.org/ubbthreads/ubbt...tml#Post1799584
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: autoxcuda] #1921029
09/28/15 03:21 AM
09/28/15 03:21 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I'll post them for you. But this is how to post pictures.
Then do this:
He posted them on FABO...
http://www.forabodiesonly.com/mopar/showthread.php?p=1970983784#post1970983784
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: MuuMuu101] #1921030
09/28/15 03:35 AM
09/28/15 03:35 AM
So Cal
So Cal
Before and After on Evan's p/s pump setup:
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: autoxcuda] #1921034
09/28/15 03:42 AM
09/28/15 03:42 AM
So Cal
So Cal
More details of Evan's pump install and fabrication.
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: autoxcuda] #1937412
10/23/15 04:59 PM
10/23/15 04:59 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
What is the date of the event for 2016?
I need to take vacation time to go down to SoCal and want to put my request in at work
Thanks!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: RylisPro] #1937593
10/23/15 11:12 PM
10/23/15 11:12 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Thanks!
Fall Fling is this weekend so they won't announce it for another month. Hopefully this time I'll actually be able to take my Dart to all 4 of the event days...
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: RylisPro] #1938167
10/25/15 04:13 AM
10/25/15 04:13 AM
So Cal
So Cal
Thanks!
Spring Fling XXX 30th Anniversary show is:
April 23 & 24, 2016
Spring Fling Speed Festival "10" will be April 21, 2016
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: autoxcuda] #1938272
10/25/15 12:02 PM
10/25/15 12:02 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Alright! Looks like I'm taking April 20-22 off work.
With my car up and running I should have no excuses of not making it
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: RylisPro] #1938390
10/25/15 04:01 PM
10/25/15 04:01 PM
So Cal
So Cal
Awesome!! up drive
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: autoxcuda] #1939291
10/26/15 09:50 PM
10/26/15 09:50 PM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
submitting vacation time tomorrow. Gold66 glad you got that figurd out. hope we get to see you again next year.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: autoxcuda] #1941952
10/31/15 12:35 AM
10/31/15 12:35 AM
so cal
alltime Offline
alltime  Offline
so cal
Looks like a group is forming a Caravan to drive down from the Pacific Northwest. Their talking about it on Mopax group.
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: alltime] #1941976
10/31/15 01:45 AM
10/31/15 01:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
They're.
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: Kern Dog] #1941980
10/31/15 01:54 AM
10/31/15 01:54 AM
gold66cuda Offline
gold66cuda  Offline
Making plans to head down again, hope it works out.
Re: Spring Fling Speed Festival "9" Apr 9, 2015 track day [Re: autoxcuda] #1942301
10/31/15 03:49 PM
10/31/15 03:49 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
This is a good time of year to go race, I just have to much else going on next year that I cant flake out on.
