Re: New spoiler
[Re: Mr.Yuck]
#1808007
04/20/15 07:45 PM
04/20/15 07:45 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Does this have a yet to be installed back window? I would think the airflow would rather turbulent without a window, and decrease efficiency of the spoiler requiring it to be much higher to be useful and therefore greater drag. What speeds are talking? That will definitely be a point of turbulent air. I would have sealed that up well before worrying about a spoiler. But that's just my 2cents...the spoiler looks like good handy-work though! we get dinged for Lexan/plastic $X per cubic inches/feet. We are close to the $500 limit now. Once we see how much room we have after our mods are added up. We should have room for the rear hatch. Hmm, I would try to get something on there. May be work some Tuft testing to see how bad you want it, it'll at least give you some sort of feedback on what's going on back there.
Re: New spoiler
[Re: Mr.Yuck]
#1808017
04/20/15 07:58 PM
04/20/15 07:58 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Wrap a piece of sheet metal around it and fire up the mig.
Rearward vision is highly overrated.
Re: New spoiler
[Re: feets]
#1808486
04/21/15 11:02 AM
04/21/15 11:02 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Rearward vision is highly overrated. We get hit for sheet metal too. It's funny that you say rearward vision is over rated, my team mate yelled at me on the radio to stop looking in the rear view mirror and worry about what was in front of me.
Re: New spoiler
[Re: Mr.Yuck]
#1808703
04/21/15 04:17 PM
04/21/15 04:17 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
When you get the size figured out, layup some carbon fiber, it will be way less weight and mucho stiffer. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: New spoiler
[Re: Mr.Yuck]
#1809059
04/21/15 11:18 PM
04/21/15 11:18 PM
Posts: 4,323 NY NY
340duster340
NY NY
you could make it tunable with turn down flaps, or just saw-zall away.
it looks like you have a piano hinge at the bottom, you could use turn buckles on the same side to adjust the height/angle rather than have fixed mounts.
also what kind of speeds are we talking about?
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
Re: New spoiler
[Re: Mr.Yuck]
#1809341
04/22/15 12:36 PM
04/22/15 12:36 PM
feets
Senior Management
Senior Management
Irving, TX
Fab up a set of rear window louvers. It might help straighten out some of the air flow through the car and onto your spoiler.
Throw the judges for a loop and use papier mache.
Re: New spoiler
[Re: feets]
#1809643
04/22/15 07:19 PM
04/22/15 07:19 PM
Mr.Yuck
Brookeville, Md
Throw the judges for a loop and use papier mache. funny you should say that. I said I'll get a set of louvers and we should be good. They do not count against the car. The team said they are ugly I said so is the entire car.
Re: New spoiler
[Re: Mr.Yuck]
#1809738
04/22/15 10:00 PM
04/22/15 10:00 PM
Posts: 1 Central Jersey
MagillaGuerrilla
Central Jersey
[/quote] we get dinged for Lexan/plastic $X per cubic inches/feet. We are close to the $500 limit now. Once we see how much room we have after our mods are added up. We should have room for the rear hatch. [/quote] If this is for ChumpCar, check the rulebook for 2015 updates - Lexan rear windows (including hatch) are now free so long as they conform to the OE size, shape, and location. See Rule 9.1.6.3 and Rule 9.1.7.1 here
Re: New spoiler
[Re: MagillaGuerrilla]
#1810006
04/23/15 09:59 AM
04/23/15 09:59 AM
Mr.Yuck
Brookeville, Md
[/quote]
we get dinged for Lexan/plastic $X per cubic inches/feet. We are close to the $500 limit now. Once we see how much room we have after our mods are added up. We should have room for the rear hatch. If this is for ChumpCar, check the rulebook for 2015 updates - Lexan rear windows (including hatch) are now free so long as they conform to the OE size, shape, and location. See Rule 9.1.6.3 and Rule 9.1.7.1 here [/quote] good to know, Thanks
