Re: What happened to this bearing
[Re: mopster]
#180342
01/01/09 05:15 PM
01/01/09 05:15 PM
Posts: 1,072 The Sunny Shuswap
dodgefarmer
The Sunny Shuswap
After about 600 street miles the oil looks really bad and it has lost most of its viscosity. Oil used is valvoline VR1 20W/50. Oil pressure drops to 55 psi from normal 65 psi
I hav'nt used Valvoline 20W/50 since 1977 for that very reason. That being said I would suggest that you get an oil sample analyzed (like I should have done) . Looking back I believe that I probably had severe fuel contamination but I'll never know for sure.
Randy
#180343
01/02/09 10:12 AM
01/02/09 10:12 AM
Posts: 128 Finland
mopster
Finland
please post good clear pictures of the front and back of a pair of rod bearings and main bearings. it's hard to tell what the problem is when it's only being described by someone. pictures ar worth 1000 words.
Here we go.
[Re: mopster]
#180347
01/02/09 10:47 AM
01/02/09 10:47 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Is there any spring left in the bearing (so they fall right into the saddles or do you have to push them in). If the spring is gone it would indicate an overload/detonation. Look at the cap mating surface. Does it look like there has been metal transfer? Another indicator of overload/detonation.
How does the crank look (scratches, etc). Could some particles have gotten in the oil?
I would suppose with a chevy oil pump that it could be possible that the pump is cavitating/overheating the oil on bypass. You could try using a thinner oil (10/40 or 10/30) If the clearances are tight the above 2 oils should be fine.
[Re: mopster]
#180349
01/02/09 02:04 PM
01/02/09 02:04 PM
Are those std. size bearings or are the bigger?Next what does the crank look like? any ridges burrs around the oiling holes. Have you mic-ed the crank? Check for taper and roundness... Something is definitly heating up the bearings...
[Re: mopster]
#180350
01/02/09 02:10 PM
01/02/09 02:10 PM
Posts: 1,379 Houston,Tx.
Lee446
Houston,Tx.
This may sound very basic, but, what is the capacity of the oil pan? I was rebuilding my Chevy truck 350, and as a matter of course, I told the machine shop to get me a high volume pump. My machine shop builds lots of Chevy's for dirt track and drags, and the engine builder advised me not to use one with the stock 5 qt. pan as it would suck it dry at higher rpm. I have never had that problem with my Mopars, but they are all BB with at least a 6 qt. pan.
[Re: mopster]
#180352
01/02/09 04:01 PM
01/02/09 04:01 PM
I still think something else is going on.SBC motors have a pretty good oiling system. The returns to the pan are good..How did the filter look? Have you cut it open? I have seen problems leading to galling of bearings due to a clog in : a filter or filter mounting pickup..just a thought..
#180353
01/02/09 04:27 PM
01/02/09 04:27 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
Excessive acids in the oil can cause the pocking evident in some of the photos. When the oil was drained what was its condition?
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#180354
01/02/09 04:39 PM
01/02/09 04:39 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
mostly in part that contamination,acids,fuel,antifreeze can and will cause the pocking and unraveling but the rods don't show much evidence.How tight was the main bearing clearence?Was there excessive end play?What about the line bore or crank run out?It's hard to tell from the pictures.Just my thoughts as to some of the maybe causes.
#180355
01/02/09 06:13 PM
01/02/09 06:13 PM
Posts: 128 Finland
mopster
Finland
You may be right, a lot of sbc engines are built with HV oil pumps and this isnīt a usual outcome. Filter is cut open and there was some minor particles in it, probably from the bearings, but it wasnīt clogged or anything.
[Re: B G Racing]
#180356
01/02/09 06:41 PM
01/02/09 06:41 PM
Posts: 128 Finland
mopster
Finland
mostly in part that contamination,acids,fuel,antifreeze can and will cause the pocking and unraveling but the rods don't show much evidence.How tight was the main bearing clearence?Was there excessive end play? What about the line bore or crank run out?It's hard to tell from the pictures.Just my thoughts as to some of the maybe causes.
Main bearing clearance .003" and rods .0025". This possibility of contamination is interresting, but should it show in rods as well as in mains? How about the brown colour, could contamination cause it, I thought that it must be heat causing it?
[Re: mopster]
#180357
01/02/09 10:37 PM
01/02/09 10:37 PM
sixpackbee
Western New York
Certain contaminants can cause lubricity problems. If the friction modifiers get compromised then excessive heat usually results. The pock marks can be caused by acids ect. which in turn lead to greater friction coefficients which lead over heated parts. It could be a situation of one thing causing two different appearances on the bearings for two different reasons. Was an oil change, brand change, performed recently? There are some oils that do not play well with others and can cause problems.
[Re: mopster]
#180359
01/03/09 05:07 AM
01/03/09 05:07 AM
B G Racing
Eighty Four, PA
The car was driven a few hundred miles with faulty powervalve. It was stuck open and consumed about 1/3 more fuel than usually. Could this contaminate oil badly enough to cause bearing failure?
[Re: mopster]
#180360
01/03/09 05:08 AM
01/03/09 05:08 AM
B G Racing
Eighty Four, PA
That info helps,and as Sixpakbee stated,something effected the lubricity of the oil.In this case more likely gas.The reason it is more prevalent on the mains is that the crank takes more constant loading and unloading as well as thrusting where as the rods more or less float on the crank journal and only recieve a load during compression strokes which is minimized and helped by the opposing piston and rod.
[Re: mopster]
#180361
01/03/09 11:46 AM
01/03/09 11:46 AM
torkrules
I'm neurotic
I'm neurotic
That could cause some bog problems. How do the cylinders/rings look? This usually gas washes the cylinders.
