Re: For the first time since 2011.............
[Re: moparguy7074]
#1797013
04/06/15 09:06 AM
04/06/15 09:06 AM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Check to make sure everything is tight in distributor. I had the same problem with mine, and screws in rotor were loose. Not saying that's the problem, but something to check.
I agree, I had the same issue. Also agree to take it over 3000 rpm and check it at total timing.
[Re: WILD BILL]
#1797014
04/06/15 10:33 AM
04/06/15 10:33 AM
BradH
What type of damper do you use?
What brand of timing chain set, too?
The damper is a Profesional Products.
I don't recall 100% on the chain but I think it's a Cloyes.
The outer ring of that damper would be my first suspect.
[Re: WILD BILL]
#1799772
04/09/15 09:49 PM
04/09/15 09:49 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Well, I went and borrowed Scott's dyno timing light as I knew it worked with my set up.
I didn't even get a chance to try it as I wanted to double check everything was put back together correctly after I took the drive gear out to prime it.
That when I saw the dist was not lined up and caused me to check the balancer. I can spin the outer ring by hand
I guess that explains the wandering timing
[Re: WILD BILL]
#1800043
04/10/15 03:51 AM
04/10/15 03:51 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Glad you found your problem Bill... bummer you have to buy a new balancer.. but at least it wont come flying off going down the track and maybe go flying through the hood
[Re: WILD BILL]
#1800746
04/10/15 11:49 PM
04/10/15 11:49 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Billy, great to see you on here. Congrats on making the decision to get backout. Great luck, see you soon. Thanks for all of your help when getting my truck worked on.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: WILD BILL]
#1800798
04/11/15 12:27 AM
04/11/15 12:27 AM
WILD BILL
BROOK PARK, OH
Thanks guys.
Rick, in case you were not aware, I don't work there anymore.
[Re: WILD BILL]
#1801299
04/11/15 10:06 PM
04/11/15 10:06 PM
WILD BILL
BROOK PARK, OH
Got it sorted out today. Put an ATI on it and the timing is rock solid even with my trusty old CM dial back light.
Now I just need to put the new belts in, wash it and the 2 Jrs. and get em loaded up.
[Re: WILD BILL]
#1801917
04/12/15 08:47 PM
04/12/15 08:47 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Good luck Bill, you are doing better than me.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
