Re: For the first time since 2011............. [Re: moparguy7074] #1797013
04/06/15 09:06 AM
04/06/15 09:06 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Check to make sure everything is tight in distributor. I had the same problem with mine, and screws in rotor were loose. Not saying that's the problem, but something to check.
I agree, I had the same issue. Also agree to take it over 3000 rpm and check it at total timing.
Re: For the first time since 2011............. [Re: WILD BILL] #1797014
04/06/15 10:33 AM
04/06/15 10:33 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What type of damper do you use?
What brand of timing chain set, too?
The damper is a Profesional Products.
I don't recall 100% on the chain but I think it's a Cloyes.
The outer ring of that damper would be my first suspect.
Re: For the first time since 2011............. [Re: WILD BILL] #1799772
04/09/15 09:49 PM
04/09/15 09:49 PM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
Well, I went and borrowed Scott's dyno timing light as I knew it worked with my set up.
I didn't even get a chance to try it as I wanted to double check everything was put back together correctly after I took the drive gear out to prime it.
That when I saw the dist was not lined up and caused me to check the balancer. I can spin the outer ring by hand eek
I guess that explains the wandering timing laugh2
Re: For the first time since 2011............. [Re: WILD BILL] #1799830
04/09/15 10:46 PM
04/09/15 10:46 PM
BradH Offline
BradH  Offline
I'll PM you the address where you can send my consulting & diagnostic fee.
Re: For the first time since 2011............. [Re: BradH] #1799832
04/09/15 10:49 PM
04/09/15 10:49 PM
BROOK PARK, OH
BROOK PARK, OH
I'll be sure to mail it off the next time I mail my membership fees for the board thumbs
laugh2
Re: For the first time since 2011............. [Re: WILD BILL] #1800043
04/10/15 03:51 AM
04/10/15 03:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad you found your problem Bill... bummer you have to
buy a new balancer.. but at least it wont come flying
off going down the track and maybe go flying through
the hood
wave
Re: For the first time since 2011............. [Re: WILD BILL] #1800121
04/10/15 11:08 AM
04/10/15 11:08 AM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
It's good to see you back Bill. Yep, a lot has changed and all the talk of new Mopar series meets has not materialized. There is no Mopar points series anymore, at least one that is local enough for us to attend regularly. The best part is that there are still some Mopar events and you'll still find the same good friends there. See you at the races!
Re: For the first time since 2011............. [Re: WILD BILL] #1800746
04/10/15 11:49 PM
04/10/15 11:49 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Billy, great to see you on here. Congrats on making the decision to get backout. Great luck, see you soon. Thanks for all of your help when getting my truck worked on.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: For the first time since 2011............. [Re: WILD BILL] #1800798
04/11/15 12:27 AM
04/11/15 12:27 AM
BROOK PARK, OH
BROOK PARK, OH
Thanks guys.
Rick, in case you were not aware, I don't work there anymore. wave
Re: For the first time since 2011............. [Re: WILD BILL] #1801299
04/11/15 10:06 PM
04/11/15 10:06 PM
BROOK PARK, OH
BROOK PARK, OH
Got it sorted out today. Put an ATI on it and the timing is rock solid even with my trusty old CM dial back light.
Now I just need to put the new belts in, wash it and the 2 Jrs. and get em loaded up. boogie
Re: For the first time since 2011............. [Re: WILD BILL] #1801345
04/11/15 10:56 PM
04/11/15 10:56 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
Glad your back buddy hope to cross paths with ya this year at some point👍🏻
Re: For the first time since 2011............. [Re: WILD BILL] #1801917
04/12/15 08:47 PM
04/12/15 08:47 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Good luck Bill, you are doing better than me.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
