78 power wagon lighting issue
#1796103
04/04/15 01:46 AM
04/04/15 01:46 AM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Ok. so for a while now Ive had issues with the bright lights, they would blink out every once in a while, but if I switched from dim to bright they would be ok for a lil bit. Well tonight the obvious happened.
BOOM, nothing, nada. no lights at all. Also no brake lights.
I have running lights, my trailer light work, but no headlights or brake light. THe dash lights work, and the bright light indicator works, but if I wiggle on the pull nob they blink out. I pulled the headlight switch down and it looks like pigeon poop on top of the switch, like the windshield is leaking water on it or something. I had a switch outa a 85 ramcharger, but the same happened, no headlights or brake lights.
Heres my question,,,,,
DO I have a deeper issue. I also swapped out my dimmer switch with the one in my parts ramcharger, and same thing happened.
Fuses are ok, etc, etc...
Oh it seemed like the lights got SUPER bright before this happened.
Any ideas??
Kasey
Re: 78 power wagon lighting issue
[Re: Moparnut426]
#1796105
04/04/15 09:35 AM
04/04/15 09:35 AM
Posts: 27,728 places
79powerwagon
places
I've several of these trucks, and like mentioned before, the headlight switch and floor dimmer switch are pretty weak. I would never perform a test with another old switch, only new ones, as they just aren't expensive. Also, the bulkhead connectors can be problematic. But the single best upgrade I've done to all of my trucks was to simply make a new, separate wiring harness to all of the lights that becomes a dedicated ground circuit, straight to the battery! The difference this makes is amazing! While you are at it, make sure all of the ground straps are still there, attached, and clean.
[Re: 79powerwagon]
#1796106
04/05/15 01:08 PM
04/05/15 01:08 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
my '79 did that. first oil the dimmer switch, sometimes they act up, and that will usually cure it. If the problems continues, try a new switch, but also check the bulkhead connector.
1981 Dodge D150 360 auto
[Re: savoy64]
#1796110
04/06/15 01:14 PM
04/06/15 01:14 PM
Moparnut426
maybe the short ruined the turn signal switch also---brake lights go through the turn signal too....
That could be, I know I have 12 volts at that white pin at column.
Thanks, Ill try that. Ive been staring at this since Friday night and my eyes and head hurt LOL Didn't even think of that.
KAsey
[Re: Moparnut426]
#1804356
04/15/15 06:42 PM
04/15/15 06:42 PM
Posts: 678 Marshall TX
Texas383
Marshall TX
Everytime that has happened on any Mopar I've owned I would replace the floor dimmer and it would always solve the problem.
1969 Y2 Super Bee 1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
[Re: Moparnut426]
#1805806
04/17/15 07:42 PM
04/17/15 07:42 PM
Moparnut426
OK, it ended up being melted wires, melted bulk head, 4 blown headlights, blown tail lamp, and a melted down turn signal switch. All happened at the same time!!!
It got a new dimmer switch, headlight switch, turn signal switch headlights, a tail lamp bulb, and some wires.
