9 in Rear,,,, what gear oil you using #1795430
04/03/15 11:10 AM
04/03/15 11:10 AM
Fla
birdboy Offline OP
birdboy  Offline OP
Fla
what weight oil are you using and is synthetic needed? 2-3 qts?
the more I deal with people the more I like my dog
Re: 9 in Rear,,,, what gear oil you using [Re: birdboy] #1795431
04/03/15 01:05 PM
04/03/15 01:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What is the car used for... my street 9" I run the
90-120 non syn... I might change over to the syn
this year since its broke in... this is a street/strip
car
Re: 9 in Rear,,,, what gear oil you using [Re: birdboy] #1795432
04/03/15 01:07 PM
04/03/15 01:07 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Nobody will answer your question. It will turn into a 9" vs Dana 60 battle.
If you like drag racing, support your local track.
Re: 9 in Rear,,,, what gear oil you using [Re: CHAPPER] #1795433
04/03/15 02:42 PM
04/03/15 02:42 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Speaking of that, I read Dana 60's require less oil.
Re: 9 in Rear,,,, what gear oil you using [Re: 451Cuda] #1795434
04/03/15 02:53 PM
04/03/15 02:53 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What this is moparts we only run dana 60's as they are the best rear ever made!!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 9 in Rear,,,, what gear oil you using [Re: birdboy] #1795435
04/03/15 02:54 PM
04/03/15 02:54 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Take a look at this. My 9" takes 2-1/4 2-1/2
http://goodsenseoil.com/G2457-GearOilWhitePaper.pdf
Re: 9 in Rear,,,, what gear oil you using [Re: birdboy] #1795436
04/03/15 03:24 PM
04/03/15 03:24 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: 9 in Rear,,,, what gear oil you using [Re: birdboy] #1795437
04/03/15 03:25 PM
04/03/15 03:25 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
85-140 and no synthetic here. 9" all the way here and have been 5.50s at 265 mph.
Re: 9 in Rear,,,, what gear oil you using [Re: 1967dartgt] #1795438
04/03/15 03:33 PM
04/03/15 03:33 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
I never said they were the best, those are your words. All I've ever done is promote them as a strong rear that can be built cheaply.
Re: 9 in Rear,,,, what gear oil you using [Re: birdboy] #1795439
04/03/15 03:35 PM
04/03/15 03:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Race car or street car?? AS for qty it will hold 2.5ish qts
Re: 9 in Rear,,,, what gear oil you using [Re: Al_Alguire] #1795440
04/03/15 03:42 PM
04/03/15 03:42 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I just run 80/90 synethic in my rear, but it has a spool.
Re: 9 in Rear,,,, what gear oil you using [Re: 1967dartgt] #1795441
04/03/15 06:50 PM
04/03/15 06:50 PM
Q
Quicktree Offline
Quicktree  Offline
Q
same here, doesn't matter who makes it. a rear is rear
Re: 9 in Rear,,,, what gear oil you using [Re: Quicktree] #1795442
04/03/15 07:07 PM
04/03/15 07:07 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
75/90 Royal Purple. 5 years down the track & my gears still look like new.
