Re: New 3:55 gears always howl. True or False? [Re: NOrrTH] #1795057
04/04/15 10:00 AM
04/04/15 10:00 AM
Georgia
Steve Bryant Offline
Georgia
False. My 8 3/4 3.55's sound exactly like my 3.23's sounded.
My E-Body car howls a little in 4th gear but that's my 4-Speed and not the rear end.
Re: New 3:55 gears always howl. True or False? [Re: moper] #1795058
04/04/15 11:11 AM
04/04/15 11:11 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Any gear can be noisey if there's a problem. Problems are not always with the gears themselves, or even from the chuck. But - if there are not other issues, and they are broken in proerly, no gear ratio in and of itself will be noisey.
The wrong pinon angle can cause a perfectly setup rear to howl.
Re: New 3:55 gears always howl. True or False? [Re: TJP] #1795059
04/04/15 04:25 PM
04/04/15 04:25 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
That's BS.
The gears aren't set up properly.
He's blowing smoke at you.
Need to find someone else that knows what they're doing, and talking about.
When i first started out as an auto mechanic, i worked at a shop doing differentials, here in my city.
The other common Fallacy is that the lower you go the more they will whine, BULLS$heet I say. I have run gear sets as low as 5:13's in a street car that were quiet as a church mouse. I've run 3:91's, 4:10's, 4:30's, 4:56's, 4:88's and 5:13's. ALL QUIET noise wise WHEN SET UP PROPERLY. IF one is talking about special RACE only sets that could be a different story.
And it is the same guys that can't get the gears to be quiet that can't get a 8.75 to last behind a slant 6. IT IS ALL IN THE SET UP!!!! Some guys break them time after time after time and say the rear is junk, then other guys set them up and they last for really long times. I am shocked at how many shops I have seen guy replace a pinion seal on a crush sleave rear and just tighten the nut with a big ole impact, there are not a lot of guys who reeeeeealy understand how to set up a hypoid gear.
Re: New 3:55 gears always howl. True or False? [Re: HotRodDave] #1795060
04/04/15 05:47 PM
04/04/15 05:47 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
That's BS.
You mean torque wrenches are not optional?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: New 3:55 gears always howl. True or False? [Re: astjp2] #1795061
04/04/15 11:11 PM
04/04/15 11:11 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I read in Mopar Action magazine that the Mopar engineers chose their ratios based on several factors. One was in relation to the amount of times the pinion gear intersected the same teeth on the ring gear. Please forgive my vague description here, but the theory was that the fewer times the same teeth touched each other, the longer lasting the gearset was by spreading out the wear and the load. This explains why the Mopars came with some ratios different than GM or Ford. Numbers like 2.71, 2.76, 2.93, 2.94, 3.91 were rarely seen outside of the Mopar brand. the 3.23 and 3.55 were more common ratios though. GM used them as well as some GM specific #s like 3.07, 3.08, 3.42 and 3.73.
Re: New 3:55 gears always howl. True or False? [Re: DaveRS23] #1795062
04/04/15 11:51 PM
04/04/15 11:51 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
There are particular gear sets than will be noisy, no matter the set-up. But that is more brand or batch specific, than ratio specific.
I agree with this. Most gears will not make much noise if set-up right. But I have seen some that make noise (not alot of noise but some) and they were done by good shops. Working for a Dodge dealer I can tell you I remember a truck that a customer complained the rear was noisey. It was a brand new truck with the new to Dodge "American Rear" and this was around 2005 to 2008 as I dont remember which year. I ended up replacing the ring and pinion and the pinion and carrier bearings as per the Mopar tech adviser and it was no different when I was done. And we had the proper tools for it since we were a Dodge dealer. It was not alot of noise as it was a small whine at about 55 mph. In fact most people would not even complain but this guy must have drove this speed alot. So in the long run Mopar had me replace the full drum to drum rear and recheck all the settings including pinion angle which made no difference as it still had some noise. I do believe the whine noise in the complete new unit did happen at a slightly lower speed. In the end the custumer was told that small whine is normal as it was and as I said most people like you all and me would have never even thought it was noisey enough to complain about. The guy took the truck happy with us as he saw me replacing the complete unit because the service manager brought him in the shop so he could see for himself we replaced the drum to drum unit. Ron
Re: New 3:55 gears always howl. True or False? [Re: 383man] #1795063
04/05/15 10:06 AM
04/05/15 10:06 AM
Enfield, Ct
Moe Offline
Moe  Offline
Enfield, Ct
My rear end builder says the Richmond gear sets like to howl. He uses US Gear only.
Re: New 3:55 gears always howl. True or False? [Re: Darryls-Demon] #1795064
04/05/15 11:19 AM
04/05/15 11:19 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I have a 3.55 gear set in my Challenger, every part is new and was bought from Doctor Diff and doe`s not howl at all.
I have 5000 miles on the setup.
Thats a nice challenger- or as young ones might say, Noice!!
Keep old mopars alive.
Re: New 3:55 gears always howl. True or False? [Re: 383man] #1795065
04/05/15 12:44 PM
04/05/15 12:44 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
They had to do this with my 03 Ram with the 9.25 SG. They rebuilt the original one with all new stuff and it still was noisy. It sounds like it was similar noise wise to yours and had the dealer not jerked me around on some other issues I would likely never have put in a claim, but...
So they dialed the case and found it was out of spec and ordered a new housing and filled it up with new parts. When I asked why they didn't just install a drop in complete unit, I was told that a drum to drum 9.25 wasn't available and they had to build them at the dealer from scratch. Sounded like a fairy tale to me but either way I had a new diff under my truck.
Of course they still managed to get into my wallet for a few hundred because the parking brake shoes were FUBAR and not covered under warranty. $125 a set for the shoes plus brake job labor now because that's a separate repair. I hate dealerships...
But the diff in mine is now silent.
Kevin
Re: New 3:55 gears always howl. True or False? [Re: Twostick] #1795066
04/05/15 04:37 PM
04/05/15 04:37 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
ok, so that exactly makes them howl? I have a set of 4:10 Richmond that howl like crazy. when everyone says they are not set up right, what is not right??
Re: New 3:55 gears always howl. True or False? [Re: NOrrTH] #1795067
04/05/15 05:14 PM
04/05/15 05:14 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
same person...one set howled like a banshee...second set was quiet as a SBD...
Re: New 3:55 gears always howl. True or False? [Re: Moe] #1795068
04/05/15 10:42 PM
04/05/15 10:42 PM
My rear end guy (decades of exp) said Richmond gears are "hard to setup" quote unquote
Re: New 3:55 gears always howl. True or False? [Re: RapidRobert] #1795069
04/06/15 01:18 AM
04/06/15 01:18 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I set up the Richmond 4.56s in my 8 3/4. Good pattern, took it for a short ride, let it cool 3 times. It said break them in 500 miles, I thought yeah ok, I can't resist that long. Plus drag cars don't do it, right? (They also don't drive on the street)
Layed into it 3rd gear from 30 mph and it got sideways hard. Gotta do it again. And again. And then it got noisy. They hum on the highway now, guess I'll be a good boy next time
Re: New 3:55 gears always howl. True or False? [Re: mikemee1331] #1795070
04/06/15 01:29 AM
04/06/15 01:29 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
ok, so what exactly makes them howl? I have a set of 4:10 Richmond that howl like crazy. when everyone says they are not set up right, what is not right??
I would think the checking depth on the pinion would be the problem. As to whether it is too deep or too shallow you can't see by simply looking at it.
As to how to get it out I don't think I would change the checking depth once the gears have been ran.
You can check the backlash and adjust it yourself with a dial indicator. I set the backlash years ago on one and never had an issue (removed an open carrier and installed a clutch pac)
I got a bad feeling the 391's I just set up are going to howl. I don't have them in yet and it may not be an issue but it was hinky trying to set the backlash...almost .003 difference measured on the ring gear at 4 different locations.
...FAFO...
Re: New 3:55 gears always howl. True or False? [Re: skicker] #1795071
04/06/15 05:59 AM
04/06/15 05:59 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Years ago I set up a set of 3.9 Richmond gears as a first try and they were quiet as can be.
Few years on, I reset the backlash on the gears and now they're noisy.
