Re: Key Off Battery Draw- 1971 Valiant [Re: 4speeds4me] #2235321
01/16/17 02:49 PM
01/16/17 02:49 PM
Round Rock, Tx
PlumCrazyChris Offline
Round Rock, Tx
Magnum,
Did you figure this one out? I seem to be having the same issue with the new mini starter on my Challenger. Battery draining after a couple days, as well as not fully charging while running. I've found voltage on the line that runs to the solenoid on my starter, which when unplugged from the starter relay, is shorted to ground at the starter. My friend measured his starter solenoid post and found 6 ohms through the windings to ground. Mine is a straight short.
What should the that reading be? Anyone else have any ideass?
Thanks,
Chris
VP of Mopar Muscle Cars of Austin
70 Challenger
www.mopar.org
Re: Key Off Battery Draw- 1971 Valiant [Re: PlumCrazyChris] #2235385
01/16/17 04:10 PM
01/16/17 04:10 PM
if the small (solenoid) terminal with the 11/32 nut on the starter is dead shorted to the starter case then the starter needs to come out. I'm assuming the large starter "batt" stud has no continuity to the starter case. we'll continue on for the draw that is running the batt down and why it ain't charging.
Re: Key Off Battery Draw- 1971 Valiant [Re: 4speeds4me] #2235476
01/16/17 05:55 PM
01/16/17 05:55 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Did you check the connector on the ignition switch where it plugs to the harness. I have seen them melted there a few times.
