Re: whats the largest valve lift with j heads and kb piston [Re: cheapstreetdustr] #2003153
02/01/16 01:45 AM
02/01/16 01:45 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline OP
i have bronze guides installed. ill have to pull I/E springs to see what i got going on.
thanks guys ill post when i get going on this. to bring this post to a conclusion.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: whats the largest valve lift with j heads and kb piston [Re: 65signet] #2003226
02/01/16 06:10 AM
02/01/16 06:10 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Originally Posted By 65signet
I have a .592/.610 lift solid cam with same pistons, and i am maxed out on valve lift, my piston sits .005 out to the hole. 360 with J heads
Can you tell me what head gasket thickness is?
