Re: zero oil pressure
[Re: Supercuda]
#1791319
03/30/15 10:43 PM
03/30/15 10:43 PM
RapidRobert
iirc someone mentioned that Lowes has a paint stirrer rod that is a 5/16" hex but it might not be long enough (iirc). If you have a junk intergear you can grind the teeth down on your bench grinder & the teeth are soft & grind down pretty fast. EDIT then a speed handle/screwdriver bit
[Re: mikemee1331]
#1791321
03/31/15 10:19 PM
03/31/15 10:19 PM
Posts: 65 WV
WV Runner
WV
They are Indy 440-sez. I pulled the distributor and the shaft, the shaft looks fine, Its not stripped. I had to order a priming shaft, I should have it tomorrow? I'm gonna prime the hell out of it and see what happens, I will let you guys know.
you are a patient man! I would been rigging up a cutoff screwdriver or something and really making a mess out of things! kudos for doing it the RIGHT way...
Thanks man! I love the car and hate when its broke, but its March still and I have a 2011 Challenger in the garage beside the Road Runner. Its not worth screwing up the motor up over. Sadly the priming rod didn't come to today, I checked the tracking number and I should have it tomorrow.
[Re: WV Runner]
#1791324
04/01/15 09:05 PM
04/01/15 09:05 PM
Posts: 5,170 CT
GTX MATT
CT
Usually only takes 10 seconds or so, but I've had it take closer to a minute. If nothing after a minute you've got an issue.
Try loosening the oil filter and priming it. You should get oil coming out of where the filter mounts.
[Re: GTX MATT]
#1791325
04/01/15 09:38 PM
04/01/15 09:38 PM
Posts: 65 WV
WV Runner
WV
I ran it for almost 2min earlier, I loosened the filter and primed and almost immediately oil started gushing out, I re-tightened it and started priming again and I got pressure, and at first it made a lot of bubbling sounds from air, but I got pressure now. Thanks Guys! Could it of been air in the pump of something like that? ![](/ubbthreads/images/graemlins/beer.gif)
[Re: WV Runner]
#1791326
04/02/15 03:50 PM
04/02/15 03:50 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Yep. Your pump wouldn't prime. It happens on occasion.
Good to know it was an easy fix.
