Re: Billet crank ?
[Re: dthemi]
#179096
12/31/08 01:50 PM
12/31/08 01:50 PM
Posts: 614 Michigan
Get-X
First I'd like to throw out the disclaimer; I'm, like most people, thrilled you're making a mopar specific line of parts, and they can't be beat for the money, no doubt.
Making big power with that type crank can obviouly be done and lots are. I know from experience in hundreds of cases, and it's no exaggeration that when you're in a thousand Hp range you can't compare a less expensive crank to a upper level crank over time. We've done literally hundreds of motors over the years for customers in that range and when we use inexpensive cranks they just don't hold up over time. Sure they'll make it right off the bat, but when you look at bearings between two similar HP engines, one with an inexpensive crank, and one with an expensive crank the effects are plain to see. I'm not crapping on your parts, just stating a proven fact. I would buy the best budget would allow for a crank, because in that area, (for me) the long term benefits out weigh the initial savings for that type power.
To ad to that, my 21 year old son is finally showing interest in cars, and we're talking about building a 500 inch motor together on the tightest budget we can just to see what we can get. My intentions are to use your parts and heads for his first build. I'm sure for the combo it will be more than respectable, and will live just fine at it.
You beat me to it. Sure, that thing made 1450 hp for a few dyno pulls, but what happens when it becomes two piece after 20 laps and destroys the block, the cam gets sawed in half and the heads get borked? Sorry, but I've seen firsthand what happens when a crank fails and it isn't pretty.
When MP was selling 1053 strokers people said the same thing until cranks started breaking and wiping out entire motors. We broke one in half in a S/C dragster that was a fairly mild build.
I'm not a rich guy and can't afford stupid mistakes with this motor. The consensus seems to be that I'm ok with a quality forging. I kinda knew that but was just looking for a few informed opinions.
Thanks again,
Marc
'65 Belvedere '68 GTX '57 Dodge pickup
Re: Billet crank ?
[Re: Get-X]
#179097
12/31/08 02:42 PM
12/31/08 02:42 PM
Posts: 746 Carson City, NV
440sourcedotcom
Carson City, NV
I can understand your concerns. Even though the engine in the December issue of Hot Rod was built many months ago, and has lasted quite a bit longer than "a few dyno pulls," I can see what you are saying. At the 1400+ horsepower level, it is possible there could be fatigue issues which can affect the long term lifetime expentancy of the parts. To be perfectly honest, we haven't had large numbers of people using our stuff which have had verified dyno results at the 1400+ horsepower range, so there is no fact based and verifyable evidence (supported by multiple builds) that I am aware of to prove yay or nay on this issue.
We have, however, had several dozens of people running our stuff at the 900-1000HP level for over 5 years. Every year these engines are torn down, cranks magged, etc, so at this level it is verifiable that fatigue is not an issue in terms of long term reliability. That's why we "officially" rate the cranks at 1000 horsepower.
Just something else to chew on. Appreciate everyone's objective input.
Re: Billet crank ?
[Re: 440sourcedotcom]
#179098
12/31/08 04:34 PM
12/31/08 04:34 PM
Posts: 622 sing sing
unknown
sing sing
Keep up the good work at 440 source, I have one of your 4.5 cranks going in my hemi for my street/strip duster. Im happy with it for the cost.
Re: Billet crank ?
#179099
12/31/08 06:24 PM
12/31/08 06:24 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
i am in the 900/1000 range and feel i got a good product for the build i had in mind. [440source]
Re: Billet crank ?
[Re: go green]
#179100
12/31/08 07:59 PM
12/31/08 07:59 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Billet crank for 1000 hp is a waist of money .
You can make 2500 hp with a forged crank easy.
hey! I have a billet crank for an 800hp motor
cost me $3641
Post deleted by Defbob
[Re: Defbob]
#179101
12/31/08 08:23 PM
12/31/08 08:23 PM
Re: Billet crank ?
[Re: Defbob]
#179102
12/31/08 08:35 PM
12/31/08 08:35 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
cost me $3641
And later if you decide to make 2800 HP you can use the same crank.
In all seriousness, were all very happy to have cranks in the range offered now. There are cranks for every need and budget now, thanks to companies like 440 source. I still think that 1000 HP motors need upper level cranks (just my opinion), but if it meant the difference between having a complete motor, or not because of budget I'd do what I had to. IMO it's never a waste of money, if it's available, to buy the best crank you can afford.
Re: Billet crank ?
#179104
01/01/09 07:30 AM
01/01/09 07:30 AM
Defbob
Norwich CT USA
cost me $3641
Well, now you have an excuse to put a 14-71 blower on top of that Hemi and make some real steam!
I do have the right compression for blown alcohol, but i don't think the pistons are up for it. I do think about a 14/71 all the time
Re: Billet crank ?
[Re: hemi-itis]
#179106
01/01/09 12:41 PM
01/01/09 12:41 PM
dthemi
back in Georgia
I'd rather have a cracked fuel crank than a new budget type crank in the power level we're talking about here. Bryant makes forged cranks for Ford and Chevy along with their billet line. I wish they'd make a forged line for Chrysler. The Ford and Chevy forgings are priced similar to Callies. I'm not trying to belittle bargain cranks at all, or in any way. I'm thrilled they're available. Engine Systems gets to build more engines as do most shops, because more people can afford the parts. We advise people that 8-900 HP should be the limit for these parts, and that's not far from where the manufacturers spec them. Most say a thousand. We use more Scat in that range, not because the material is any different than most of those guys use, but because the machine work is better, and that's more the problem to me. Also I would love to live in a 2" steel house if I could
Re: Billet crank ?
[Re: hemi-itis]
#179108
01/01/09 02:06 PM
01/01/09 02:06 PM
Posts: 200 AB
Efidart
AB
From what I was told......I thought a used Bryant fuel crank was good enough too.. But now I have a hole in the side of my KB block because of it.
A used up fuel crank would maybe be good to 5-600HP anything over that I would be scared. You should mag a crank like that and don't bet your engine on a tiny crack.
Ill have the engine out of the car soon so I can show you a 2 piece Billet crank.
I would rather run a 440 source forged crank at 1500HP then a cracked billet. At least you know it will bend before it will break in half.
My new crank is going to be a Callies magnum.. but thats $2000 rather then $599.. and they claim it will handle 1800HP without a problem.. and heres hoping.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
Re: Billet crank ?
[Re: hemi-itis]
#179110
01/01/09 02:38 PM
01/01/09 02:38 PM
Posts: 200 AB
Efidart
AB
Had it at 11 Lbs boost on pump gas and 1300~ RWHP when it let go. It worked for almost 2 years of street driving and the occasional race weekend before it broke in half on the chassis dyno.
The used crank I got for $1500 and was from a friend of mine who ran it in his funny car then had it X-Ray'd with no cracks. He was going to put it back in.. good thing he didn't.
It had a few runs on it which I thought wasn't used up at all, I was wrong.
Don't bet your engine on a cracked crank, they get rid of them for a reason. Sometimes you get lucky and don't have a problem... sometimes you dont!
Re: Billet crank ?
[Re: boatracer572]
#179112
01/01/09 04:17 PM
01/01/09 04:17 PM
Posts: 200 AB
Efidart
AB
Should have known better.. I should have bought a Callies or something along those lines for a little more money first off. At least the place it window'd the block is easily fixable or so it looks that way. I didn't expect that much HP when I first built the engine, thought it would be 1100~ RWHP on 11 lbs. Don Bailey knows his stuff when he helped me with the camshaft, I think hes the one partially to blame for the extra HP. . Buy a new billet or a good forged piece for anything 800HP and above if you want it to live. A billet is overkill for anything under 1000HP but it doesn't hurt anything besides the wallet. I'm envious of your heads! I spoke to Steve Gill at PRI and looked at the predators 1st hand, WOW! When I get up the cash and the guts to put a pair on, 530 CFM on the intake will be warmly welcomed, not to mention the exhaust.
Re: Billet crank ?
[Re: Defbob]
#179115
01/01/09 07:51 PM
01/01/09 07:51 PM
blownzoom440
ELYRIA,OH
hemi-itis, did your crank already have a standard snout? don't they usually have splined snouts?
that is my thaught,no keyway slot.
