Re: Crankshaft reuse? [Re: dvw] #1790562
03/31/15 07:11 PM
03/31/15 07:11 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Crank looks like the journal was welded. Those pits look like they're between the 2 rod journals.
Doug
That was my first impression.
Welded crank.
If you can swing it, go for the stroker.
The extra inches will drink a bit more fuel but will cover up the sound of a bigger cam. You can make your resto cruiser have a bit more bite with a mellow bark.
- Stu Harmon
Re: Crankshaft reuse? [Re: mr111] #1790563
03/31/15 07:27 PM
03/31/15 07:27 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
As for the crank being welded, highly unlikely, this isn't the only place this happens, there's another journal near it that has something similar. In the picture I posted, there's another small pit in the upper right hand corner. I just can't see someone welding this thing from twenty pieces.
Cranks are welded to repair them, not put them back together.
If someone chews up an engine badly the rods can grind heavily on the crank journals. Pitted bearings can catch debris and wear down the crank like sandpaper.
A crank grinder can take that beat up crank, weld a bunch of material on the bearing journals, and make them big and sloppily oversized. Then, he will turn the journals back down to the original size.
*POOF*
Now your chewed up worn out crank is back to it's original dimensions and good as new.
HOWEVER, if the welder isn't that good or doesn't take proper care the welds can be porous. When they grind them back down to original size it will expose the little pin holes and imperfections.
Those imperfections are what I see in that crank. They can be found anywhere across a welded journal.
Little particles of metal, carbon, or other debris can be carried by the oil and end up between the bearing and the crank. Little holes will catch the trash. That's where it starts chewing up the soft bearings.
That crank either needs to be offset ground (gets rid of the pits) or welded up and repaired again.
- Stu Harmon
Re: Crankshaft reuse? [Re: feets] #1790564
04/01/15 12:48 AM
04/01/15 12:48 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
I agree with Feets, that crank looks like it has been welded.
Re: Crankshaft reuse? [Re: MO_PA] #1790565
04/01/15 01:00 AM
04/01/15 01:00 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Have you tried to find a good 440 crank lately? They are few and far inbetween around here! Price a new one lately?
JB Rhinehart, Realist
A-Body's RULE!
Re: Crankshaft reuse? [Re: Rhinodart] #1790566
04/01/15 01:39 PM
04/01/15 01:39 PM
AndyF Offline
AndyF  Offline
I have several brand new 440 cast cranks sitting on the shelf. The forged cranks are a little harder to find. I just sold a std/std 440 forged crank to a guy who needed one for a truck motor.
Re: Crankshaft reuse? [Re: Rhinodart] #1790567
04/01/15 01:44 PM
04/01/15 01:44 PM
dogdays Offline
dogdays  Offline
Chrysler built 750,000 440s and who knows how many 413s. I have a hard time believing that someone would weld up two journals on a 440 crank. That'd have to cost more than the core charge for a different crank.
Crankshaft welding is done by the submerged arc process and it produces a very good result. Heck, any weld is expected to not have porosity. It is not, as some posters imply, inevitable that a weld will have voids.
Any certified welder should be able to produce a weld with no voids using a flux coated welding rod, commonly called stick welding.
I mean really, I am far from certified but my stick weld samples passed guided bend tests. Chip off the slag and get enough penetration on the next pass to melt out any unseen slag inclusions.
My other clue is that the pits occurred in a line and not spread randomly over the surface.
My best guess is some sort of acidic material attack on the uncovered parts of the crank journal. I have seen pitting like that in an engine that blew a head gasket and got antifreeze in the cylinders, where it turned into something acidic, possibly glycolic acid. Boring the cylinders 1/2 mm, or 0.020", didn't get to the bottom of the pits, but it got close. The dark spots at the bottom of the pits were still visible after boring.
R.
Re: Crankshaft reuse? [Re: dogdays] #1790568
04/01/15 06:44 PM
04/01/15 06:44 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Nobody knows the history of this crank. It would have been welded by a hack.
Personally, I prefer spray welding shafts instead of stick or mig.
It's a good idea to have any welded crank heat treated after welding.
- Stu Harmon
