6.4 Hemi in my Cuda? #1790409
03/28/15 06:25 PM
03/28/15 06:25 PM
SO CAL
BB70DUSTER Offline OP
SO CAL
I know its been beat to death, but I can't find a simple straight answer... I have a 71 Cuda, and a 6.4 Hemi crate engine, engine is a 2011 Challenger engine with the plastic intake, what do I need to change at minimum cost to run this? I have a small block 833 trans Ill be running... Not opposed to swapping to a carburetor if it saves me money.
Re: 6.4 Hemi in my Cuda? [Re: BB70DUSTER] #1790410
03/28/15 07:24 PM
03/28/15 07:24 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
There is a Fast N Loud episode on Monday installing one in a 71 Challenger.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: 6.4 Hemi in my Cuda? [Re: Savoy1964] #1790411
03/28/15 08:28 PM
03/28/15 08:28 PM
SO CAL
SO CAL
no thanks... TV is just that...
Re: 6.4 Hemi in my Cuda? [Re: BB70DUSTER] #1790412
03/28/15 09:36 PM
03/28/15 09:36 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
you would need a controller. , 6.1 intake and have it CNC to fit 6.4, fuel rails for 6.1, ATI Super Damper is recommended, and Ported 87mm throttle body.
Re: 6.4 Hemi in my Cuda? [Re: Savoy1964] #1790413
03/28/15 10:08 PM
03/28/15 10:08 PM
SO CAL
SO CAL
Why a 6.1 intake?
Re: 6.4 Hemi in my Cuda? [Re: BB70DUSTER] #1790414
03/28/15 10:46 PM
03/28/15 10:46 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Why a 6.1 intake?
I believe it has something to do with the fuel system or the fuel rails. The other alternative is finding an early 5.7L intake from a car.
As far as swapping, the typical off the top of my head... TTi mounts, TTi headers, a fuel management system, a small block bellhousing, and a special clutch (idk who makes one).
Re: 6.4 Hemi in my Cuda? [Re: MuuMuu101] #1790415
03/28/15 11:35 PM
03/28/15 11:35 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
6.4 intake has a computer controlled runner that no one has a controller for.
Re: 6.4 Hemi in my Cuda? [Re: Savoy1964] #1790416
03/29/15 12:06 AM
03/29/15 12:06 AM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
Re: 6.4 Hemi in my Cuda? [Re: Savoy1964] #1790417
03/29/15 12:06 AM
03/29/15 12:06 AM
SO CAL
SO CAL
if I'm reading right that just takes a Rpm activated switch to control it?
Re: 6.4 Hemi in my Cuda? [Re: Chally426] #1790418
03/29/15 12:08 AM
03/29/15 12:08 AM
SO CAL
SO CAL
Re: 6.4 Hemi in my Cuda? [Re: Chally426] #1790419
03/29/15 12:12 AM
03/29/15 12:12 AM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
There's been a lot of 6.4's installed in the older cars
Re: 6.4 Hemi in my Cuda? [Re: BB70DUSTER] #1790420
03/29/15 12:21 AM
03/29/15 12:21 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Pretty sure you could use the 6.4 intake. The biggest thing will be finding a controller to deal with the VVT. You could lock out the cam and use almost any controller, but the VVT is worth power. Also it has a variable runner intake, but it just needs a 12V source hooked to an RPM switch to activate it when you want. The guys on the LXForums seem to set it at 4400ish RPM when they do the swap onto a 5.7.
I think MS3 is able to control the VVT now. HotWire also sells swap kits for the electronic side using factory parts
Re: 6.4 Hemi in my Cuda? [Re: WO23Coronet] #1790421
03/29/15 12:28 AM
03/29/15 12:28 AM
SO CAL
SO CAL
I know it kinda defeats the purpose, but can the 6.4 be carbureted?
Re: 6.4 Hemi in my Cuda? [Re: BB70DUSTER] #1790422
03/29/15 02:17 AM
03/29/15 02:17 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I'm sure it could but then you'd have to do ignition still. A dragpack intake is a good intake
Re: 6.4 Hemi in my Cuda? [Re: WO23Coronet] #1790423
03/29/15 02:40 AM
03/29/15 02:40 AM
SO CAL
SO CAL
Ignition was my concern... The Msd box only shows for a 5.7
Re: 6.4 Hemi in my Cuda? [Re: BB70DUSTER] #1790424
03/29/15 03:16 AM
03/29/15 03:16 AM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Holley now makes a full wiring harness and computer for swapping anything from a 5.7 to a 6.4 fairly "easy".
http://www.hotrod.com/features/1501-hemi-engine-swaps-made-simple-with-new-holley-efi-harness/
Ryan
Re: 6.4 Hemi in my Cuda? [Re: Devil] #1790425
03/29/15 01:46 PM
03/29/15 01:46 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Do not fall into the "this is an easy swap" mentality. There are so many computer issues depending on which engine, trans, instruments, etc you can easily end up spending many times more than you planned. I HIGHLY suggest you talk to Dave at Modern Muscle at the very least. He does this every day across many combinations of platforms. It will NOT be cheap no matter what you think. The least expensive way is to get the info up front and proceed accordingly.
Sure, there is a lot of info about how to make it all fit...that is the EASY part!
Been there and done all of that and that is where I am coming from. The computer issue is huge on these swaps particularly when you don't have it figured out up front. Progress is being made daily on making these swaps easier.
Driving modern convenience in classic beauty
Re: 6.4 Hemi in my Cuda? [Re: Darius] #1790426
03/29/15 01:53 PM
03/29/15 01:53 PM
SO CAL
SO CAL
Thats why I keep thinking a carburetor may be the way to go... I have a 6 speed auto for it too, but already decided to stick with my 4 speed... Does anyone know if there is a ignition controller to run a carb on this thing???
Re: 6.4 Hemi in my Cuda? [Re: BB70DUSTER] #1790427
03/30/15 12:46 PM
03/30/15 12:46 PM
SO CAL
SO CAL
Anyone?
Re: 6.4 Hemi in my Cuda? [Re: BB70DUSTER] #1790428
03/30/15 01:07 PM
03/30/15 01:07 PM
GA
roadrunninMark Offline
GA
What about using the factory computer(s) to control it? I would think that would be an easier place to start, plus cheaper when you buy a whole wrecked car. Does someone have access to the programming to remove programming you don't need (like cats, etc)?
