I thought I had posted to this issue but I do not see it in the thread. The factory large amplifier gets its power from the control radio. The adaptor cables for factory replacement have a wire to furnish this power but it is mislabeled "Power Antenna" feed. It is usually a blue wire. If this wire is not connected, the amplifier will not work. Make sure this blue wire is connected and has power on it. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
