Re: Rear body&frame improvements
[Re: mopardude318]
#1784749
03/24/15 04:14 PM
03/24/15 04:14 PM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
PLEASE make one for an A-body! I'd buy one! And please don't say an A-body is not worthy! Then We are our own worst enemy
We can always do a one off and if there is enough excitement about the B&E, the boss will have me prototype stuff for the A's. I think that the construction for the A bodies may be a bit tougher as the pin-style upper mounts would be tricky. I've had to repair one of those that blew out from air shocks once. Super not-fun.
[Re: Dan@Hotchkis]
#1784750
03/24/15 04:25 PM
03/24/15 04:25 PM
Posts: 701 Northern California
lilcuda
Northern California
Do you have subframe connectors on the car? If not, I would start there.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: BigBlockMopar]
#1784752
03/24/15 10:21 PM
03/24/15 10:21 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Yes, frame connectors are present. Welded front and rear, but plan to weld them to the floors as well.
before you do, check the rules of the track you wanna run at, some classes don't allow you to weld to the floor plan, or you get bumped to a class you probably don't want to be in.
[Re: Dan@Hotchkis]
#1784753
03/24/15 11:28 PM
03/24/15 11:28 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
[/url]
We've done initial testing on 68-72 B Bodies and E Bodies. Works great so far.
Probably a stupid question, but what are the large circles for near the ends? Modular frame mounts of some sort?
[Re: GoodysGotaCuda]
#1784754
03/25/15 12:05 AM
03/25/15 12:05 AM
Dan@Hotchkis
Current design allows a full TTI 3" system on all platforms.
[Re: BigBlockMopar]
#1858811
06/28/15 11:34 AM
06/28/15 11:34 AM
Posts: 679 Los Osos, Ca
CKessel
Los Osos, Ca
Looks like typical old car stuff. As you do your repairs, are you putting in any anti rust treatments to the new and old exposed areas? Body cavity wax etc? Would be a good idea.
Carl Kessel
