Ignition controler 6.1 Gen111 #1783814
03/19/15 05:42 PM
03/19/15 05:42 PM
Denison,Ia.
Cuda367 Offline OP
Cuda367  Offline OP
Denison,Ia.
Need an ignition controller for a 6.1. MSD only list for 5.7 and the fast unit is more for EFI than carb. What are you guys using? I believe just changing the reluctor wheel would alow the msd to work on the 6.1. Has anybody tried to change them? Any problems?
Re: Ignition controler 6.1 Gen111 [Re: Cuda367] #1783815
03/19/15 06:20 PM
03/19/15 06:20 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The FAST unit in stand-alone mode works fine with a carb.
Done several.
Re: Ignition controler 6.1 Gen111 [Re: Mopar_Rich] #1783816
03/19/15 10:11 PM
03/19/15 10:11 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
The Hemi 6 controller from MSD can work both 5.7 and 6.1. There is a jumper loop in the harness that you either leave in tact or cut, depending on engine. The instructions are available on line from MSD. I know this works for a fact. I am running a Hemi 6 controller in a 5.7 right now that was previously used on a twin turbo 6.1 Jeep.
[image][/image]
Re: Ignition controler 6.1 Gen111 [Re: sgcuda] #1783817
03/19/15 11:32 PM
03/19/15 11:32 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
I run a late 5.7 MSD controller on my 2010 6.1 crate motor.
The only thing not compatible was the crank and cam sensor plugs - so I changed the sensors to 5.7 ones.
Works perfectly.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Ignition controler 6.1 Gen111 [Re: Moparmal] #1783818
03/20/15 12:46 AM
03/20/15 12:46 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I'm here scratching my head wondering what the difference is between a 5.7 & 6.1 than cu. in. ?? the connections?
Re: Ignition controler 6.1 Gen111 [Re: cudaman1969] #1783819
03/20/15 12:55 AM
03/20/15 12:55 AM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
Yes it is pretty much just the connections as far as hooking up the MSD..
Re: Ignition controler 6.1 Gen111 [Re: cudaman1969] #1783820
03/20/15 10:45 AM
03/20/15 10:45 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Yes. Different wiring harnesses for the different type of coil packs for 5.7 and 6.1's.
Re: Ignition controler 6.1 Gen111 [Re: STEFF] #1783821
03/21/15 11:11 PM
03/21/15 11:11 PM
sgcuda Offline
sgcuda  Offline
The coil connectors are different, but the hidden difference between the early 5.7 and the 6.1 is the crankshaft tone wheel. That is why the loop wire on the harness has to be either cut or intact, depending on which tone wheel is being used. The later 5.7's ( with same coil setup as 6.1 ) use the same tone wheel as the 6.1. That being said, I don't know what kind of tone wheel is used on the 6.4 or the 6.2 Hellcat engine.
[image][/image]
Re: Ignition controler 6.1 Gen111 [Re: cudaman1969] #1783822
03/22/15 05:03 AM
03/22/15 05:03 AM
Moparmal Offline
Moparmal  Offline
Like I said...I used the later 5.7 harness on my 6.1
The only issue was the crank and cam sensor clips - everything else was plug and play
Re: Ignition controler 6.1 Gen111 [Re: sgcuda] #1783823
03/22/15 12:09 PM
03/22/15 12:09 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
All 5.7 from 08 and down and all 6.1 have the same reluctor wheel. (Toner Wheel)32 teeth IIRC
The only difference in the two are the 5.7 has three bolts holding it on the crank and 6.1 has 4 bolts.
All 09 and up 5.7 6.4 and 6.2 have a reluctor wheel with 64 teeth. I know the 6.4 has 4 bolts holding it to the crank. I'm assuming the rest have the same.
I BELIEVE the only difference in the MSD wiring harness has to do with the early 5.7 with the crossover ignition wire and the 06 and up coil on plug wire. If you have the early version of 5.7 you can easily convert it to the later version.
So long story short buy the later version and convert if you need too.
Matt
