Re: Help me decide Holley 650 or 750 [Re: twister360] #178314
12/30/08 08:37 AM
12/30/08 08:37 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
The 750 will work fine but if the car is mostly a street car the 650 would be a better choice. I have a 360 with pretty much the same build (a little less cam) and have had 600, 670, 725 and 750 carbs on it. In order of preference its the 670, 600, 750 and 725.
Getting back to your rich mixture at idle. What is your initial timing? You should have between 15 and 20 degrees BTDC with the cam you are using. The magnum heads like less (32-34) total timing than open chamber heads.
With the overlap in the cam you are using the cylinders are not filling very efficiency at idle and you need to start the fire earlier to ensure all the mixture is burnt. Advance the initial timing in small increments until you get max manifold vacuum. You will then need to limit the timing in the distributor to keep the 32-34 number. If you have a MP distributor or an aftermarket one then you it will be easy.
Remember the first step in dialing in a carb is to get the timing right.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Help me decide Holley 650 or 750 [Re: dgc333] #178315
12/30/08 12:29 PM
12/30/08 12:29 PM
Houma, Louisiana
twister360 Offline OP
Houma, Louisiana
I think I'll stay with the 750 and try and fine tune it next week when I have some free time. Thanks for all the help.
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: Help me decide Holley 650 or 750 [Re: YO7_A66] #178316
12/30/08 01:05 PM
12/30/08 01:05 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
If you buy a double pumper, go for the 650 because:
1 They're cheaper
2 they have the same baseplate as a 750
3 if you need more carb at a later date, buy the
new ported main body.
