Help me decide Holley 650 or 750 #178294
12/29/08 07:35 PM
12/29/08 07:35 PM
Houma, Louisiana
twister360 Offline OP
Houma, Louisiana
Currently I have a built 360 Magnum motor in my 74 Duster. I have Magnum heads that have been mildly ported, a Comp Cam with 230* intake and 236* exhaust at .050 amd .544 lift on intake and .555 on exhaust,RPM air gap dual plane intake, with a Holley 3310 750 CFM vaccuum secondaries. The car has a 3200 stall converter in a 904 with TCI shift kit and a fresh rebuild of tranny,and 3.91 gears in a SG 8 1/4 rear end and Mickey Thompsons 275x60x15 ET street radials.
My problem is that the carb seems too rich. This combo was dynoed at 400 HP / 410 torque at the flywheel, but once installed in the car, there seemed to be too much fuel and has a strong smell of gas.
Is this too much carb for the motor? I have some that tell me to go to a Holley 4777 650 CFM, and the car will get better gas mileage and be faster at the track.
Which carb would you run and why? Thanks Moparts
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: Help me decide Holley 650 or 750 [Re: twister360] #178295
12/29/08 07:46 PM
12/29/08 07:46 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
check your vacuum ...and then check your power valve in the holley...
also...adjust your idle mixture screws..
check your float levels too...
i have a similar cam in my 73 duster and it runs great with a 750 vacuum holley..
Tony
70 AARCuda Vitamin C
Re: Help me decide Holley 650 or 750 [Re: twister360] #178296
12/29/08 07:50 PM
12/29/08 07:50 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Sounds like you have a carb. problem but it has nothing to do with the carb. size. Keep the 750 and fix/tune it.
Re: Help me decide Holley 650 or 750 [Re: 70AARcuda] #178297
12/29/08 08:19 PM
12/29/08 08:19 PM
Houma, Louisiana
Houma, Louisiana
I have checked the power valve and it is okay. Where should the level be in the bowls? What should I look for when checking the vaccuum? Where is a good starting point on the mixture screws? Thanks for the info.
Re: Help me decide Holley 650 or 750 [Re: twister360] #178298
12/29/08 08:25 PM
12/29/08 08:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
check the vacuum..where the power brakes or pvc on the carb is...
u want to compare that with the power valve..u dont want the power valve opening to early cause that dump extra gas into the carb..
float level should be at the lower edge of sight hole in side of bowl..
Tony
Re: Help me decide Holley 650 or 750 [Re: 70AARcuda] #178299
12/29/08 08:30 PM
12/29/08 08:30 PM
adjust mixture screws 1/4 turn at a time for highest vacuum. then reset idle speed
Re: Help me decide Holley 650 or 750 [Re: twister360] #178300
12/29/08 08:33 PM
12/29/08 08:33 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
what jets sizes are you running ?
check your float levels-with the engine idling gas should barely trickle out the bowl side screws
Re: Help me decide Holley 650 or 750 [Re: twister360] #178301
12/29/08 08:46 PM
12/29/08 08:46 PM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
I have your twin...
I have a 360 Magnum in my '71 Demon. Stock bottom end with a 226/238 @ .050" with .520" lift. Eddy Air-gap intake, 727 with ~3500 converter and 3.91s. My best is 12.76 @ 104 mph. I am currently running an Eddy 650 right out of the box. I never even touched the idle screws. With that said, I am considering going to a 750.
Re: Help me decide Holley 650 or 750 [Re: twister360] #178302
12/29/08 08:49 PM
12/29/08 08:49 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""I have checked the power valve and it is okay.""
What is your in-gear vacuum reading with your foot on the brake (like you are at a stop sign)?
What number is your power valve?
Re: Help me decide Holley 650 or 750 [Re: twister360] #178303
12/29/08 08:50 PM
12/29/08 08:50 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I ran a holley 750DP on a mild 340 (stock 340 cam) w/ zero problems. It had great throttle response and I got 17mpg hwy... I would think a 650 might be too small for your application. The 750 vacuum is ok but it will require tuning as does any holley. If it were my car I'd probably get a used 750 DP, rebuild it and start w/ 72/80's a 6.5PV and 28 squirters...
FWIW, My 72 swinger had an almost stock 340, headers, J-heads and a holley 750 DP. It ran 13.80's on street radials and 3.55 rear.
Re: Help me decide Holley 650 or 750 [Re: Mr.Yuck] #178304
12/29/08 09:43 PM
12/29/08 09:43 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the holley 3310 750 vacuum holley is an universal carb...it will need some tuning to make it work..and it will work great...
just need to check what number power valve u got...it needs to be something around a 6.5...and adjust the idle mixture...
the jetting will be close..
my 73 duster ran 3 tenth quicker will a 750 dp then the 750 vacuum...but driving every day i run the vacumm carb..
Tony
Re: Help me decide Holley 650 or 750 [Re: 70AARcuda] #178305
12/29/08 10:15 PM
12/29/08 10:15 PM
Houma, Louisiana
Houma, Louisiana
The power valve is 6.5. If the vac drops below 6.5 will this cause the PV to open? Where would I find step by step directions for setting this carb? Thanks
Re: Help me decide Holley 650 or 750 [Re: twister360] #178306
12/29/08 10:17 PM
12/29/08 10:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
try holley's web site. I'm sure they have step by step instructions.
Re: Help me decide Holley 650 or 750 [Re: twister360] #178307
12/29/08 10:18 PM
12/29/08 10:18 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
It sounds like the same problem I used to have with my Holley. If it has front and rear mixture screws, adjust them in all the way, then adjust out one full turn. Start the car and see how it idles and if there is still a rich gas smell. Make small adjustments to each one until the idle speed increases which means you are leaning out the mixture.
Re: Help me decide Holley 650 or 750 [Re: Dave Watt] #178308
12/29/08 10:38 PM
12/29/08 10:38 PM
Houma, Louisiana
Houma, Louisiana
Thanks for all the help. What is the purpose of the PV and how does it operate? If manifold pressure drops to a certain point, will the PV open? The last time I checked my manifold pressure it was above 10 inches at idle. Don't know what it would be at WOT or part throttle.
Re: Help me decide Holley 650 or 750 [Re: twister360] #178309
12/29/08 10:43 PM
12/29/08 10:43 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
AT WOT it should be ZERO... usually you set your PV from idle vacuum.
Re: Help me decide Holley 650 or 750 [Re: Mr.Yuck] #178310
12/29/08 10:52 PM
12/29/08 10:52 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
behind the power valve is two small passages that provide additional fuel as a power enrichment circuit...
if u floor the gas....vacuum drops to zero...power valve opens and provides additional gas...
most holleys with two metering block in them ...the primaries will be about 8 to 10 jets leaner then the secondaies.
the pvrc provides that additional fuel....so u can cruise on a leaner mixture...then get more gas went u floor it...
Tony
Re: Help me decide Holley 650 or 750 [Re: 70AARcuda] #178311
12/29/08 10:53 PM
12/29/08 10:53 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.mortec.com/carbtip1.htm
scroll down the page...has info on power valves.
Tony
Re: Help me decide Holley 650 or 750 [Re: 70AARcuda] #178312
12/29/08 10:56 PM
12/29/08 10:56 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
Re: Help me decide Holley 650 or 750 [Re: twister360] #178313
12/30/08 07:30 AM
12/30/08 07:30 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""The last time I checked my manifold pressure it was above 10 inches at idle.""
Was this in neutral or in gear idle?
If you have an automatic, you can tune the carb to get it close in N, but then you need to finish tuning it with the car in gear and a vacuum gage hooked up.
