Page 3 of 4 1 2 3 4
Re: R block cam Journal question [Re: RAY1969CARS] #1782240
03/20/15 11:31 PM
03/20/15 11:31 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
No they don't.
Re: R block cam Journal question [Re: RAY1969CARS] #1782241
03/21/15 12:20 AM
03/21/15 12:20 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Comp also has 1.998 babbit core for flat tappet 48's, used by dirt guys..they quoted me about $100 for a ugl.
Re: R block cam Journal question [Re: Hot 340] #1782242
03/21/15 12:48 AM
03/21/15 12:48 AM
CA.
RAY1969CARS Offline OP
CA.
I need a solid roller
Re: R block cam Journal question [Re: RAY1969CARS] #1782243
03/21/15 12:56 AM
03/21/15 12:56 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Bullet had 30 of those in stock last I talked to them. Callies cores I think
Re: R block cam Journal question [Re: Hot 340] #1782244
03/21/15 01:50 AM
03/21/15 01:50 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Comp had no solid roller 1.998 cams, bullet didn't have any either. I believe bullet should have some now. Predator cams had 200 cores this last summer when I got mine.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: R block cam Journal question [Re: 1967dartgt] #1782245
03/21/15 10:05 AM
03/21/15 10:05 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
The guy at bullet told me they have a supplier now, when they run out they get a bunch more. Pretty sure the supply problem is diminished for these.
Re: R block cam Journal question [Re: Hot 340] #1782246
03/21/15 10:51 AM
03/21/15 10:51 AM
CA.
CA.
I be leave so dam cam cores
Re: R block cam Journal question [Re: Hot 340] #1782247
03/21/15 04:03 PM
03/21/15 04:03 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes predator cams is the supplier for bullet, the reason he had 200 of them he supplies a few cam grinders. I don't know where he gets his cores made, and wish he would get one with more lobe separation.
Re: R block cam Journal question [Re: 1967dartgt] #1782248
03/21/15 04:09 PM
03/21/15 04:09 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
for some reason I seem to remember Callies coming up in the conversation. Maybe I'm wrong.... still confuses the ever lovin s##t out of me
Re: R block cam Journal question [Re: 1967dartgt] #1782249
03/21/15 04:12 PM
03/21/15 04:12 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Steve Overmier at Callies told me they make cores, not sure if they make them for Predator, but pretty sure he said they make them for Bullet. It was a while ago.
Re: R block cam Journal question [Re: J_BODY] #1782250
03/21/15 09:50 PM
03/21/15 09:50 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
they do they had 8 instock when i got mine ,110 l/c
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: R block cam Journal question [Re: Ian] #1782251
03/27/15 06:05 PM
03/27/15 06:05 PM
CA.
CA.
Can anybody tell me the OD of the Babbitt bearing 50mm and the OD of the cage of the needle bearing housing ? 50mm
Re: R block cam Journal question [Re: Ian] #1782252
03/27/15 07:13 PM
03/27/15 07:13 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have a 112 but would love more.
Re: R block cam Journal question [Re: 1967dartgt] #1782253
03/28/15 12:05 AM
03/28/15 12:05 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
specs . (Pic)
Re: R block cam Journal question [Re: Hot 340] #1782254
03/28/15 12:54 AM
03/28/15 12:54 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
specs . (Pic)
That's the core I have, only has a 106 intake lobe. Can't do that much with that.
Re: R block cam Journal question [Re: 1967dartgt] #1782255
03/29/15 06:24 AM
03/29/15 06:24 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
specs . (Pic)
110 l/c you could go 2 degrees wider may be 3 depending on profile
Re: R block cam Journal question [Re: RAY1969CARS] #1782256
03/30/15 01:49 AM
03/30/15 01:49 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
The cam tunnel bore in the block for the 50mm needle bearing is 2.2820-2.2826
Re: R block cam Journal question [Re: SB412DUSTER] #1782257
03/30/15 02:35 AM
03/30/15 02:35 AM
CA.
CA.
Thanks bro
Re: R block cam Journal question [Re: Ian] #1782258
03/30/15 12:04 PM
03/30/15 12:04 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
specs . (Pic)
Yes made 112 out of it, buts thats it. Need to do custom core for more.
Re: R block cam Journal question [Re: RAY1969CARS] #1782259
03/30/15 12:07 PM
03/30/15 12:07 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I will measure the OD of the babbit when they get here. The block is at machine shop now.
Page 3 of 4 1 2 3 4
