Re: R block cam Journal question
[Re: Hot 340]
#1782242
03/21/15 12:48 AM
03/21/15 12:48 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
Comp also has 1.998 babbit core for flat tappet 48's, used by dirt guys..they quoted me about $100 for a ugl.
I need a solid roller
[Re: RAY1969CARS]
#1782243
03/21/15 12:56 AM
03/21/15 12:56 AM
Posts: 3,397 Pa
Hot 340
Pa
Bullet had 30 of those in stock last I talked to them. Callies cores I think
[Re: Hot 340]
#1782244
03/21/15 01:50 AM
03/21/15 01:50 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Comp had no solid roller 1.998 cams, bullet didn't have any either. I believe bullet should have some now. Predator cams had 200 cores this last summer when I got mine.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1782245
03/21/15 10:05 AM
03/21/15 10:05 AM
Posts: 3,397 Pa
Hot 340
Pa
The guy at bullet told me they have a supplier now, when they run out they get a bunch more. Pretty sure the supply problem is diminished for these.
[Re: Hot 340]
#1782246
03/21/15 10:51 AM
03/21/15 10:51 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
I be leave so dam cam cores
[Re: 1967dartgt]
#1782249
03/21/15 04:12 PM
03/21/15 04:12 PM
Posts: 3,397 Pa
Hot 340
Pa
Yes predator cams is the supplier for bullet, the reason he had 200 of them he supplies a few cam grinders. I don't know where he gets his cores made, and wish he would get one with more lobe separation.
Steve Overmier at Callies told me they make cores, not sure if they make them for Predator, but pretty sure he said they make them for Bullet. It was a while ago.
[Re: J_BODY]
#1782250
03/21/15 09:50 PM
03/21/15 09:50 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
for some reason I seem to remember Callies coming up in the conversation. Maybe I'm wrong.... still confuses the ever lovin s##t out of me
they do they had 8 instock when i got mine ,110 l/c
[Re: 1967dartgt]
#1782253
03/28/15 12:05 AM
03/28/15 12:05 AM
Posts: 3,397 Pa
Hot 340
Pa
I have a 112 but would love more.
specs . (Pic)
[Re: 1967dartgt]
#1782255
03/29/15 06:24 AM
03/29/15 06:24 AM
Ian
Victoria, Australia
specs . (Pic)
That's the core I have, only has a 106 intake lobe. Can't do that much with that.
110 l/c you could go 2 degrees wider may be 3 depending on profile
[Re: RAY1969CARS]
#1782256
03/30/15 01:49 AM
03/30/15 01:49 AM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
Can anybody tell me the OD of the Babbitt bearing 50mm and the OD of the cage of the needle bearing housing ? 50mm
The cam tunnel bore in the block for the 50mm needle bearing is 2.2820-2.2826
[Re: SB412DUSTER]
#1782257
03/30/15 02:35 AM
03/30/15 02:35 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
Thanks bro
