Re: R block cam Journal question
[Re: RAY1969CARS]
#1782201
03/17/15 08:13 PM
03/17/15 08:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Can a Standard step journal be machined out to a 50 mm ???
Sorry.. I was gonna get back with you but I havent found my stock cam yet
[Re: MR_P_BODY]
#1782202
03/17/15 08:16 PM
03/17/15 08:16 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
no worries bro
[Re: RAY1969CARS]
#1782203
03/17/15 10:18 PM
03/17/15 10:18 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I do not believe so, I think they measure 52 mm.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: mr_340]
#1782205
03/18/15 01:17 PM
03/18/15 01:17 PM
MR_P_BODY
Are you talking about the block or the cam?
The cam itself... does anyone know what size the large journal is on a stock cam... I looked but cant find the spec
[Re: mr_340]
#1782207
03/18/15 01:47 PM
03/18/15 01:47 PM
MR_P_BODY
If this will copy over from the 1967 Dodge Service Manual for the 273/318 engine:
1.998"-1.999" on the #1 cam journal. I couldn't get it to copy and paste from the PDF.
Ray... based on this and this 50 millimeter = 1.968503937 inch but I know that my 50mm cam had to be ground a bit to fit the bearings so its a bit oversized... measure that #1 journal on that stick.. its gonna be very close.. and in some cases the bearings are over sized(I have had most of them that needed to be sized).. or bore the cam tunnel to 50mm roller specs
[Re: MR_P_BODY]
#1782208
03/18/15 02:11 PM
03/18/15 02:11 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
I'll check it as soon as I get home around 330 thank
[Re: RAY1969CARS]
#1782209
03/18/15 10:56 PM
03/18/15 10:56 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I forget the O.D. of the 50mm needle bearings. But, yes you can have the tunnel bored for 50mm roller bearings.
[Re: WHITEDART]
#1782211
03/18/15 11:10 PM
03/18/15 11:10 PM
MR_P_BODY
55 mm cores are cheap from comp cams
He has a 48* babbit block... I sold him a 48* 50mm by accident thinking it was a babbit one.. when I checked my stash I got rid of the babbit one along the line somewhere .. now he is trying to see if the 50mm can be cut to babbit specs.. he could cut the block to 50mm and use what he has now but he wants the babbit set up
[Re: Leon441]
#1782216
03/19/15 02:49 AM
03/19/15 02:49 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
That would be the key to what I want to do you know any OD and what the block is actually measuring for the press of the bearings are the numbers I may need
[Re: RAY1969CARS]
#1782217
03/19/15 02:57 AM
03/19/15 02:57 AM
MR_P_BODY
mike I only have calipers no mic but I'm getting 1.995 on the cam
Now you need to measure the front bearing to see what it is
[Re: vc360]
#1782219
03/19/15 09:14 AM
03/19/15 09:14 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
48 degree babbit blocks are not stepped journals ........ they take their own bearing sets and are all the same diameter. http://www.jegs.com/i/Mopar-Performance/312/P4876372/10002/-1?parentProductId=1903872
I am pretty sure the 59 degree blocks use the stepped bearings like the stock blocks.
That's not correct. The early48 deg "r" blocks and "r1a"blocks used stepped journals like a 59 block but with 48 degree lobe spacing. I have one and it uses std small block cam bearings. Call bullet or midway cams.
Why does this not surprise me ? Add that to the which oil pan and which crankshaft journal questions then. I am pretty sure that the MoPar UGL cams for the babbit blocks are all gone , but cores can be sourced elsewhere. But like everything else with these motors , bring your wallet.
