Page 2 of 4 1 2 3 4
Re: R block cam Journal question [Re: tubtar] #1782220
03/19/15 09:57 AM
03/19/15 09:57 AM
CA.
RAY1969CARS Offline OP
CA.
48 degree babbit blocks are not stepped journals ........ they take their own bearing sets and are all the same diameter.
http://www.jegs.com/i/Mopar-Performance/312/P4876372/10002/-1?parentProductId=1903872
I am pretty sure the 59 degree blocks use the stepped bearings like the stock blocks.
That's not correct. The early48 deg "r" blocks and "r1a"blocks used stepped journals like a 59 block but with 48 degree lobe spacing.
I have one and it uses std small block cam bearings.
Call bullet or midway cams.
Why does this not surprise me ?
Add that to the which oil pan and which crankshaft journal questions then.
I am pretty sure that the MoPar UGL cams for the babbit blocks are all gone , but cores can be sourced elsewhere.
But like everything else with these motors , bring your wallet.
It Ain't no Chevy lol
Re: R block cam Journal question [Re: RAY1969CARS] #1782221
03/19/15 11:42 AM
03/19/15 11:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have 1 more 50mm cam(UGL) for the 48*.. I was hoping
that it was a babbit one but it isnt... some where I
got rid of the one I had
Re: R block cam Journal question [Re: MR_P_BODY] #1782222
03/19/15 11:46 AM
03/19/15 11:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Our R3 project stalled for about 3 months last year as we couldn't find a core..... my R3 now has BBC cam bearings
Re: R block cam Journal question [Re: J_BODY] #1782223
03/19/15 11:51 AM
03/19/15 11:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What journal.. babbit or 50
Re: R block cam Journal question [Re: MR_P_BODY] #1782224
03/19/15 11:56 AM
03/19/15 11:56 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
was a babbit deal.... I "think" there are cores out there again, but at the time nobody had anything.
Re: R block cam Journal question [Re: J_BODY] #1782225
03/19/15 12:53 PM
03/19/15 12:53 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
And people think a G3 is complicated!
Re: R block cam Journal question [Re: MattW] #1782226
03/19/15 01:21 PM
03/19/15 01:21 PM
CA.
CA.
Is it the 50 mm needle bearing a lot thicker than a regular bearing ? I don't know off hand If it is couldn't I just bore out the cam tunnel seems to me that the 50mm care are easier to come by my experience with the 1st R block being so old and they r3 a lot newer. If anybody's done is what would be the price on doing it Machine whys is it a real big deal ???
Re: R block cam Journal question [Re: MattW] #1782227
03/19/15 01:22 PM
03/19/15 01:22 PM
408Dust Offline
408Dust  Offline
Call LSM 248-674-4967 I had a 54mm one made for me in 3 weeks this January. Chris Padgett at comp may be able to help also.
Re: R block cam Journal question [Re: RAY1969CARS] #1782228
03/19/15 01:38 PM
03/19/15 01:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my new R3 block it came with the 50m cam tunnel
but I still had to have it machined to line it up
and have the bearings fit.. the tunnel was a bit
undersize.. I had to have the mains line honed also..
it was bad
Re: R block cam Journal question [Re: MR_P_BODY] #1782229
03/19/15 04:31 PM
03/19/15 04:31 PM
CA.
CA.
it was bad
I guess this is half the fun lol
Re: R block cam Journal question [Re: RAY1969CARS] #1782230
03/19/15 04:50 PM
03/19/15 04:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
it was bad
If your gonna run a big lift cam you would be far
better to have the cam tunnel bored to 50mm specs..
that way the cam wont flex like the stock type core
being that you have to grind the base of the cam to
get the lift... but then you would want good rockers
also.. but you said you were going with TD if I recall
and if you go that way I would go push rod oiling
for the rockers.... nothing easy on these things
EDIT
Let me take a look around.. I think I have a set of
50mm bearing... if I have them you can have them
but they would need a washing
Re: R block cam Journal question [Re: RAY1969CARS] #1782231
03/19/15 07:06 PM
03/19/15 07:06 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Indy ripped me for 750 to bore cam tunnel for 50mm roller bearings & another 250 to drill 16 holes in bores for pushrods oiling, I couldn't find a jig to do it myself. Now I know how women feel when they get rapped.
Re: R block cam Journal question [Re: rickraw] #1782232
03/19/15 07:14 PM
03/19/15 07:14 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
I think I have a few 48* roller cams, and one or two are stepped. I cannot use them in my block (need 50mm roller). I can measure to see, maybe we can swap? Please tell me what measurements the cambearings should have, and I will check through!
Re: R block cam Journal question [Re: MR_P_BODY] #1782233
03/19/15 10:54 PM
03/19/15 10:54 PM
CA.
CA.
it was bad
EDIT
Talk to a couple shops QMP. Bob Lemback I guess it can be done boring to a 50mm one more call to Brian at Imm that's the shop that will be doing all the machine work and the assembly and put it on the pump still need to know the pros and cons don't want to back myself into a corner to go a certain way with the motor oiling etc. etc.
Re: R block cam Journal question [Re: RAY1969CARS] #1782234
03/19/15 11:05 PM
03/19/15 11:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is JMO but I would go 50mm with push rod oiling
with multi shaft rockers such as TD.. this was the
way I went and it worked well... I was turning 8200
rpm all the time but I did go as high as 9600 looking
for more power.. this was on my 405ci W-9 but I
needed another .150 lift on the cam which would have
made 750 hp... but I wimped on the cam... talk with
Brian and see what he thinks
Re: R block cam Journal question [Re: MR_P_BODY] #1782235
03/20/15 12:12 AM
03/20/15 12:12 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would go with a Babbitt cam, the factory 2" size(1.998) and predator cams has cores. A Babbitt bearing is much more reasonable then rollers and cores are cheap also.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: R block cam Journal question [Re: 1967dartgt] #1782236
03/20/15 01:23 AM
03/20/15 01:23 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
You live close to the best shop in the west.stop banging your head on the key board and get it done . And get it to the track the more money you try to save the more it cost you. This is what I found out the hard way on my w8 dill
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: R block cam Journal question [Re: WHITEDART] #1782237
03/20/15 10:20 AM
03/20/15 10:20 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
my 48 r block has stepped bearings ,my new cam is not stepped seems to fit in the front nice the new cam is 21 = 1.9985 2" SB Mopar "R" Babbit
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: R block cam Journal question [Re: Ian] #1782238
03/20/15 07:45 PM
03/20/15 07:45 PM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
Re: R block cam Journal question [Re: vc360] #1782239
03/20/15 10:26 PM
03/20/15 10:26 PM
CA.
CA.
Do the 50 mm roller bearing cams have holes in the journals for oil as well as A grove cut them ???
Page 2 of 4 1 2 3 4
