Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777218
03/14/15 02:24 PM
03/14/15 02:24 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Sorry, Bob. It's not ready yet. Maybe by the winter. Our 6AL type Ignition Box has the rev-limiter, but there is wiring.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: sunroofgtx] #1777219
03/14/15 03:44 PM
03/14/15 03:44 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Do you have the ignition box on your website? I am looking for one and after installing your ready to run on an engine this morning I would find it hard not to buy an ignition box
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: CTD5.9] #1777220
03/14/15 06:18 PM
03/14/15 06:18 PM
MN
W
Willie68coronet Offline
W
MN
Mancini has them. firecore 6 series
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: CTD5.9] #1777221
03/16/15 12:28 PM
03/16/15 12:28 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
The Ready to Run has an ultra-hot ignition box inside. Just not a rev-limiter, yet. keith Dunnick dyno tested them and the RTR distributor was actually better at the higher rpm's.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777222
03/18/15 09:31 AM
03/18/15 09:31 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Do not buy a pertronix distributor if you have Edelbrock heads! I had to remove a ton of material for 2 days, still had to grind the distributor and the cap. The whole time praying I didn't go too far, I bet I removed at least 3/8 of an inch into the cylinder head. I'll try to get pics tonite.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777223
03/18/15 11:33 AM
03/18/15 11:33 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Look at it this way Bob ------ LESS weight
Russ
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: max_maniac] #1777224
03/18/15 11:53 AM
03/18/15 11:53 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Russ
Hadn't thought of it that way yet!
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777225
03/18/15 12:03 PM
03/18/15 12:03 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
3/8 of an inch is a lot of meat - if it leeks you will find out pretty quick once it gets hot and under pressure! I think I would have just found something else that fits better. Had the same issue with the 440 source dizzy - I went with summit dizzy (same as firecore) fits fine - but I have a MSD 6 digital ignition - neatly stowed away under my dash
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: DoubleD] #1777226
03/18/15 02:47 PM
03/18/15 02:47 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Yea it would have been much easier to go another route. I called Muscle Motors though and he assured me there's alot of meat in that area. On the head it actually sticks out there in a rounded shape almost like it was done for cosmetics. So it hits a large distributor there. I really needed a Rev limiter, wanted to get rid of wiring, and I got a great deal on it new so I'm gonna make it work.
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: ProSport] #1777227
03/23/15 11:34 PM
03/23/15 11:34 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Did you get the 400 Dist or order the 440 and cut the shaft?
Owner of Custom33.com 1933 Plymouth Coupe and Roadster Kits
Re: Anyone run a Pertronix Ignitor3 billet distributor? [Re: Matt Erich] #1777228
03/24/15 12:06 PM
03/24/15 12:06 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
400 Distributor.
It is up and running, I really like the easy access to the advance Springs, right under the rotor. The Rev limiter I need to play around with, the tiny adjuster seems to jump all over the place rpm wise, and it seemed to kick in early. I will get it figured out and I might just buy their external Rev limiter box as it would be easier to set and to do quick low rpm settings just to make sure the Rev limiter is working.
