Re: Which automatic shifter are you using !!??
[Re: an8sec70cuda]
#1776745
03/11/15 10:19 AM
03/11/15 10:19 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
PPP because you have options on set up. I like to push on the upshift and they can do that with a reverse pattern valve body.
"Just a Bracket car dressed up like a streetcar"
[Re: RAY1969CARS]
#1776754
03/11/15 04:44 PM
03/11/15 04:44 PM
Thumperdart
State of confusion
Hurst Promatic 2.........stupid simple.
[Re: GY3]
#1776755
03/11/15 05:00 PM
03/11/15 05:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
ANY Mopar benefits from a rear exit shifter cable IMO.
Clearing the starter, header and torsion bar can be a real challenge with the front exit cables!
... I have to rap the shifter cable with high temp covering just to make sure it doesnt burn.. no big deal.. but if I could get a rear exit on the pro ratchet that would be the ultimate ... JMO ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1776756
03/11/15 05:14 PM
03/11/15 05:14 PM
Posts: 4,715 Wichita
GY3
Wichita
Wrapped mine for sure and did a little creative bending of the bracket during install to keep it away from heat and redirect it's path.
Too bad no one makes an aftermarket setup similar to a slapstick with an adjustable metal rod instead of a cable! ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: Thumperdart]
#1776757
03/11/15 05:22 PM
03/11/15 05:22 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Ran one in the Mirada.... worked fine. Bought one for the Duster......nothing but problems. Swapped shift arms between the cars.... Same crap. Something was amiss on it internally. Chit canned it.
[Re: Super Scamp]
#1776758
03/11/15 05:22 PM
03/11/15 05:22 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
PPP 3 speed in the Challenger and Stealth black Pro Bandit 2 speed in the Scamp. Both great shifters. Both also air shifted
What doz one of those bad boys go for ??? 400.00
[Re: J_BODY]
#1776760
03/11/15 05:25 PM
03/11/15 05:25 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
better sit down son.....
Lolol no air shifter lololo
[Re: J_BODY]
#1776761
03/11/15 05:34 PM
03/11/15 05:34 PM
MR_P_BODY
I never cared for that PPP shifter... I could make that in my shop... 2 panels of alum with a arm.. no thanks.. but I know some guys like it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1776762
03/11/15 05:40 PM
03/11/15 05:40 PM
Posts: 4,292 Morrow, OH
markz528
Morrow, OH
Well I was going to put a B&M Pro Ratchet in my GTX build but now I am leaning towards the PPP. The rear exit is too good to pass up.
How do you even put a front exit cable with a CSR shield? I have a Cheetah in my race car with the rear entry and it is wonderful to have the rear entry, but the Cheetah is not a street shifter.
[Re: markz528]
#1776764
03/11/15 05:53 PM
03/11/15 05:53 PM
MR_P_BODY
I burnt 1 shifter cable using the pro ratchet.. that was the very first cable.. it was a bit short and I didnt cover it.. I was being brave.. since then I use a longer cable and I DONT use the heavy duty one.. they are a lot stiffer and harder to bend to clear things... but I heat wrap it just to be sure... never burnt up another... I'll wrap it just so I can use the shifter I like... this cable has been in there 14 years now ![](/ubbthreads/images/graemlins/wave.gif)
