Re: To Paint Parts or Not [Re: ScottSmith_Harms] #1776524
03/11/15 09:04 PM
03/11/15 09:04 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Mike, I never got your message about a Duster?
they seem to be going to scatpacktom?? antway I sent an e-mail to the address you have listed. it's probably gone by now.
Re: To Paint Parts or Not [Re: mikemee1331] #1776525
03/12/15 01:51 PM
03/12/15 01:51 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Electronic ignition conversion is easy, especially if you use an aftermarket box like MSD.
Use a later Chrysler electronic distributor as the trigger (most people wont notice the minor difference) and hide the box under the battery tray. Run the trigger wires behind the water pump housing to hide and it's really easy. A ground, a switched hot, a main hot (to battery), the two trigger wires and coil wires. VERY simple install and is easily reversible! The built in rev limiter is an added bonus on the 6AL!
I did this in my '71 Barracuda and now my '63 Dodge 330 and it makes a world of difference in startup, idle and drivability not to mention no points (maintenance) to deal with!
Re: To Paint Parts or Not [Re: GY3] #1776526
03/13/15 06:55 AM
03/13/15 06:55 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
If a original part not has good to perfect paint, i usully restore it by clean and repaint it.. ONLY if i can get the correct shade of the color again.. if not i would leave it as is. Also depending on the cars condition, and how important the finish is.
About your shaker parts, i would leave the orange lid as is and maby the baseplate also, or repaint in 80% gloss.
Nicklas
Re: To Paint Parts or Not [Re: 71redcuda] #1776527
03/13/15 01:30 PM
03/13/15 01:30 PM
Kennewick, Wa.
71vert340 Offline OP
Kennewick, Wa.
Thank you for the replies. For now, I'll leave the parts alone since I'm putting the car back together for the spring. I enjoy taking the car to shows so people can enjoy it. I receive compliments for it. This past year, I overheard a person telling his friend my convertible was his favorite of the show. Another person stood there looking at the car and asked if it was mine. When I said yes, he told me he wondered what it would be like to drive the car and be seen in it. I told him to go ahead and get in and sit behind the wheel. He had me take his picture and thanked me for the time. That's what makes it worth it. When I said it doesn't do well at the local show, it's because all Challengers are put together in the same class, so I sit next to Challengers with high impact colors, hemi engines and chrome, but it's all cool. I just enjoy sharing the car with others.
Re: To Paint Parts or Not [Re: 71vert340] #1776528
03/13/15 02:32 PM
03/13/15 02:32 PM
Kennewick, Wa.
Kennewick, Wa.
I posted this pic over in the tech forum for a 70 Cuda Shaker question. I noticed when I took the photo this morning there's bug guts on the inside of the scoop. How should I clean the parts, especially the inside of the scoop, to get rid of the bug splatter? Dish detergent maybe? This will be the first time this assembly has been cleaned in the 43 years I've owned it. Thanks.
Terry
Re: To Paint Parts or Not [Re: 71vert340] #1776529
03/16/15 11:51 PM
03/16/15 11:51 PM
Kennewick, Wa.
Kennewick, Wa.
I cleaned the doors, grilles and inside of the scoop. I'll share a few pictures and show the markings on the screw heads. This first is the spray pattern of the black inside the scoop with all but one grille removed. It looks like a quick spray job.
Re: To Paint Parts or Not [Re: 71vert340] #1776530
03/16/15 11:54 PM
03/16/15 11:54 PM
Kennewick, Wa.
Kennewick, Wa.
This next pic is of one of the grilles. notice they were painted the flat black on the outside but the inside of the grille you see when looking into scoop is more semi-gloss. Maybe this is the result of years of car washing, waxing, etc.
Re: To Paint Parts or Not [Re: 71vert340] #1776531
03/16/15 11:57 PM
03/16/15 11:57 PM
Kennewick, Wa.
Kennewick, Wa.
Warm air door cleaned.
Re: To Paint Parts or Not [Re: 71vert340] #1776532
03/17/15 12:00 AM
03/17/15 12:00 AM
Kennewick, Wa.
Kennewick, Wa.
Cold air door and rod. The rod appears to have black paint spatter on it but I wouldn't think it would have been attached when the cold air door or warm air door were sprayed. Maybe just tarnish of the plating.
Re: To Paint Parts or Not [Re: 71vert340] #1776533
03/17/15 12:02 AM
03/17/15 12:02 AM
Kennewick, Wa.
Kennewick, Wa.
Screw head marking on the cold air door attaching screw.
Re: To Paint Parts or Not [Re: 71vert340] #1776534
03/17/15 12:05 AM
03/17/15 12:05 AM
Kennewick, Wa.
Kennewick, Wa.
Marking on the grille attaching screw.
Re: To Paint Parts or Not [Re: 71vert340] #1776535
03/17/15 12:06 AM
03/17/15 12:06 AM
Kennewick, Wa.
Kennewick, Wa.
Last, the shaker bubble part number.
Re: To Paint Parts or Not [Re: 71vert340] #1776536
03/17/15 12:07 AM
03/17/15 12:07 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The spray pattern may look random but it was quite specific in many ways. When they were primed and sealed (brick red and grey colors) they were hung two at a time with the undersides towards each other and the fronts pointed towards the ceiling so they looked like a giant clam. The drain holes pushed them away from each other at the front so there was a 1/2 inch or so gap at the front and the rears were touching together. They were typically hung from one of the drain holes which skewed them a small amount so they didn't align perfectly, this is why you often see overspray patterns on the undersides which show features like dots and lines from the overlapping bolt holes and slots at the rear and sides which blew through the opposite scoop that was hanging with it. Then once they were dry it appears that the final paint (black Organosol, Silver Argent, etc.) was applied after they were set individually on a flat surface with no masking which shows over spray on the underside due to the drain holes holding the front up and a short distance away from the resting surface and from painting through the front openings.
So, accordingly, for those going all out on a proper restoration you'll find it much easier to use two scoops (one to act as a mask for the other one) to duplicate these details 100%.
