Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On [Re: Big Bad Bee] #1775605
03/12/15 02:01 AM
03/12/15 02:01 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Dogdays, thanks for the positive input. I respect JohnRR's knowledge and opinion, although I must say that if I did everything he told me I should do, I would have $50K involved in my car and it would be bulletproof.
DKN 1997, Rarefish and 383man, are any of you running a holley with choke tower? If so, how's the performance with that drop air cleaner?
Since we are going there, have any of you removed a choke tower? if so, what did you use?
my demon has no choke tower...as for performance, I couldn't say, I've had it on for so long I can't remember if there was any difference
Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On [Re: Pool Fixer] #1775606
03/12/15 08:30 AM
03/12/15 08:30 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Like someone else said, the ford motorsports air cleaner was the one to get. But I'm pretty sure it's been discontinued for at least 5 years.
Glad to see how this car has came along. Do you know what ever happened with your old barracuda/cuda?
Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On [Re: 68KillerBee] #1775607
03/12/15 01:50 PM
03/12/15 01:50 PM
dogdays Offline
dogdays  Offline
I agree that the choke airhorn needs to go. Airflow around it, under the tallest air cleaner you can fit, will mess with the carburetor flow patterns.
If you had a milling machine you could use that, it's the sophisticated way.
If you don't have a milling machine, a hacksaw and a couple of files will achieve the same result. The zinc material the carb is made of is relatively soft. You can just chop it off, but it'll look better (maybe work better too) if you radius all the square corners. Think of the top of a Holley HP carb. You don't have to go that far, but easing the corners will give it a finished look.
R.
Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On [Re: 68KillerBee] #1775608
03/12/15 03:05 PM
03/12/15 03:05 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
Yes I do! I sold the Quickfish to a guy from Germany who makes regular trips to Seattle to get cars to restore. Big time Concourse de Elegance guy. He flipped it to a nice mopar guy up in British Columbia named Mike. Mike has the body repaired and painted and the engine back in, top back on and interior getting done last time I checked. He didn't do a complete resto but then if you saw the underside of the car you'd know why. Really clean car. He had a baby on the way and the car took a back seat. Haven't talked to him in a year. He went original B5/white with it.
I’m listening.
Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On [Re: Big Bad Bee] #1775609
03/12/15 04:52 PM
03/12/15 04:52 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
I went with the older Performer, non-RPM, for just this reason on my 69 R/T with Ramcharger hood... not sure if you're looking for every last HP, but that might be an option for you.
Darren
Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On [Re: Ludington1] #1775610
03/12/15 08:10 PM
03/12/15 08:10 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Street Dominator intake. I wish mine was not a spread-bore. Sorry..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On [Re: Big Bad Bee] #1775611
03/13/15 01:46 AM
03/13/15 01:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes my 850 has all the choke tower on it as all I did was remove the choke blade. Here it is on the old eng but I still use this same carb just like this. One day I will pull the carb and have the air horn (choke tower) milled off and see if it helps any. Ron
Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On [Re: 383man] #1775612
03/13/15 01:48 AM
03/13/15 01:48 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is a closer pic of my air cleaner. Ron
Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On [Re: 383man] #1775613
03/13/15 09:30 AM
03/13/15 09:30 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I believe that the OPs choke tower is taller than the choke tower on the typical 4781, 850 DP like Ron's.
Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On [Re: BSB67] #1775614
03/13/15 02:26 PM
03/13/15 02:26 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
'67 Satellite with 440, RPM, 850 DP Holley with choke horn milled off, 1/2" carb spacer, Moroso drop base air cleaner - good clearance with stock hood. Runs the same exact time in the 1/8 mile with or without air cleaner.
Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On [Re: BSB67] #1775615
03/13/15 06:33 PM
03/13/15 06:33 PM
Spokane Valley, WA
Spokane Valley, WA
I believe you're right. Looking like I'd better call the guys down at the CNC lab (I work at a technical college).
I’m listening.
