Re: Wiring directly to the battery, how do you do it?
[Re: Evil Spirit]
#1774009
03/09/15 09:15 AM
03/09/15 09:15 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Problem is that noise on the line that you hear in a speaker is not likely all the noise on the line. And that noise you cannot hear may interfere with the EFI computer. One hopes the manufacturer of your kit put in filters to deal with it.
[Re: cjskotni]
#1774010
03/10/15 12:33 AM
03/10/15 12:33 AM
Posts: 1,822 Colorado
denfireguy
Colorado
The closer to the battery, the better because the battery helps filter electrical noise.
Horrible misinformation. The electrical noise would be no different anywhere on the charging circuit. The only thing that would differ would be the voltage itself as there will be small drops across various connections (i.e. bulkhead). The "shakiness" of the voltage will be no different as it's all the same circuit.
The only thing you gain from wiring on the battery (or starter relay) is pulling additional current through the dash harness (unless you have done a bypass), making the car that much more unsafe not mention making the ammeter totally unreliable.
The "noise" from radio is not necessarily from the alternator but from the ignition circuit, not the alternator. This is EMF and if present on one side of the charging circuit, will also be present at the other. If you have noise now, wiring from the battery probably won't help.
I pull my two electric fan relay loads from the alternator stud. No noise on my radio and my ammeter is dead accurate.
Sorry, if it is misinformation, it is propagated by the manufacturers of commercial two way radios such as Motorola, Harris, Tait, Yaesu, Kenwood, Bendix King, and a few others. Add to that the manufacturers of electronic sirens like Whelan, Federal Sign and Signal, Denelcor and Unitrol.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1774011
03/14/15 11:16 PM
03/14/15 11:16 PM
beepilot
I did what StrkrDart69 did . I bought one of these from http://racetronix.com/ They are in Canada but I have bought a lot from them and shipping to US is no problem, reasonable prices too. These junction blocks are priced from $10. I ran a wire down from the starter relay and sort of hid it under the battery like he said. Have multiple tie ins here.
