Page 2 of 3 1 2 3
Re: Highway RPMs [Re: MoparJ] #1773456
03/07/15 05:42 PM
03/07/15 05:42 PM
USA
rftroy Offline
rftroy  Offline
USA
The A-833 with OD swap will take place sometime before the year is out.
You may not like the OD4 behind that engine. It will cruise nicely, yes, but the ratios are such that it is no fun getting going.
The ratios are 3.09, 1.67, 1.00, 0.73.
1st to 2nd is getting very close to a 2 to 1 ratio change.
I had a 318 with 360 heads, thermoquad, and a DC hyd. with specs right between the stock 318 and 340 cams, and an OD4.
It was miserable to drive because of the torque curve. It winds out fast due to the low first, but then 2nd gear puts you way down on the torque curve, and you just lug for a while. If you shift at 4500 from 1st, you start 2nd at 2432.
It was especially no fun in stop and go traffic, and you know what that's like here in SoCal.
I ended up pulling the OD4 after just a few months and put the std 4 speed back in.
I have the OD4 behind my slant 6, and it runs great. But that's when you find that the stock slant 6 has a really wide torque curve, and it can pull comfortably at low rpm. A warmed over 318 is going to be more "peaky", and that's where the wide gear spread works against you.
Not saying it won't be right for you, but keep in mind that acceleration runs aren't going to be as much fun.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Highway RPMs [Re: rftroy] #1773457
03/07/15 06:40 PM
03/07/15 06:40 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
I had a '69 Dart Swinger 340 with 3.23 gears that would cruse at 2700 rpm's at 65 mph with stock tires. I went to 3.91 gears and the rpm's went to 3200. I took many 400 mile trips from the bay area to LA with no problems. Mileage was not great, but high test gas was only $.25 a gallon back then.
Raul
Re: Highway RPMs [Re: Aspen7695] #1773458
03/09/15 09:32 PM
03/09/15 09:32 PM
dogdays Offline
dogdays  Offline
Don't forget that Jamie Passon has his own set of OD gears that have smaller drops between the first three gears, although the gearsets are pricey.
In reality it shouldn't hurt the engine, but I'd like a nice set of earplugs to make it easier on me!
R.
Re: Highway RPMs [Re: dogdays] #1773459
03/09/15 09:43 PM
03/09/15 09:43 PM
IN
ahy Offline
ahy  Offline
IN
The engine can take some spinning... but over 3,500 RPM to keep up with normal 75 MPH traffic would be a bit much for me. If you plan any meaningful highway miles, suggest 3.23's or the OD transmission or even both. A healthy moderate 318 should handle 3.23's easily. Better range on a tank of fuel would be another benefit.
Re: Highway RPMs [Re: Grizzly] #1773460
03/09/15 10:37 PM
03/09/15 10:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did a head gasket on a '98 350 700R4 half-ton and at 170,000 miles the cylinders still had cross hatch in them.
My 87 318 with more miles and no OD still shows the cross hatch. It's called moly rings.
Don't be the exception.
Re: Highway RPMs [Re: Supercuda] #1773461
03/09/15 10:43 PM
03/09/15 10:43 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
I ran across this not too long ago. Check it out!
http://vexer.com/automotive-tools/speed-rpm-calculator
Re: Highway RPMs [Re: superbeedave] #1773462
03/09/15 11:03 PM
03/09/15 11:03 PM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
cool site
Re: Highway RPMs [Re: d-150] #1773463
03/09/15 11:11 PM
03/09/15 11:11 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Sure, it "can" spin that high, but I am definitely tired of 3.91s...even with 28.4" tall tires.
My 0.62 6th should put me at a 2200rpm cruise at 80. Now that's more like it! [1900 at 65mph]
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Highway RPMs [Re: GoodysGotaCuda] #1773464
03/10/15 02:17 PM
03/10/15 02:17 PM
dogdays Offline
dogdays  Offline
Yep, that was my point, too. It's hard on the driver, the engine should be able to run at that speed indefinitely.
R.
Re: Highway RPMs [Re: Von] #1773465
03/10/15 04:32 PM
03/10/15 04:32 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
As far as will high rpm on the highway hurt it? Eventually, yes: there's a reason why new vehicles with overdrive are hitting 300,000 miles and the old girls barely made 100,000.
No offense, but considerably more involved than just final drive ratio....
The gear ratio helps but is probably one of the least important factors. Harder bores, moly rings, oil technology, and fuel injection have helped to make big strides.
Also theres lots of 4 banger cars that turn 3000-3500 @ 70 in overdrive.
Re: Highway RPMs [Re: GTX MATT] #1773466
03/10/15 09:11 PM
03/10/15 09:11 PM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
I think there is a huge difference between a 4 banger and a big block spinning well over 3 grand for hours at a time.
Master, again and still
Re: Highway RPMs [Re: rftroy] #1773467
03/10/15 10:52 PM
03/10/15 10:52 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Completely agree. Many do the calculation and think they have struck gold with the desired rpm but in the real world rpm drop sucks.
The answer after 100 years of building cars. Just like the OEM's do it. More gears. rftroy, dogdays and goody get it. A rear ratio will not solve it, nor will putting up with 4000rpm on the highway in the right lane will everything passing.
Overdrive is the only answer.
Re: Highway RPMs [Re: Magnum] #1773468
03/10/15 11:33 PM
03/10/15 11:33 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
A Member who I have not seen on here for quite some time, had an 833od in an A-body with a 360. I asked him about it and he said he never noticed any drastic difference: the 360 pulled the wide-ratios with ease and still did low 13's in the 1/4. 340Shorty had the same set-up in his truck and he liked his as well.
I just got one in an '84 Ram with a 318 2bbl. With 2.94 gears, 30" tires, and at 4000 pounds that 833od is fun as heck to drive. I got back into one of my close-ratio ratio cars and it felt like you had to shift all the time. It seemed like it was wasting power.
The 1st to 2nd is not an issue at all, 2nd to 3rd is a little much but nothing you can't get used to.
Mo' Farts
Moderated by "tbagger".
Re: Highway RPMs [Re: Grizzly] #1773469
03/11/15 01:16 AM
03/11/15 01:16 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Grizzly is dead on.
Re: Highway RPMs [Re: Grizzly] #1773470
03/15/15 11:39 PM
03/15/15 11:39 PM
Magnum Offline
Magnum  Offline
I got back into one of my close-ratio ratio cars and it felt like you had to shift all the time. :
Good point. As a daily driver, too many gears is not neccessary but for racing they are there. Close ratios are what you need to keep an engine in it's power band. If you are not competative, then it's not a big deal.
During city commuting. Go with skipping gears. In my 5 spd Mustang I often go 1,3,5 and even GM had skip shift on their close ratio T56's 1 to 4rth.
Re: Highway RPMs [Re: Magnum] #1773471
03/16/15 01:24 AM
03/16/15 01:24 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
It's not the engine rpm, it's the engine noise with the headers and hi flow mufflers, wind noise/open windows, no a/c. We are just use to driving modern cars. My wifes CRV turns the same rpm as my demon.
Re: Highway RPMs [Re: ademon] #1773472
03/16/15 02:15 AM
03/16/15 02:15 AM
france
jose jones Offline
jose jones  Offline
france
Put a set of 3.23 gears in it I was in California this week everyone goes about 80 on the freeways!! There is no need to run your RPM's that high on a street car
Re: Highway RPMs [Re: DaveRS23] #1773473
03/16/15 02:55 AM
03/16/15 02:55 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Yes and no
Smaller engines usually have shorter strokes which is conducive to high rpm cruising. But, 3000 rpm is 3000 rpm... The piston sweeps the bore just as many times regardless of the bore/stroke, and rings/pistons sweeping up and down is what adds to engine wear.
**Photobucket sucks**
Re: Highway RPMs [Re: 70Cuda383] #1773474
03/16/15 04:04 AM
03/16/15 04:04 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Yes and no
Again, yes and no. With the smaller bores and stroke, there's less moving mass that doesn't move as far and that allows the engine to have a higher natural frequency (otherwise known as red line). But I don't really see a difference from a wear standpoint. Also, 4 bangers need to spin at a higher rpm at higher speeds in order to keep the car moving. It's actually a little wasteful for a v8 to be cruising at 3000 rpms (all depending on the vehicle's weight and aerodynamics).
Re: Highway RPMs [Re: MuuMuu101] #1773475
03/16/15 11:47 AM
03/16/15 11:47 AM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
I was thinking of the weight stopping and starting with each stroke in the 8, especially big blocks. Our stuff is usually bigger and heavier inside and really wasn't designed to spin that high that long. Which is at least part of the reason why anything but a performance car got 2.76s or so. Of course, newer, lighter reciprocating assemblies lessen the impact.
And doesn't the load increase exponentially with RPM?
I just think that after a certain point, the higher the RPM and the longer it is held there, the more impact it has on our engines. So I don't cruise my big blocks over 3,500 for any length of time and usually try to keep it closer to 3,000.
Too old school?
Page 2 of 3 1 2 3
