Re: oil pressure fluctuations
[Re: slickrock]
#1772495
03/05/15 08:37 PM
03/05/15 08:37 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I'd hook up a cheap after market mechanical gauge, cause it would be the easiest and cheapest to do. Wouldn't even have to mount it, if you want to keep the dash stock. If it shows the same symptoms then no need to dig into the dash to replace the factory gauge. I'm kinda leaning towards the pick up tube next. Loose or cracked.
I have mechanical Aptitude. I can screw up anything.
[Re: JohnH]
#1772499
03/05/15 11:50 PM
03/05/15 11:50 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
Also, my 440 I put a "T" coming-out of the block for the oil pressure.I have the factory gage, and I also installed a direct pressure gage. The factory says 20 psi,, and the direct stays at 50psi.. But you do have two places to install oil pressure gages back there if you don't want to T it off, If you install a direct gage, which I recommend get copper tubing, don't use that plastic. I feel strongly there is no windage tray on that block,, but like every one is saying get a direct gage..
What factory (Mopar 440 equipped) gauge has PSI readings on it??? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Pacnorthcuda]
#1772500
03/06/15 01:43 AM
03/06/15 01:43 AM
Posts: 5,449 So Cal
Sinitro
So Cal
My 70RR has PSI readings on the OE oil guage...
Just my $0.02... ![](/ubbthreads/images/graemlins/wink.gif)
[Re: Sinitro]
#1772501
03/06/15 02:13 AM
03/06/15 02:13 AM
Posts: 549 WV
JohnH
WV
My 70RR has PSI readings on the OE oil guage... My 69 Charger has PSI
Just my $0.02...
[Re: Pacnorthcuda]
#1772502
03/06/15 02:14 AM
03/06/15 02:14 AM
Posts: 549 WV
JohnH
WV
Remember a 440 is a dry sump engine,
Umm, no its not.
Ummm yes it is..
[Re: slickrock]
#1772505
03/06/15 05:04 AM
03/06/15 05:04 AM
Posts: 43,317 Bend,OR USA
Cab_Burge
It sounds like it is time for you to find out exactly how much oil is in your engine now and how much it should have. Drain the oil with the motor hot or at least warm and measure it, write it down and then look at the oil pan and see if it has any numbers stamped into or on the oil pan anywhere ![](/ubbthreads/images/graemlins/scope.gif) If it does let us know those numbers, Mopar had two different stock oil pans on the BB and Hemi motors in 1970 and 1971 ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) The common production "402' oil pan and the 1970/71 only 426 street hemi and 440 6 pak oil pan ![](/ubbthreads/images/graemlins/scope.gif) If you oil pan doesn't have any numbers stamp into it measure the depth of it at the back of the sump where the oil drain plug is, measure from the engine block down to the bottom of the oil pan and the length and width of the center oil sump and let us know those measurements ![](/ubbthreads/images/graemlins/thumbs.gif) The common misconception on the proper amount of oil in the stock 402 oil pans originates from factory service manuals that said 4 quarts, they had the wrong amount in them ![](/ubbthreads/images/graemlins/shock.gif) It show 4 quarts plus one for the oil filter, Mopar sent out several diffeent service bulletins over the years correcting that to be 5 quarts plus one for the oil filter ![](/ubbthreads/images/graemlins/scope.gif) the 1970/1971 426 street Hemi and 440- 6 pak oil pans hold 6 quarts plus one for the oil filter, that is the best stock oil pan to use in any 1966 to 1971 B and E body with a B or RB or Street Hemi motor in those cars ![](/ubbthreads/images/graemlins/scope.gif) You need the matching oil pick up also to use those pans correctly to prevent oil starvation.Let us know what you find out, I always add the proper amount of oil to the motors I build and then make sure the oil dipstick is showing full with the correct amount of oil in them, if not reading correctly I correct and calibrate the dipstick so it reads correctly ![](/ubbthreads/images/graemlins/shruggy.gif) I learned a very hard lesson years ago on a car I took in trade, the Mopar chrome dipstick showed the motor to be around a half a quart over full when it only had two and half quarts of oil in the oil pan ![](/ubbthreads/images/graemlins/shruggy.gif) I ended up spinning a rod bearing in that motor due to oil starvation ![](/ubbthreads/images/graemlins/rant.gif) I now drain and verify all the motors I take in that I didn't build to start with ![](/ubbthreads/images/graemlins/thumbs.gif) No matter who built them, verify, verify and reverify to make sure you know exactly what you have ![](/ubbthreads/images/graemlins/thumbs.gif) IHTHs
[Re: dynorad]
#1772508
03/06/15 04:12 PM
03/06/15 04:12 PM
Posts: 4,322 Prospect, PA
BSB67
Prospect, PA
When the oil pressure says "0" are your rods knocking? If not that would point to incorrect pressure gauge.
if it has hydraulic lifters you would think those would be clattering pretty good....
