Big block truck mounts. Only one type? #1771764
03/04/15 11:23 PM
03/04/15 11:23 PM
Thunder Bay,ON
LilRedDave Offline OP
Thunder Bay,ON
Is there only one style of big block truck mounts for the 73 to 93 chassis? Are mounts for the 4 x 4 is different?
Re: Big block truck mounts. Only one type? [Re: LilRedDave] #1771765
03/04/15 11:35 PM
03/04/15 11:35 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
There actually 3.
These are 2wd and 72-74 4wd with the divorced transfer case.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Big block truck mounts. Only one type? [Re: moparmarks] #1771766
03/04/15 11:37 PM
03/04/15 11:37 PM
moparmarks Offline
moparmarks  Offline
And these which fit 75-93 4wd with the married transfer case.
There is another like these that have 2 slots for the biscuit mount that can be used on both 4wd and 2wd.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Big block truck mounts. Only one type? [Re: moparmarks] #1771767
03/05/15 12:21 AM
03/05/15 12:21 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
There actually 3.
About how long are those brackets for the 2wd? Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Big block truck mounts. Only one type? [Re: GTSDart340] #1771768
03/05/15 09:30 AM
03/05/15 09:30 AM
Thunder Bay,ON
Thunder Bay,ON
Thanks guys! Which ones would these be?
Re: Big block truck mounts. Only one type? [Re: LilRedDave] #1771769
03/05/15 11:46 AM
03/05/15 11:46 AM
moparmarks Offline
moparmarks  Offline
75-up 4wd.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Big block truck mounts. Only one type? [Re: GTSDart340] #1771770
03/05/15 11:48 AM
03/05/15 11:48 AM
moparmarks Offline
moparmarks  Offline
There actually 3.
I'll see if I still have any but bet they are a good 5".
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Big block truck mounts. Only one type? [Re: GTSDart340] #1771771
03/06/15 10:04 AM
03/06/15 10:04 AM
moparmarks Offline
moparmarks  Offline
There actually 3.
4.75" total length.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Big block truck mounts. Only one type? [Re: moparmarks] #1771772
03/06/15 06:19 PM
03/06/15 06:19 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Arent the Divorced the same as 2wd?
Re: Big block truck mounts. Only one type? [Re: 76dodgeboy] #1771773
03/06/15 09:56 PM
03/06/15 09:56 PM
moparmarks Offline
moparmarks  Offline
Yep, thought I stated that in my first post.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Big block truck mounts. Only one type? [Re: moparmarks] #1771774
03/12/15 04:45 AM
03/12/15 04:45 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
That would only leave 2 styles not 3 for the 72-78 trucks
Re: Big block truck mounts. Only one type? [Re: 76dodgeboy] #1771775
03/12/15 04:48 AM
03/12/15 04:48 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Ah I missed the Dual slot mount. That would make 3 but Is it a Stock one? Ive only seen it as an Aftermarket.
Re: Big block truck mounts. Only one type? [Re: 76dodgeboy] #1771776
03/12/15 12:03 PM
03/12/15 12:03 PM
moparmarks Offline
moparmarks  Offline
Not totally sure if they are stock but have found the dual slots on factory BB tracks.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
