Re: not sure, maybe a blown headgasket
[Re: ashburnmike]
#177194
12/29/08 12:04 AM
12/29/08 12:04 AM
RapidRobert
it's 14 MM & most if not all are that size & a few have 18MM adapters(which you wont need). I would suggest you get a fairly good one at your parts house that will continue to give accurate readings years to come. Compression testing is somewhat basic & people have gotten away from them somewhat but they have saved me lots of times when my mind wanted to get away from the K.I.S.S. principle.
[Re: RapidRobert]
#177195
12/29/08 12:24 AM
12/29/08 12:24 AM
Posts: 455 Ashburn, Virginia
ashburnmike
Ashburn, Virginia
Thanks Robert.
I'll post the findings tomorrow evening with, hopefully, a consistant reading cylinder to cylinder. If there is a substantial difference though and if the concensus is that it is the head gaskets, I will be leaning on you guys once again for more guidance.
But then the question arises, what caused it to happen in the first place.
[Re: FuryUs]
#177199
12/29/08 08:08 PM
12/29/08 08:08 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Not having the throttle wired open will affect the readings some, but not so much so that the readings are not valid--your readings are all in the same ball park. Probably not a head gasket.
I am on record as never thinking that is/was a head gasket. Really nothing really pointed to a head gasket problem. (Full coolant levels, nice oil and oil level normal.)
[Re: ashburnmike]
#177202
12/29/08 08:52 PM
12/29/08 08:52 PM
RapidRobert
#1 140 #2 150 #3 135 #4 135 #5 140 #6 147 #7 145 #8 140
You have a healthy long block. I am out of ideas also except for as he said vac leak
[Re: ashburnmike]
#177206
12/29/08 10:01 PM
12/29/08 10:01 PM
Posts: 4,558 Montana
FuryUs
Montana
would something as simple as fouled plugs be the culprit for the stumbling in the motor...but that doesn't explain the running hot does it.
Nope, and it doesn't explain the oil pressure shooting up, either... Wierd...
[Re: FuryUs]
#177208
12/29/08 10:36 PM
12/29/08 10:36 PM
RapidRobert
All I can think of now is what vitc gtx said, a slight intake coolant leak and I wonder if the ECU is acting up & when it was right was it idling at 1500?
[Re: ashburnmike]
#177209
12/29/08 10:39 PM
12/29/08 10:39 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
If you have the ralley dash, your fuel gauge could be the cause of your gauges reading too high, as the voltage limiter is part of the fuel gauge, and could cause the gauges to read too high or to low if it malfunctions. Happened to my 340 duster, all three gauges, (temp, oil press and fuel level started reading half of what they should have because of the fuel gauge. I imagine a non ralley cluster may do the same if plug-in style voltage limiter freaks out. ![](/ubbthreads/images/graemlins/Twocents.gif) Head gasket re-torqing is seldom done, so if the bolts were torqued to correct specs, it should not cause a problem.
[Re: cupcake]
#177210
12/29/08 10:40 PM
12/29/08 10:40 PM
ashburnmike
Ashburn, Virginia
take a picture of the smoke cloud????
go figure...
When I ran it today to warm it up...no cloud...no anything out of the tailpipes
[Re: buildanother]
#177212
12/29/08 10:47 PM
12/29/08 10:47 PM
ashburnmike
Ashburn, Virginia
If you have the ralley dash, your fuel gauge could be the cause of your gauges reading too high, as the voltage limiter is part of the fuel gauge, and could cause the gauges to read too high or to low if it malfunctions. Happened to my 340 duster, all three gauges, (temp, oil press and fuel level started reading half of what they should have because of the fuel gauge. I imagine a non ralley cluster may do the same if plug-in style voltage limiter freaks out. Head gasket re-torqing is seldom done, so if the bolts were torqued to correct specs, it should not cause a problem.
Yes it is the Rallye dash. The gauges were steady and stable until this recent occurance. How can you test the gauges? Could that also cause the motor to stumble if the current was interrupted...creating the "miss'
