Thanks for all the info guys, I understand the physics of the problem now.
I've ordered both the Comp. Cams buttons; nylon and roller, to see which we prefer, and have polished the area where they will contact the cover, (standard sheet metal).
It seems pretty stout with no deflection when I give it a substantial push so I'm not sure of the need for one of the cast covers outside of the timing adjustability feature.
I may weld a reinforcement plate on the outside of the cover if your consensus agrees it would help.
I'm using a Comp Cam's cam and rollers and timing set so compatibility should work when it comes to adjusting end play.
Getting close to installing the cam so stay tuned for more questions, You guys are a big help to all of us needing your expertise and I know I appreciate it!!
Joe
