Re: Which manual valve body to look for? [Re: John_Kunkel] #1770215
03/04/15 06:07 PM
03/04/15 06:07 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
thats awesome thank you very much
Re: Which manual valve body to look for? [Re: John_Kunkel] #1770216
03/04/15 08:47 PM
03/04/15 08:47 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Turns out the full instructions for converting to manual shift are also on the tech archive Here . Looks like there is a warning that the transmission will no longer have coast braking in first, I assume this means no LBA?
Re: Which manual valve body to look for? [Re: CTD5.9] #1770217
03/05/15 10:47 AM
03/05/15 10:47 AM
Up a holler, down a crick
booger Offline
booger  Offline
Correct, LBA has coast braking in first.
I will be replacing a TurboAction RMVB, with a Coan RMVB w/ LBA since the car will be street driven. Don't need the stress of worrying about anything going wrong if my wife decides to take the car to the 7-11.
There's more to making the trans LBA than just swapping the valve bodies. I don't know if they're all the same or not. See installation pdf on this link if interested.
http://www.coanracing.com/Catalog.asp?ProductDetail=2055
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: Which manual valve body to look for? [Re: booger] #1770218
03/05/15 01:28 PM
03/05/15 01:28 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
Is there any drawback to a forward pattern/lba VB? I like the forward pattern on the factory slapstick and don't want to change it.
Re: Which manual valve body to look for? [Re: Lee446] #1770219
03/05/15 04:50 PM
03/05/15 04:50 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
From talking w/ Turbo-Action and reading stuff elsewhere, a RMVB design is faster on the track for reasons I can't explain (not a tranny guru).
I have a FMVB w/ my factory Slap-Stik for exactly the same reasons you stated. Works for me.
Re: Which manual valve body to look for? [Re: BradH] #1770220
03/05/15 05:47 PM
03/05/15 05:47 PM
booger Offline
booger  Offline
I always heard the reason for reversing the pattern was so you're shifting away from neutral/reverse instead of toward it
Re: Which manual valve body to look for? [Re: booger] #1770221
03/05/15 06:33 PM
03/05/15 06:33 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I had to regrind/weld the shift gate in my column shift for my mud bogging truck, we routinely shift a ton and that shift into Neutral or reverse sucks.
Re: Which manual valve body to look for? [Re: DusterDave] #1770222
03/06/15 03:43 AM
03/06/15 03:43 AM
Southern Maryland
preddy Offline
preddy  Offline
Southern Maryland
call john cope. get one of his. CRT hands down.
+1. John da man!
+2. call John at CRT - LBA RMBV + bolt in sprag + billet drum
It's a crap shoot - I know people that have raced for 20 years with less and have had no issues. I also have a friend who used a non-LBA RMVB and a stock drum. It was built by a well known transmission guy and it grenaded on him and tore up his car and cost him a body part...
Re: Which manual valve body to look for? [Re: booger] #1770223
03/06/15 05:01 AM
03/06/15 05:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I raced my buddies Duster for him and he had a forward pattern manual V/B and I hated shifting while racing having to push the shifter forward. I am just so used to the reverse manual V/B and it just makes more sense when racing your car to pull the shifter towards yourself. Ron
