Page 2 of 3 1 2 3
Re: Front wheels don't turn ! [Re: gtsdude] #1769362
03/03/15 12:11 PM
03/03/15 12:11 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
I forget what the hole is called in the master cylinder but if your pushrod is to long it will not let the pressure bleed back through the hole. So your brakes will just lock up harder (pump up) every time you push on them
Re: Front wheels don't turn ! [Re: Wedgeman] #1769363
03/03/15 12:30 PM
03/03/15 12:30 PM
Az
Crizila Offline
Crizila  Offline
Az
I just tried loosening the bleeder screws and turn the tires.....the pads are still sticking to the rotor and making it hard to turn by hand.....
If you have the bleeder screws loose and the brakes are still dragging, the problem is in the calipers. Forget everything else for now ( not a hydraulic problem )and go directly to the calipers. Pistons are not retracting ( worn square cut "O" rings or corrosion in the piston bores / pistons. Other issue could be calipers not sliding on the pins or on the sliders - again, corrosion.
Fastest 300
Re: Front wheels don't turn ! [Re: littleVAL] #1769364
03/03/15 12:33 PM
03/03/15 12:33 PM
Az
Crizila Offline
Crizila  Offline
Az
Compensating port. Not his problem if the brakes still drag after he opens the bleeder screws. I think he said he has pushrod clearance.
Fastest 300
Re: Front wheels don't turn ! [Re: Crizila] #1769365
03/03/15 12:39 PM
03/03/15 12:39 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
How long has the car been sitting? We have high humidity and this happens every winter to our cars. Drive it around and drag the brakes and see if the corrosion/surface rust grinds off and they free up.
Re: Front wheels don't turn ! [Re: 66coronet] #1769366
03/03/15 12:46 PM
03/03/15 12:46 PM
Az
Crizila Offline
Crizila  Offline
Az
- is that like a hillbilly tune up? " hold the gas peddle on the floor and what ever is holding it back will break loose and blow out".
Fastest 300
Re: Front wheels don't turn ! [Re: Crizila] #1769367
03/03/15 12:49 PM
03/03/15 12:49 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
Drag the brake to eat the surface rust off while driving through the pits. Not hold the brake. Big difference.
Re: Front wheels don't turn ! [Re: 66coronet] #1769368
03/03/15 01:52 PM
03/03/15 01:52 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I was noticing some surface rust on my disk rotors last weekend. Tis the season...
Re: Front wheels don't turn ! [Re: Airwoofer] #1769369
03/03/15 02:16 PM
03/03/15 02:16 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I think once again some of us are making a mountain out of a mole hole. The poster is from Canada and it is February. All disk brakes have some drag especially after that cold wheel bearing grease and Winter rust sets in.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Front wheels don't turn ! [Re: pittsburghracer] #1769370
03/03/15 03:51 PM
03/03/15 03:51 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
The car is in a heated garage, even in the summer it has that effect......
Like stated before I installed calipers and all other related components new....it's been doing that ever since but never corrected the problem
Again, like I said before the car is always a dog to push in the pits...
Dan
Re: Front wheels don't turn ! [Re: Wedgeman] #1769371
03/03/15 04:03 PM
03/03/15 04:03 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Do you have residual valves?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Front wheels don't turn ! [Re: Eric] #1769372
03/03/15 05:04 PM
03/03/15 05:04 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Did you convert from drum brakes? I remember from long ago that a drum brake master cyl. won't work on a disc set up?
Re: Front wheels don't turn ! [Re: camastomcat] #1769373
03/03/15 06:00 PM
03/03/15 06:00 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
My car has done this same thing since I converted it to front disc. I used front disc setup off of a 80's diplomat. Spindles, rotors, calipers, and a master cyl from a 90's dodge ram truck I believe. The fronts just dont turn free when its jacked up. I dont think it is hurting my E.T.'s but I could be wrong.
67' charger 499 RB 10.57 at 127
Re: Front wheels don't turn ! [Re: dragram440] #1769374
03/03/15 06:26 PM
03/03/15 06:26 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
If it's a front drum brake master, that may be the problem. And if there is enough resistance, and they grab or one does, think of the possibilities.
Re: Front wheels don't turn ! [Re: dragram440] #1769375
03/03/15 06:44 PM
03/03/15 06:44 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Have you tried just removing the caliper completly and turning the rotor? If not, just pop it off and if you find the rotor difficult to spin, most likely you have overtighten the spindle nut and that's the source of the added drag.
If the rotor spins freely w/o the caliper you may try the attached tech tip which adds a spring to move the pads away from the rotor. Here's the link found in the archive.
http://www.moparts.org/Tech/Archive/brake/13.html
Re: Front wheels don't turn ! [Re: camastomcat] #1769376
03/03/15 07:17 PM
03/03/15 07:17 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
It is a aluminum master off a 94 Ram with disc brakes. It is certainly drag from the pads. I hope no one has wheel bearings that tight or you are gonna have some major issues. I dont think you could get anything in the 90's with drum brakes! The master cyl. rod is correct length and not pushing the piston on the master.
Re: Front wheels don't turn ! [Re: dragram440] #1769377
03/03/15 08:30 PM
03/03/15 08:30 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Yes it is converted from drum brakes...
I swapped to a disc brake MC, prop valve, and new parts all around, I left nothing on the table here....
Hoses bleed freely....non kinks...
Dan
Re: Front wheels don't turn ! [Re: Wedgeman] #1769378
03/03/15 09:13 PM
03/03/15 09:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dan
In this statement you say there seems like a small
pressure... IF I read it right
After inspections, I let off the bleeders again and it seems like it is always pushing the piston in the caliper, like a constant small pressure...
The brale pedal has lots of freedom to retract...
Dan
Is that what your saying ... is there pressure there
or is it in the caliper (not rolling back)
Re: Front wheels don't turn ! [Re: MR_P_BODY] #1769379
03/03/15 11:46 PM
03/03/15 11:46 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Yes even with the bleeder unscrewed, the piston still pushes on the rotor...making it hard to turn
Re: Front wheels don't turn ! [Re: Wedgeman] #1769380
03/03/15 11:57 PM
03/03/15 11:57 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Pull the brake pads out and see if that's really the problem.
Re: Front wheels don't turn ! [Re: Wedgeman] #1769381
03/04/15 12:32 AM
03/04/15 12:32 AM
Az
Crizila Offline
Crizila  Offline
Az
Piston is not pushing on the rotor, it is just not retracting enough. Dirt, rust, misalignment, damaged pistons(chatter marks), etc. There should be some "slight" drag to keep foreign material from getting in between the rotors and pads. You should be able to spin the tire by hand and get at least 1.5 tire rotations out of it. Time to tear it down and find the problem - before this thread turns in to a real drag.
Fastest 300
Page 2 of 3 1 2 3
