Re: building fast 383's
[Re: 383ute]
#1765683
03/01/15 03:38 AM
03/01/15 03:38 AM
Posts: 22 downunder
383ute
downunder
i'd really like to see what combinations people have used & what results they had. i'm involved in 2 383 engine builds atm, one in a 72 cuda & other in a 69 A body ute/pickup 3200lbs.
cuda has ported 516 heads 2.08/1.74 valves new Klines, springs retainers locks from "hughes". tm6 inlet 1" spacer 750dp hood scoop purple 509 cam timing chain, kb +.030 -6cc dome hyp pistons with arp rod bolts. 727 & 8 3/4 3.23 . no converter or gears yet.
69 A body pick up indy ez 76cc heads 10.7:1 static comp, heaverly ported street dominator manifold 3"spacer, 750dp 68 hemi dart scoop. 1.6 roller rockers, mopar .577 cam. 564ish lift after lash ( ez heads 295 cfm @ 550" lift from hughes site" & 252* @.050, 110* ls. 4*advanced. arias -12cc domed forged floating pistons on prepped std rods & crank. arp r/bolts, main & head studs. block is resleeved on all 8 cyls & 1/2 filled. all balanced as well as 1/2 oil pick up & deep pan . 3500 stall reverse pattern shift 727 alloy pan & braced 8 3/4 3.9 gears. this is the info i have on my ute & friends cuda both have headers & 2 1/2" mandrell exhausts. both arn't built yet so i got no advice on these. though can tell you my ute went best 13.4 & 104mph with 3000 stall 3:55 bw 6cyl diff 26"225 tyre & worn out std 383 w/std 906 heads custom 509/511" 312/318* 108*LS cam. worn out whole timming system .0105 piston clearence, ultra low compression, unported street dominator 1" adapter 750dp. but couldn't set timming.
[Re: 383ute]
#1765685
03/01/15 01:44 PM
03/01/15 01:44 PM
Posts: 8,682 Buford, GA
I_bleed_MOPAR
Buford, GA
The 383 in the Charger is nothing special but pretty strong. Mike McCandless built it and ran it in a 3500 lb. RR for a short time. I have most of the specs at home but what I can remember is it has Ross 9:0-1 pistons, Comp "540" cam, 906 heads, balanced, and a Performer RPM intake w/ a 750 Holley. IIRC, best ET was 7.15 in the 1/8th with a 4k converter (never thought to ask what gear).
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: dvw]
#1765688
03/01/15 02:37 PM
03/01/15 02:37 PM
Posts: 22 downunder
383ute
downunder
A 383 with stock heads, good pistons, and the right cam would make good power with a 75 MM turbo. With eddy heads I bet you could make 700+ @15psi. Doug
I'm thinking with a 75 mm turbo & eddy heads 700+ with 10lbs .
[Re: 383ute]
#1765691
03/01/15 03:09 PM
03/01/15 03:09 PM
Posts: 9,894 MI, usa
dvw
MI, usa
I don't think so. Doug
[Re: RemCharger]
#1765692
03/01/15 03:11 PM
03/01/15 03:11 PM
Posts: 22 downunder
383ute
downunder
Is the ute a track only deal? And what kind of fuel will you be using. Are the indys max wedge ports?
no it's a street car that's getting closer to a track deal. maybe a set of flashing lights away from being a track car. it will go togeather na for now on 98 pump gas if boosted will be duel fuel 98 pump for starting/warming up & e85 for boost. & no indy's are standard intake window atm. i reckon it's a good little combo for now. i'm hoping for mid 11's or better & with some weight loss other mods may touch the 10's.
[Re: dvw]
#1765694
03/01/15 03:24 PM
03/01/15 03:24 PM
Posts: 22 downunder
383ute
downunder
maybe not but after seeing some of the times & mph some of the guy's are getting with very basic small blocks & street weight cars , & theres a bunch of these guys using cheap holeset diesel turbos & e85 it makes me wonder what a free reving 383 will do with good heads.
[Re: RemCharger]
#1765695
03/01/15 03:36 PM
03/01/15 03:36 PM
Posts: 22 downunder
383ute
downunder
With e85 you could build a real stout n/a motor.
well that was the plan. then me mate rang me & told me about these guys using holsets & e85 & blow through carbs & costs of custom headers ect. i'm ata point where i need to start milling my heads & better cam new head gaskets to gain more compression for the e85. a mate is upto 14:1 in his big block chebby & his thing gets better & better with compression & runs heaps cooler. but if i'm going turbo down the track i'm best leaving my heads alone.
[Re: dvw]
#1765696
03/01/15 03:40 PM
03/01/15 03:40 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
is 75mm big enough to support 700hp? As for headers... I doubt they are going to matter much. It's not like you are going to be able to use anything off the shelf. I sure hope you are good at fab work. Otherwise you'll be paying somebody big money to fab up the hot side.
[Re: danbob]
#1765700
03/01/15 09:42 PM
03/01/15 09:42 PM
Posts: 1,413 Johnstown
69dart
Johnstown
I've always run 383's. Currently I'm running a .030 over TRW piston, .600ish roller cam, otb 440 source heads, M1 intake, 750 E85 carb in my roadster. Best ET is 9.73 I believe @ 133 or 6.11 @ 108 in the 1/8th. I'm in the process of building a spare. Only thing I'm changing is flycut the pistons so I can run a little bigger cam and maybe some better heads. I'd like to throw a little spray at it this year. Maybe 150HP Plate system to dip in the 5.90's or help at the stripe.
