Re: Help with Pro Magnum rockers experience.
[Re: RemCharger]
#1764965
02/28/15 12:29 AM
02/28/15 12:29 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I have not with your specific parts pile , but changing the rockers means measure and order the correct length push rods for any single shaft mounted deal. I have no idea how much the difference is , but is was substantial with my 340 small block.......and I wanted better push rods anyway. ![](/ubbthreads/images/graemlins/thumbs.gif) ( I went from stock to H.S. )
[Re: sasquatch]
#1764971
02/28/15 02:09 PM
02/28/15 02:09 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
They use a ball ball style pushrod . Once you determine the length you can shop in the Bowtie section for pushrods. Way cheaper and huge selection..No need for customs on that rig. Todd
Fixed ![](/ubbthreads/images/graemlins/beer.gif)
[Re: B3RE]
#1764978
03/01/15 06:26 AM
03/01/15 06:26 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
I think he means the solid hold downs that clamp the top of the shafts to the pedestals instead of the cheap ass stamped metal Mopar pieces.
I used those as well on my low deck and shimmed the rocker pairs to avoid rubbing the PR at the tunnels. I also upsized to a .375"/.080" wall PR. Bushed lifter bores and edm lifters as well.
[Re: 64Post]
#1764979
03/01/15 12:40 PM
03/01/15 12:40 PM
Posts: 7,664 IN
ahy
IN
Yes and yes. Solid shaft hold downs. Sides milled slightly to generate clearance along the shaft and shim washers used to line up rockers over the valves. Bought the shim washers in packs of 16 or something like that from Mancini. I upgraded to 3/8" pushrods at the same time. Sweep over the valve was centered and tight though no photos or measurements.
[Re: ahy]
#1764980
03/01/15 02:23 PM
03/01/15 02:23 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
My first time using the Comp Pro Magnums and I really like and prefer the cup being part of the rocker stud and being able to use ball/ball pushrods.
I'm a little vexed why you say you would look for 1-2 turns when you can easily get full lash adjustment with only 5/8 to 1 turn. The rocker still oils through the hole and there also less likelihood of losing a pushrod from the rocker stud backing off since it will still be 'captive' by the cup stud.
I know you want/need ~1 1/2-2 turns whenever you have a cup type pushrod, But you need that room to make sure the lip of the cup can't contact the rocker body at full lift. With a cup/stud this is not a concern since the stud now has a machined flat behind the cup and the rocker.
The pro magnums are a nice upgrade, I think I may switch all my other rocker arm ball studs to stud cups and go to ball ball pushrods. Seems a lot simpler.
[Re: Bill MeLater]
#1764982
03/02/15 04:03 PM
03/02/15 04:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
How do they oil the cup to ball then? Is pushrod oiling needed?
The single shaft version has a hole in the cup.. oil from the shaft goes through the rocker to oil the roller tip and the cup ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1764983
03/02/15 04:27 PM
03/02/15 04:27 PM
dogdays
Someone else said this but I'll repeat, www.oempushrods.comDecent low-cost pushrods available in 0.050" length increments. I'd suggest getting pushrods that oil through the ball even if you don't use that feature right now, you may use it later. R.
