Re: `61 Fury and `62 300 axle the same ?
[Re: 67R/T4speeder]
#1763873
02/27/15 04:23 PM
02/27/15 04:23 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
'57-'64 axle shafts are all the same with the SG/non-SG provision.
The bolt pattern at the end of the main housing changed in '62 so the complete rear ends aren't totally interchangeable (pre-'62 has no parking brake provisions).
[Re: 67R/T4speeder]
#1916703
09/21/15 02:00 PM
09/21/15 02:00 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You realize the difference between SG and non-SG is the length. Looks to me there is more than just the bearing seal diameter difference. Looks to me the lower shaft pictured is beefier all around. Which tells me it's probably a beefier axle for the 300 setup. So is it a 61 300 or a 62 300 donor, cause you list both.
The seals are different 61 vs 62 300.
[Re: 67R/T4speeder]
#1916740
09/21/15 02:52 PM
09/21/15 02:52 PM
Supercuda
About to go away
About to go away
up yours
Between the bearing and the splined end is where the length difference would be.
[Re: 67R/T4speeder]
#1916764
09/21/15 03:18 PM
09/21/15 03:18 PM
Posts: 1,669 Caldwell, Idaho
67R/T4speeder
Caldwell, Idaho
OK I will take another look I appreciate the input My buddy has been building this `70 Cuda protouring style for years now and I always ask " Hows Supercuda coming along? "
[Re: 67R/T4speeder]
#1916850
09/21/15 05:23 PM
09/21/15 05:23 PM
John_Kunkel
Rio Linda, CA
The SG axle shaft is only 1/8" shorter than the non-SG axle shaft so measure carefully. Run the tape measure parallel to the centerline of the axle, not down the side of the axle shaft.
[Re: 67R/T4speeder]
#1917328
09/22/15 12:31 PM
09/22/15 12:31 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Nice looking Fury.We had one all black and vert.It had the 395 Golden Commando package.People said the old man was nuts to pay 700 for it in 64.Rocky
Chrysler Firepower
