Re: Help set up my fuel system [Re: MR_P_BODY] #1763634
03/04/15 03:37 AM
03/04/15 03:37 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Need to upgrade my fuel system on my street/strip Satellite. It's adequate for street use but has started to run out of fuel at the top of third when I've gotten on it on a hill (highway onramp).
Right now the engine is in the 525 HP neighborhood, car should run mid 11s but hasn't been down the strip yet as I'm still sorting it out. Plans in the near future are for headwork and 600-650 HP.
I'm thinking 1/2 inch pickup and fuel line up to the mechanical pump, with one Holley black pump. 9/16 line from the pump to carb with a dead head fuel pressure regulator. Does this sound sufficient? I would think that this should be more than enough but I really don't know.
Why the 9/16 line... the 1/2 is your choke/flow
and is more than enough.. I assume you would run on
the mech pump and turn on the black when racing
Will a mechanical pump draw through an electric pump when on the street just driving around? I wouldn't mind having an electric pump at hand for race duty, but it would be nice to be able to drive around town on just the mechanical pump.
(sorry for the hi-jack)
My buddy does it on his 460.. mech pump with a holley
blue in the rear... so yeah I guess it works..he
has been doing it about 6 years now... he runs 11.50
on motor and 10.80 on a little spray
Looking at the Carter rotary vane pump. Reading around on this a little, most seem to recommend using a parallel line around the elec. pump with a check valve. Would you say this would be good practice, Mike?
Re: Help set up my fuel system [Re: StealthWedge67] #1763635
03/04/15 03:59 AM
03/04/15 03:59 AM
MR_P_BODY Offline
Happy Birthday MR_P_BODY  Offline
I've never done it... to me the check valve would have
to be big... same ID as the line... but I've never done it...
I either run a mech or a elec... but thats me
Re: Help set up my fuel system [Re: MR_P_BODY] #1763636
03/04/15 04:14 AM
03/04/15 04:14 AM
CT
GTX MATT Online content OP
GTX MATT  Online Content OP
CT
I have a friend with a carter electric (not sure which one) that the mechanical pump wont pump through, he's gotten stranded a couple of times over the years when the electric pump dies, so it must depend on the pump.
Re: Help set up my fuel system [Re: GTX MATT] #1763637
03/04/15 02:41 PM
03/04/15 02:41 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You could do like I do. I run just an electric pump on the street but I do carry a spare pump with me. I run the Holley electric pump and I have never had it fail yet but its good to be prepared. I also carry a spare coil , ballast , dist pick-up and dist cap & rotor. Ron
Re: Help set up my fuel system [Re: 383man] #1763638
03/06/15 11:14 AM
03/06/15 11:14 AM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
I'm a huge fan of the quieter gerator vane pumps such as the HP125 Holley or Mallory 140 along with a 100 micron filter. And also running a return line system! Just run one GOOD electric pump with return and it will last for years! Do it once, do it right.
Of course use a return style regulator and I'm a fan of -8AN single line to the carb with the inline gauge and another 40 micron filter.
Remember, same size line up & back (1/2" with your future add-ons). Simple with the new 1/2" stock pickup tubes for stock tanks now (Vansauto.com). Most of the tanks have an "extra" vent line you can use for the return- or with a new tank, weld on a bung & fitting for it.
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: Help set up my fuel system [Re: chrisnben] #1763639
03/06/15 03:44 PM
03/06/15 03:44 PM
California
mickm Offline
mickm  Offline
California
i don't know, but it seems to me that fuel systems get way overthought and over bought.
i run the stock 3/8" fuel line and pickup to a carter mechanical pump from mancini. from there i run 5/16" line to a tee, and 5/16" line to both carbs. essentially, it is a stock hemi system.
the pump was supposed to self regulate to the 5.5-6psi that the carters need, but was all over the map, as high as 10psi. i got another pump from them, the same. so i hung a holley regulator directly off of the pump. other than that, this is a stock system.
so far i have no indication of starving for fuel, and i run 2 650 edelbrocks. granted, i haven't taken it down the track, so i don't know what it will do after 10-11 seconds of full throttle, but if there was an issue i could most likely up the pressure at the regulator and that may solve it, even for the track.
so a basically stock system is feeding 540" and 1300cfm, so far with no issues. and yes, i do pound it!
