Re: 67 coronet rt stripe? [Re: KISSAlien] #1761663
02/24/15 04:01 PM
02/24/15 04:01 PM
K
KOS Offline OP
KOS  Offline OP
K
This picture was taken in the Spring of 1967. Check out the black stripe. This car was delivered to the dealership with it. But it doesn't have the Dodge lettering. Maybe the ad was of a prototype.
explain this then.........factory did strange things just like they said my dads 67 Z28 never came factory with headers supposed to be dealer only install....well it did confirmed by numerous specialists.
Have you ever painted any stripes? If so, what was the step-by-step process you used?
As for the Z28 factory headers were an well known factory option in 1967 and 1968. They came in the trunk and the dealer installed them upon delivery. There are many different cars where this process was used.
so if it was the dealer did they read the fender tag said we have to paint a pin stripe on the car?i assumed it was a decal(sticker)not painted...even so how do you explain how the other coronet mentioned came with the stripe out of the factory?also the header deal that came in the trunk of the z28s which everybody knows isnt the case with the old mans car...they came factory installed not dealer....if you like to wager on it i could prove it.
Re: 67 coronet rt stripe? [Re: KOS] #1761664
02/24/15 04:17 PM
02/24/15 04:17 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
How come the one Coronet mentioned/pictured does not have the Dodge lettering/cutout but the advertisement does?
Re: 67 coronet rt stripe? [Re: autoxcuda] #1761665
02/24/15 04:24 PM
02/24/15 04:24 PM
K
KOS Offline OP
KOS  Offline OP
K
good question id like to know the answer also.......im just saying factory did weird stuff who knows for sure.my big question is did the dealer read the fender tag(or how does it work)and say we have to paint a stripe on this one?
Re: 67 coronet rt stripe? [Re: KOS] #1761666
02/24/15 04:48 PM
02/24/15 04:48 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
good question id like to know the answer also.......im just saying factory did weird stuff who knows for sure. my big question is did the dealer read the fender tag(or how does it work)and say we have to paint a stripe on this one?
I don't believe the dealer had any info, decoders and/or was not trained to completely decipher a fender tag even in 67. And they can do pretty much whatever they want to the car before it's sold. It's their car (sorta sometimes).
Factory built cars as planned. They had various large build plan sheets that had codes that were on the fender tag and build sheet, and much more to accompany cars down line.
They did not make stuff up out of the blue. They do make some minor mistakes that are not caught.
As was said. There is nor has been found a production code for racing side stripes on 67 Coronet R/T.
I don't believe any 67 Dodge or Plymouth had wide racing side stripes in 1967?
Re: 67 coronet rt stripe? [Re: autoxcuda] #1761667
02/24/15 04:54 PM
02/24/15 04:54 PM
K
KOS Offline OP
KOS  Offline OP
K
The dealer does not really check tag. They did not have info to completely decipher them even in 67. And they can do pretty much whatever they want to the car before it's sold. It's their car (sorta sometimes).
well you just answered my question......it is on my fender tag white horizontal accent stripe so whatever it means the factory put it on the car correct?
Re: 67 coronet rt stripe? [Re: KOS] #1761668
02/24/15 05:00 PM
02/24/15 05:00 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
And the accent stripe is commonly called a pin stripe.
Here's the factory information:
http://www.hamtramck-historical.com/dealerships/1967DodgeColorAndTrim-03.shtml
Re: 67 coronet rt stripe? [Re: p d'ro] #1761669
02/24/15 05:12 PM
02/24/15 05:12 PM
USA
b54406barrel Offline
USA
Is it cryptic that the ad for a 67 r/t has bold 'road runner' wording in it? Where's the 'tin hat' smiley?
Re: 67 coronet rt stripe? [Re: autoxcuda] #1761670
02/25/15 01:02 AM
02/25/15 01:02 AM
K
KOS Offline OP
KOS  Offline OP
K
did i miss something??....where does it say accent stripe???
heres the fender tag code .... LL1 p6x ax68
Re: 67 coronet rt stripe? [Re: KOS] #1761671
02/25/15 02:07 AM
02/25/15 02:07 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Says paint stripe. That's the accent stripe.
Mopar never painted on any stripes that were only on the side of the car wider than a pin stripe in the 70's and 70's.
There is a picture of a 66-67 car getting a painted pin strip applied at the factory. It's a long pad on a jig that gets pressed against the car like an ink pad. On many original paint cars you can see the paint thin in the middle of the pin/accent stripe were the pad pushed out paint to the edges.
I'm not sure any big three company painted stripes wide enough that would need masking on the side of a car in the 60's and 70's.
