Re: OUCH!! Hope this isn't permanent......... [Re: stumpy] #1760603
02/24/15 08:36 PM
02/24/15 08:36 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Stump
Actually it does
When tranny temp is cold od is delayed
Red
Re: OUCH!! Hope this isn't permanent......... [Re: stumpy] #1760604
02/24/15 08:59 PM
02/24/15 08:59 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Temp has nothing to do with trans od.
Are you 100 percent sure on that?
Re: OUCH!! Hope this isn't permanent......... [Re: mopars4ever] #1760605
02/24/15 09:40 PM
02/24/15 09:40 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
my 93 with a 318 is better on MPG than my 94 with a 3.9/ but I have never had one 9 MPG-bad. except my 88 D 100,318, 1st year they had TBI.
My 94 (3.9 auto reg cab short bed 3.55s) got a best ever of 18-once- usually 17 on a solid highway run, 14 in the winter in mixed driving, my 318 one (club cab, converted to 5 speed by me, also 3.55s) gets 20 on the highway and 17-18 in mixed driving. never did worse than 15, even towing, with this one. both trucks 2wd,
my 90 (3.9 pre magnum long bed also 2wd, 3.55s) got 16 in town/20 highway, like clockwork.
Re: OUCH!! Hope this isn't permanent......... [Re: stumpy] #1760606
02/24/15 09:41 PM
02/24/15 09:41 PM
places
79powerwagon Offline
places
It sure does when it's WAY below zero! Mine is merely a 3 speed with no lock-up when it's beastly cold out. When it gets to be 10° above zero or higher, it works as it should.
You should hear the rear end SCREAMING in the cold! It sounds like a UFO!
Re: OUCH!! Hope this isn't permanent......... [Re: 79powerwagon] #1760607
02/24/15 10:08 PM
02/24/15 10:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I stand corrected after some research. I thought the trans temp sensor only caused the trans to drop out of OD when it got too hot. not when it was cold. Isn't that a 1998 and newer thing?
Re: OUCH!! Hope this isn't permanent......... [Re: stumpy] #1760608
02/24/15 10:47 PM
02/24/15 10:47 PM
Between Houston & Galveston TX
SattyNoCar Offline OP
Yes, the OD is working, and so is the lock up. In certain situations, its noticeable enough that it feels like a 5 spd.
As I mentioned in another thread, I think the previous owner thought the trans was 'bad' because the truck doesn't have the 'snap' of a new vehicle. To me, it feels fine. It shifts as it should. To me, it actually shifts better than the 2002 I used to have. With the '02, I practically had to mat it to get it to drop a gear and pull (like if I slowed way down and wanted to get back up to speed quickly). With this,same scenario, and it drops down a gear without even coming close to matting it, pulls hard up to speed, upshifts, OD kicks in and you're at cruising speed. No fuss, no muss.
John
Re: OUCH!! Hope this isn't permanent......... [Re: stumpy] #1760609
02/24/15 10:52 PM
02/24/15 10:52 PM
Truckville, the capital of NY
85_Ram_4speed Offline
My '96 ext cab v-6 got around 15ish around town, 19-20ish highway. I once--and only once got 22 on a 600 mile round trip after it was given a full tune up. I owned the truck from 54,000 miles to 135,000 miles(9 years). Obviously the older the truck got, the worse it got, but it was pretty consistant to the end.
Sounds as if the T-stat is a little faulty, replace it---factory 195 is adequate IMO.
Outcast Dodge guy.
Re: OUCH!! Hope this isn't permanent......... [Re: BIGGERED] #1760610
02/24/15 10:57 PM
02/24/15 10:57 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
my '89 dakota goes into overdrive, as soon as i get up to speed. temp is not a factor.
Re: OUCH!! Hope this isn't permanent......... [Re: Golden-Arm] #1760611
02/25/15 12:46 AM
02/25/15 12:46 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
My 92 also shifts to OD no matter how cold it is.
The lockup function seems to have a bit of a delay when the trans is cold, but after the engine reaches full temp it works fine.
I am also using a Mopar Performance 166k lockup converter, not sure if that has anything to do with it.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: OUCH!! Hope this isn't permanent......... [Re: hp383] #1760612
02/25/15 03:55 PM
02/25/15 03:55 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Any of the Dodge trucks I've owned with an OD trans will not shift into OD when it's cold. I've had a 90,95,96 all do this, even my 05 does it. My brothers 96 and my dads 98 do it as well. And by cold I mean -25C (which is about -13F) and I haven't let it warm up at all (yes I know that's not good for a vehicle but sometimes you have no choice)
Re: OUCH!! Hope this isn't permanent......... [Re: WO23Coronet] #1760613
02/25/15 09:40 PM
02/25/15 09:40 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
On my 05, if it's colder than about 25F outside the converter stays unlocked for the first mile or two of freeway driving.
Re: OUCH!! Hope this isn't permanent......... [Re: Blusmbl] #1760614
02/25/15 09:55 PM
02/25/15 09:55 PM
places
places
It's good to hear that my old is behaving "normal"!
Are these trannys any more complex than a 727 (besides the OD)?
Re: OUCH!! Hope this isn't permanent......... [Re: 79powerwagon] #1760615
02/25/15 10:39 PM
02/25/15 10:39 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
The internals of the transmission no not really. They use the same clutches, and hard parts.
Main difference is in the valvebody with the OD solenoid, and electric lockup (If applicable).
Re: OUCH!! Hope this isn't permanent......... [Re: WO23Coronet] #1760616
02/25/15 11:19 PM
02/25/15 11:19 PM
If it ever gets that cold around here, the OD or even the truck itself will be the LEAST of my problems.....
John
Re: OUCH!! Hope this isn't permanent......... [Re: Blusmbl] #1760617
02/26/15 01:30 AM
02/26/15 01:30 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Sorry I should have added that once it warms up after a couple of miles it will kick into OD
Re: OUCH!! Hope this isn't permanent......... [Re: stumpy] #1760618
03/03/15 11:06 PM
03/03/15 11:06 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Replace the thermostat. Cheap and easy to do. Go with the high temp one. I think it's 205-210*. The newer engines like the higher temps.
I bought a new '90 3.9 Dakota off the dealer lot. First year I drove it, it wouldn't put heat in the cab. Then one day I caught it smoking black at idle. Pulled the thermostat, stuck open. Heat finally worked and truck ran better (normal) after that fix. I want to say it got around 14mpg average, extended cab, 2wd.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: OUCH!! Hope this isn't permanent......... [Re: GO_Fish] #1760619
03/04/15 01:11 PM
03/04/15 01:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Over in the Q&A section, I had a lot of guys disputing me that the V6 does crap for mpg. Less power than the 5.2, same mpg. I think it just takes a certain amount of hp to drive these things down the road. But 9 is bad, worse than it should be. You should at least be seeing teens mpg. Have you checked it fill to fill straight highway driving? Town driving, warm-up, short trips, etc will kill mpg.
FWIW, my buddy and I took his 97 ram 1500 extended cab 5.2 4x4 auto on a 3000 mile round trip. When we were on the flat lands in North Dakota, we ran a tank full of gas at 75mph on the interstate, got 13.5mpg. Slowed down to 55-60 for the next tank and mileage perked up to 18.5mpg. We stayed around that speed the rest of the trip. On the way back home (1500 miles) we were towing my boat/trailer, combined weight about 2200lbs. The poor 318 struggled with the extra weight and drag behind it on the hills coming up through the Missouri, Iowa, Nebraska area. Constantly shifting up/down unless I let it slow down going up the hills or went fast enough to keep it reving higher in 4th. Either way mpg was crap, don't think we broke 14mpg towing. Maybe once we hit the flat lands it had the chance to pick up a little.
My 94 Ford Explorer 4.0L 5sp manual 4x4 would do 17mpg on the highway when towing the same boat. She was real low on power doing it but got the job done. Good thing the highways here are flat and boy did the 5sp ever make towing better. That would have been a miserable tow rig if it would have had the auto trans.
My 99 Ram 2500 5.9 cummins 24v auto 4x4 long box extended cab truck towed the same boat at a consistent 17-19mpg on the highway.
Then later on same buddy bought a minty low mileage 2001 ram 2500 v10 5sp 4x4 extended cab long box. I borrowed it when going to pick up a dart sport I was buying. On the hour drive dragging the tow dolly out there, the overhead console showed a typical 12-13mpg. On the way back with the car on the dolly the mpg remained unchanged and I sure never felt the car on the back.
So basically if you're only getting 9mpg, that's worse than a 3/4 ton v10 truck with 3x the power and towing capacity.
Re: OUCH!! Hope this isn't permanent......... [Re: DaytonaTurbo] #1760620
03/05/15 09:38 PM
03/05/15 09:38 PM
We had three days of temps in the upper 70's, my gas gauge basically didn't move for three days.
Today, the temps dropped back into the 30's and my gas gauge is just free fallin' towards empty.
Gee, could it be a temp issue?
I got my tax refund, so, I went ahead and ordered the hughes kit (not burning oil, just preventive measures while I have the $$$). I'm also gathering up the rest of the parts for a tune up and to change the T-stat out.
Now I just need a couple of clear days.
John
