68 coronet RT remote side view mirror adjuster location #176003
12/27/08 12:10 PM
12/27/08 12:10 PM
Anonymous OP
Anonymous OP
I need input on exactly where the remote side view mirror adjuster is located on the driver side door. It looks like the previous owner drilled a hole for it and I just want to make shure whether the hole is in the right place or not. pics would be great!!!! thanks!
Re: 68 coronet RT remote side view mirror adjuster location #176004
12/27/08 01:08 PM
12/27/08 01:08 PM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
If your car is a factory r/t this reference is best: It should be centered vertically with the front screw of the door nameplate and 1 & 7/8" forward of the front screw. To verify the center is 1 & 5/8" below the 'break' where the flat portion of the door panel (where the name plate and remote toggle mount) bends toward the window, and 6 & 3/8" toward the rear of where the above break line bends downward at the front of the door. I'll repost some pics.
