Page 2 of 3 1 2 3
Re: Jeep for Off-Roading and Other Uses... [Re: MuuMuu101] #1759927
02/24/15 04:25 PM
02/24/15 04:25 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You can always make a left turn and go with a Ramcharger.
- Stu Harmon
Re: Jeep for Off-Roading and Other Uses... [Re: Defbob] #1759928
02/24/15 10:59 PM
02/24/15 10:59 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
Avoid 96 and later V8 ZJs, they have oddball rear axles. If you get a v8 one, make sure it is '93-95.
TJ's are better, LJ is the best in my opinion.
What are the differences in rear axles prior and post '96?
And the LJ is just a longer wheel based TJ, correct? They were offered between '04-06?
Re: Jeep for Off-Roading and Other Uses... [Re: feets] #1759929
02/24/15 10:59 PM
02/24/15 10:59 PM
SoCal
SoCal
I'm open for suggestions. I guess that would include some W series of that same era as well. Diesel? Although, if it's gas, I'd like to keep it fuel injected so it would have to be newer than the mid-80's.
Re: Jeep for Off-Roading and Other Uses... [Re: MuuMuu101] #1759930
02/24/15 11:16 PM
02/24/15 11:16 PM
Rockford, IL.
Ruppman Offline
Ruppman  Offline
Rockford, IL.
yes, correct
Re: Jeep for Off-Roading and Other Uses... [Re: Ruppman] #1759931
02/25/15 12:42 AM
02/25/15 12:42 AM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
There is no way he will find an LJ anywhere near the price of a comparable ZJ, XJ or even TJ. And while I would go to a TeeJ or build another LJ in a heartbeat, OP's intended use sure doesn't look like a Wrangler type of situation. Heck, I DDed my M715 on Boggers into 20" miles into downtown Chicago every day, so what do I know?
The 5.9s have dropped in price like crazy. Rare ≠ Desirable. Most that were in the market for a 'Niner to build have moved on to SRT 8 Grands. If another sub $2K Niner comes up when I have the disposable cash, and a spot in the stable, I will buy it.
Re: Jeep for Off-Roading and Other Uses... [Re: Cooter] #1759932
02/25/15 12:55 AM
02/25/15 12:55 AM
SoCal
SoCal
I was looking at the LJ's on CL and they're pricey. At least $10k and all of them were automatics.
Here are the one's that are local. Note that the 4500 I mentioned earlier were specific CA Emissions one...
http://inlandempire.craigslist.org/cto/4901108635.html
http://inlandempire.craigslist.org/cto/4871970526.html
http://losangeles.craigslist.org/sfv/cto/4903521699.html (this one doesn't specify it but it has the 5.9L hood)
http://orangecounty.craigslist.org/cto/4888285498.html
I think I'm still leaning towards the ZJ, but am looking into the Ramcharger. It seems like they have a better towing capacity and aftermarket than the Durango.
Re: Jeep for Off-Roading and Other Uses... [Re: MuuMuu101] #1759933
02/26/15 11:20 PM
02/26/15 11:20 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have a YJ and love driving it. Don't get one of the carbed models, stick to the EFI ones. It's great in summer, fold the top down, summer cruising. If I lived in your climate it would be a no brainer. I tow a small trailer with mine sometimes but I wouldn't want to put much behind it because of the small wheelbase. But you are correct it's not good for hauling one passenger often and there's no storage space unless I fold the seat down to take it out. And with the soft top there is no keeping things locked. I don't bother to lock the doors when they can unzip a window to get in and find the nothing I keep in there.
Re: Jeep for Off-Roading and Other Uses... [Re: MuuMuu101] #1759934
02/27/15 12:14 AM
02/27/15 12:14 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
The later axles were an aluminum "Dana 44" that nothing interchanges with and has almost nonexistent aftermarket support.
Re: Jeep for Off-Roading and Other Uses... [Re: Defbob] #1759935
02/27/15 01:04 AM
02/27/15 01:04 AM
SoCal
SoCal
Good to know...
Re: Jeep for Off-Roading and Other Uses... [Re: MuuMuu101] #1759936
02/27/15 11:07 AM
02/27/15 11:07 AM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
There really isn't anything wrong with the Al D44. It's much stronger than the D35, and it's not like you are going to waste any money on aftermarket parts for a D35. You can get lockers for the AL D44, and I really don't know what other aftermarket support you would be looking for.
Re: Jeep for Off-Roading and Other Uses... [Re: Cooter] #1759937
02/28/15 03:36 PM
02/28/15 03:36 PM
SoCal
SoCal
Also a good point. I don't see why I'd need anything more than that.
Re: Jeep for Off-Roading and Other Uses... [Re: MuuMuu101] #1759938
03/03/15 01:04 AM
03/03/15 01:04 AM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
I compared the 1993 Ramcharger and the 1993 Grand Cherokee on the fueleconomy.gov website. For the search criteria, both had the 318 and automatic transmission. The Jeep is rated 1 mpg higher than the ramcharger in town and 2 mpg higher on the highway.
I like the Ramcharger better than the Grand Cherokee. Personal opinion mostly based on the appearance. I think the Ramcharger may be a little wider than the Grand Cherokee. Elbow room is good! The Ramcharger has a separate frame. The Grand Cherokee, especially the limited models, have more luxury features, such as leather seats, etc.
Re: Jeep for Off-Roading and Other Uses... [Re: QuickDodge] #1759939
03/03/15 01:29 AM
03/03/15 01:29 AM
SoCal
SoCal
The mpg is negligible to me. What's 1-2 mpg going to make a difference? I like both, as there's pros and cons to both. Probably the Grand Cherokee a little more. The Ramchargers definitely seem more scarce.
Re: Jeep for Off-Roading and Other Uses... [Re: MuuMuu101] #1759940
03/03/15 02:58 PM
03/03/15 02:58 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Ramchargers are much less common for sure! The 1970's topless models are my favorite!
I wouldn't let a small difference in gas mileage factor to heavily into the decision either. One thing I meant to mention in the previous post is that the Ramchargers with the 3 speed transmissions used more fuel than the models with overdrive. Comparing a Ramcharger with a 3 speed transmission and a Grand Cherokee would probably be a 4 mpg or so difference on the highway. (It would vary, depending on the year of the RC, the gear ratio, etc.)
On the highway, the older Ramchargers with the 3 speed automatics will have the engine turning at higher RPM's. The Grand Cherokee, which can standard with the overdrive transmission, would definitely be the more comfortable highway cruiser. If you desire to do so, the 4 speed automatic (the 518 transmission) can be swapped into the older RC's fairly easily from what I've read.
Re: Jeep for Off-Roading and Other Uses... [Re: MuuMuu101] #1759941
03/10/15 05:35 AM
03/10/15 05:35 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
So, in the future I was thinking about getting a Jeep of some sort to go off-roading and serve as a potential back-up vehicle (so off-roading won't be its primary function).
This seems contradictory to me. If it's to be a back-up to your daily driver then I see no reason why off-roading can't be it's primary function. It doesn't have to be a tube-chassis rock buggy, a well-built trail runner can have decent enough road manners for the occasional trip to the Piggly-Wiggly too.
As for your choices, I'd aim for the ZJ. There's probably been a million made, they're usually less expensive than the other 2 mentioned, have nearly the same level of aftermarket support (if you shop around) and they blow the others away when it comes to creature comforts. Don't be afraid to look into the WJs either ('99-'04). They still have solid axles but I believe the unibody structure is like 25% stiffer than the ZJ they replaced and the 4.7 gets better mileage than the 5.2 did. After 5 ZJs I've stepped up to a WJ daily driver and am looking for another as a trail rig. Regardless of what you end up with...happy wheelin'!
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: Jeep for Off-Roading and Other Uses... [Re: Cheeto] #1759942
03/12/15 12:36 AM
03/12/15 12:36 AM
SoCal
SoCal
As for your choices, I'd aim for the ZJ. There's probably been a million made, they're usually less expensive than the other 2 mentioned, have nearly the same level of aftermarket support (if you shop around) and they blow the others away when it comes to creature comforts... Regardless of what you end up with...happy wheelin'!
I just didn't want it to be a huge money pit and was worried about towing capabilities the more it's built for off-roading.
Re: Jeep for Off-Roading and Other Uses... [Re: MuuMuu101] #1759943
03/12/15 12:22 PM
03/12/15 12:22 PM
Manitoba, Canada
Manitoba, Canada
If you've decided you don't want a Wrangler, get a cherokee, not a grand. Doesn't really matter the year. The 4.0 is a rock solid engine and they can be had with a 5 speed stick if you search for them. Much more capable off roaders than the grand and they can still tow a reasonable trailer. Aftermarket support for the cherokee is pretty good and they still look good with a bit of a lift and some decent tires. The grand cherokee always looks like a minivan wannabe no matter what you do to it.
Re: Jeep for Off-Roading and Other Uses... [Re: MuuMuu101] #1759944
03/16/15 10:53 PM
03/16/15 10:53 PM
SoCal
SoCal
Quick question, this may be dumb and I should know the answer, but what's the difference between AWD and 4WD? I was talking to a friend who is very much into Jeeps and hangs out with that crowd (one of the reasons I want to get an off-roading vehicle in the first places) and he said the V8 Grand Cherokees all had an AWD transfer case and they really don't do too well off-roading as a 4.0L Cherokee with 4WD (which he advised I should look into more). He also said I shouldn't have a problem with towing the Dart as people tow they're Wrangler's out to the desert with their Cherokees and GC's.
Re: Jeep for Off-Roading and Other Uses... [Re: MuuMuu101] #1759945
03/17/15 02:55 AM
03/17/15 02:55 AM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
AWD always drives all 4 wheels. 4wd is generally selectable for 2wd vs. 4wd. AWD frequently is for foul weather capability but not really off road. This is not always the case though as there are cars like the jeep grand cherokee that are AWD but are legitimately off road capabile with low range.
Also, not all Grand Cherokee's were AWD only. My 2002 WJ had the NV242 transfer case that offered 2wd, AWD, Locked 4hi and locked 4 lo. Although others above have suggested the XJ cherokee is a better platform than the ZJ and WJ grand cherokee I strongly disagree with that arguement.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Jeep for Off-Roading and Other Uses... [Re: blown340] #1759946
03/17/15 03:27 PM
03/17/15 03:27 PM
SoCal
SoCal
My friend also told me that the trails that he usually goes to are generally more narrow, so looking into a ramcharger or something similar may not be ideal.
Page 2 of 3 1 2 3
