70 air grabber decal...... #1759506
02/21/15 12:52 AM
02/21/15 12:52 AM
Colorado Springs,Colorado
Roadrunner440-6 Offline OP
Now I'm confused.....I have a air grabber decal set from two different advertised vendors (teeth) and both are different. The first set... the decal not only covers the outside of the door but wraps around to the inside as well. The second set only covers the outside only. Which is correct for a 1970 restoration? Any help will be greatly appreciated. Thanks
Re: 70 air grabber decal...... [Re: Roadrunner440-6] #1759507
02/21/15 02:17 AM
02/21/15 02:17 AM
...After researching....apparently the 71-72 was a larger decal so it would wrap around and into the scoop. This would prevent the decal from peeling back as the 70's would. For what it's worth....
Re: 70 air grabber decal...... [Re: Roadrunner440-6] #1759508
02/23/15 10:41 AM
02/23/15 10:41 AM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
A real deal assembly line original 1970 Air Grabber decal is more of a tomoato red/orange reflective also. The larger 71-72 decal is a lighter orange reflective. These are never installed assembly line originals that I got from a the estate of a retired line owrker.
Re: 70 air grabber decal...... [Re: EL5 71] #1759509
02/23/15 10:42 AM
02/23/15 10:42 AM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
no flash
Re: 70 air grabber decal...... [Re: EL5 71] #1759510
02/23/15 10:44 AM
02/23/15 10:44 AM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
back
Re: 70 air grabber decal...... [Re: EL5 71] #1759511
02/23/15 10:46 AM
02/23/15 10:46 AM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
2
Re: 70 air grabber decal...... [Re: EL5 71] #1759512
02/23/15 12:44 PM
02/23/15 12:44 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I have an NOS set lying around here somewhere, I will try to find them and send you a picture today.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
