Re: Car hoist????? [Re: Stanton] #1758979
02/20/15 09:52 PM
02/20/15 09:52 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
Most of the 4 posts in the shops around here also have sliding air lifts on them for doing brake jobs and such.
Re: Car hoist????? [Re: Dabee] #1758980
02/20/15 10:15 PM
02/20/15 10:15 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Picture of mine.
Re: Car hoist????? [Re: Dabee] #1758981
02/20/15 10:27 PM
02/20/15 10:27 PM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
We started out with 2 post and ended up getting a 4 post also 90% of the work happens on the 2 post but when it comes to pulling trannys and scaling the car or adjusting the 4 link the 4 post makes it nice
Re: Car hoist????? [Re: MR_P_BODY] #1758982
02/20/15 10:56 PM
02/20/15 10:56 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I just bought and installed an Ammco 9000# two post lift, wish I'd done it years ago.
Looking at the two post. Easier to work on vehicle.
Plus I'm sorta leaning towards the Bendpak.
Now for a garage that is 24" wide and 36" deep, where is the best place to put it?
I'm thinking as far back as possible to either side keeping enough room to work around it.
Thanks for the input
Matt
I mounted mine straight in from the big door, towards
the back... I have about 3' past the end of my truck
on the hoist... on the right side is my machine shop
and office area.. left of the hoist has my 38 in it
and cabinets
So Mike, I take it that your shop is 24x36?
My door will be at the front like yours but I want a smaller door at the back left for riding lawn mover snow blower ect...
With the hoist centered, do you have enough room around it?
Matt
Mine is 32' deep and 36' wide.. yes I can get around
it easy..the right 1/3 of the building is my machine
shop and office.. the left 1/3 is car storage and
cabinets and my big buffer and blast cabinet..
also my welding bench is on the machine shop side
(thats 40"x 7')... you NEVER have enough room
Also.. what will you do for heat... I highly recommend
the floor heat... works great and its cheap to run
24x36 will be the limit if the minor variance gets approved.
Now I'm thinking I'll have to stuff it to a corner to get it out of the way and go with Asymmetric to move it more out of the way.
Will be going radiant.
NG or propane?
Re: Car hoist????? [Re: MattW] #1758983
02/20/15 11:04 PM
02/20/15 11:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
NG or propane?
Mine is NG.. thank GOD we have NG here... I looked at
a house with a BIG shop/garage but it was propane
and I passed
Re: Car hoist????? [Re: Stanton] #1758984
02/21/15 12:37 AM
02/21/15 12:37 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
"4-post lifts are for storage - useless for working on cars. How would you do a brake job on a 4-post lift ???? "
NOT,,,,,,,,
I have the hydraulic jack which makes brake and suspension work easy,,,,,10 seconds and the front end is is off the ramps and easy to work on.
I have the bendpak 4 post 9 K pound lift and have no regrets.
Jack is low profile and even clears the 10 qt Charlie's oil pan on the race car
Re: Car hoist????? [Re: 69CHARGERMD] #1758985
02/21/15 01:33 AM
02/21/15 01:33 AM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
I look at it the other way. my 4 post makes it easy to do anything. I jack it up with the air jack and I have a table under it when I'm doing the brakes. then when I want to work on my race car it's sitting at ride height and I can check and do anything. check 4 Link, string line it. mine is a bendpak 14K.I got that one because it's wide so my 1 ton dually can drive on easy. it's probably a little more money with the jack but I like the piece of mind to that I don't worry about anything happening that it could fall off.
Re: Car hoist????? [Re: plycuda] #1758986
02/21/15 01:45 AM
02/21/15 01:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
They both have their place and I'm sure the OP will
buy what he wants.... but I look at what shops have
that work on cars... thats a 2 post... unlike the one
I have with the floor plate.. I have a wooden ramp
to do a trans.. if I had a open bottom one it would
be great... even on the one I have now I roll my
cart under it to work from... when I want the axle
up in place I have a set of wood blocks 2' high..
but I have found that 95% of the work I do I need
the axle hanging
Re: Car hoist????? [Re: MR_P_BODY] #1758987
02/21/15 01:56 AM
02/21/15 01:56 AM
toronto
6PAK70CUDA Offline
6PAK70CUDA  Offline
toronto
Look for ALI certification on lifts.
If you are lifting pickups get the right adapters if you are going for a 2-post.
Re: Car hoist????? [Re: MR_P_BODY] #1758988
02/21/15 02:36 AM
02/21/15 02:36 AM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
the axle hanging
well unlike most shops I don't do a few brake jobs a day. and I doubt they work on many if any race cars. so I guess it's what you would use it more for.
Re: Car hoist????? [Re: plycuda] #1758989
02/21/15 03:21 AM
02/21/15 03:21 AM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
NG or propane?
It seems you and I are in the same boat, I'm planning a 24x36 build this year as well. I have an 11k John Beam hoist that I took out of my old shop, asymmetrical is the way to go for working on cars and light trucks. For a deal on a hoist get in touch with a tool dealer (Matco/Mac/Snap-on) and see what they have to offer. The tool manufactures have trade shows for the dealers this time of year and usually have a special on hoists. Where are you in Ontario Matt?
Steve
Photobucket sucks
Re: Car hoist????? [Re: 72chrgrally] #1758990
02/21/15 02:10 PM
02/21/15 02:10 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
NG or propane?
Steve
Ottawa.
Not totally against the 4 post.
pro
Easier to get in and out of car.
Do not have to perminatly mount it to floor.
Movable.
only need 4" of concrete.
cons
take up more room
price
limited access to suspension.
Which way to go?
Re: Car hoist????? [Re: 72chrgrally] #1758991
02/21/15 02:19 PM
02/21/15 02:19 PM
Ontario
Budsworth Offline
Budsworth  Offline
Ontario
NG or propane?
Steve
I have a 10000lbs hoist that is asymmetrical and love it. I purchased mine in Oakville Ontario. Unless you re using the hoist every day like a commercial shop, then you don't need a "stickered" hoist, they are 2 to 3 times more money. I paid under 3k for mine, I ALSO went over every shiv and cable, I also spent the time to install it dead nuts level. Worth every cent and didn't cost me 6k. I used the savings for "Spray foam" insulation. Below is a link, don't be fooled these guys were great to deal with and they have every part in stock. Oh and if you want to pay the extra money, they sell the "Top of Line" Brands as well. Also they have ALL their hoists set up for you to view. We purchased 3 hoists and got a big discount, myself and two friends. Set up was 4hrs and 4 beers
http://www.liftsuperstore.com/
Re: Car hoist????? [Re: Budsworth] #1758992
02/21/15 02:45 PM
02/21/15 02:45 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
Ottawa.
pro
Movable.
cons
take up more room
price
Which way to go?
I work on cars every day, 2 post is way more versatile then a 4 post.
Steve
Photobucket sucks
